Lacing a 36 hole hub...!
I've seen a lacing pattern called "crow''s foot." It looks retro and sharp.
Is it an appropriate pattern for a 36 hole hub?
and...
Is it appropriate to have a 36 hole hub front and a 32 hole hub rear?
and...
being divisible by 4, and 3, 36 is fine to do what is groups of 6 instead of 4.
they're your wheels you don't have to apply to the Polit Bureau , for permission, Comrade.
Bikes: Bianchi Nuevo Alloro, Cannondale ST400, Fuji Palisade, GT Timberline FS, Raleigh Technium 420, Schwinn Moab, Schwinn Passage, Schwinn Tempo, Specialized Sirrus Elite (aluminum), Specialized Sirrus Triple (steel), Trek 7.6, Viner Road Record
Quoted: 15 Post(s)
Liked 65 Times
Generally, you want the larger number of spokes in the rear, unless you're a curbslammer.
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 704 Times
I built a 36-spoke wheel crows-foot style on an old Shimano high-flange hub, and it worked great. Then I noticed fractures on the flange on the radial spokes. Took it all apart, replaced the hub, and relaced it conventionally.
Jeff Wills
Jeff Wills
Are there strength characteristics to the "crow's foot" pattern?
I'm a vicarious "curbslammer" but am interested in the visual balance front and rear. The rear hub is a SA 2 spd.and I was mistaken when I said 32 rear in the earlier post. Front and rear will have 36h.
What I make of it is that 36h will work numerically and geometrically! The question becomes then is that pattern functional for 36h hubs?
I would not lace a 36-spoke wheel crow's foot style. 1/3 of the spokes will be radial, which is asking for trouble on a 36-hole hub. There's less material in the flange, which means it's weaker, which means the radial spokes are more likely to break the flange.
What is a "conventional pattern?"
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
"crow's foot" is more about style than practicality - especially for the rear. It will not be as strong torsionally as a conventional cross-3 or cross 2 pattern (having 1/3 of the spokes radial), and the twisting of the crossing spokes can introduce stresses that straight spokes do not encounter.
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Here's another:
32 is 8 sets of 4 each set = (1x radial, 1x trailing, 1x radial, 1x leading)
Here's a link to Wil's Wheels
HTH -
- Wil
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Where would I find and example of what the 3 cross FTW pattern looked like?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
S'Cruzer
Or, do you mean 'retro' in a steampunk kind of way, which is a retro that never existed ?
Bikes: 2000-something 3 speed commuter, 1990-something Raleigh Scorpion
3 leading/3 trailing looks good and can be laced using the same spokes as regular 3 cross. You just have to be careful when you're lacing it up to get the interlacing right between spokes, and to get the valve in a usable position.
the r & 1X combo looks crowded at the crossing point, maybe 2X with the r one in between better ..
Just, as said before, watch the radial spoke for pre pull through the flange , stress cracking.
I dunno, to me retro on bicycles means road bikes from 1960s/70s, and cruisers/3-speeds from the 40s/50s, and I sure never saw any crowsfoot/radial/etc stuff back then. 36H 3X or 4X, maybe 40H rear on a tandem or touring bike, that was about as extreme as it got. radial was used on old penny farthings, I don't think they'd figured out crosswise spoking yet.
...sort of a steampunk kind of way but in a more industrial/modern steampunk!
Seriously though I do appreciate the divergent thoughts on wheel lacing. I learning a whole new vocabulary. My first reaction is to form and then function! Being a visual kind of guy, it has look good AND function good!
Thanks for the indulgence!
