No voice navigation on Garmin 830 and similar GPS devices?
Quoted: 4257 Post(s)
Liked 1,359 Times
I've never tried it.
The screens they use are a special type called "transreflective", which allows them to be readable in sunlight without a backlight (which is the think that uses the most power). It's not perfect but it works reasonably well.
Likes For njkayaker:
Quoted: 3461 Post(s)
Liked 1,466 Times
That makes a lot of sense. As I mentioned above, I have my Garmin configured for maximum battery live (WAAS turned off, etc.) and the Garmin in my truck has a choice of dozens of languages, that might be a lot of power hungry computer power to do voice which certainly is convenient to someone in a car driving at freeway speeds, but not really needed for bicyclists.
Quoted: 3238 Post(s)
Liked 2,086 Times
The newer Garmins can use your phone to make voice announcements. That is, they relay the turns to the phones and let the phone do the voice generation.This should let the phone run for much longer than doing everything on the phone. One reason the Garmins don't do this without the phone is because the computers in them are slow (another way to make them run longer).
https://www.youtube.com/watch?v=UZlq3sAIG1c
A thanks to NJKayaker for this little tidbit.
@OP, this means you can get voice prompts from a recent Garmin, and garmin has rally good navigation and maps so this might work for you. Only issue I can think of is I'd doubt the phone BT is going to be smart enough to do a simultaneous BT voice prompt to the phone at the same time you are trying to do a BT connection to a set of headphones, mostly as BT connections can be stupid this away, so you might need a set of cabled headphones.
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times
OP here. Thanks again, all. In my defense, I was aware of the smartphone angle. This sentence in my post appears to have gotten lost lower in the thread:
Quoted: 95 Post(s)
Liked 85 Times
Maybe I should stick to the iPhone and buy the 830 for my stoker!
Quoted: 18883 Post(s)
Liked 10,646 Times
Well, who knew !. I did look thru my 1030 manual, no mention of course. The Garmin manuals truly suck.
Liked 2,086 Times
I have a set of BT headphones around, I'll try it next, but a big thanks to njkayaker for this link, I tried it on my 1030 and paired iPhone 8 with plugged in headphones when I got home, setup no problem, you just need to turn up the volume in the Garmin Connect App, but otherwise is a painless setup.
Quoted: 95 Post(s)
Liked 85 Times
Liked 10,646 Times
Liked 10,646 Times
Agree, thanks @njkayaker!
Liked 1,466 Times
Liked 2,086 Times
Likes For Steve B.:
Liked 2,086 Times
Which begs the joke about the older gentleman riding solo down the road on a tandem, gets pulled over by a cop, who tells him his wife fell off the bike about a mile back. "Oh, thank God" the old fart says, "I thought I'd gone deaf".
Quoted: 95 Post(s)
Liked 85 Times
Ha! The way it works now, the stoker has the paper map. So I listen to the RWGPS lady telling me "In 1/4 mile, turn right." I repeat it out loud. Then the real-life lady with paper map says: "Oh she must mean turn at Olive Ave."
Ride it like you stole it
Now if you are riding alone, that is a different story, but for tandem riding two computers or GPS devices are totally unnecessary.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
Another 830 user chiming in. I use and highly recommend Aftershokz Aeropex during rides. Once paired to a phone w/ Garmin Connect installed, with the alerts settings enabled, you can perfectly hear your surroundings plus the Garmin alerts, including voice navigation. These in no way physically cover/block your ears from hearing anything in your immediate environment. (They also sound pretty decent for music, although bass response will be less due to bone conduction tech. A fair trade-off IMHO when considering safety while riding.)
You do have to make sure the headphones don't get caught in the helmet straps when taking them off, though. The first time I rode with them, I thought I had lost them after discovering they weren't still on my head after removing the helmet. Luckily, they just got caught in the straps when I pulled the helmet off. (That time, I believe, I put them on AFTER I put the helmet on. Now, I always put them on first, then the helmet. No issues with them inadvertently getting pulled off. ) The Aeropex are so light that I don't even notice them when they're not playing any audio.
Likes For urbanOrange:
Liked 10,646 Times
Told that one to my wife/ stoker IMMEDIATELY.
Liked 2,086 Times
Liked 10,646 Times
The only Garmin computer I have is a watch, so it's always powered on and connected to the phone. But the feature set is close to an Edge, not identical. This must just be something you get and I don't.
