retro gravel bike 1x11 - do I need a chain guide?
Quoted: 46 Post(s)
I finally figured out all my components, and now am wondering if I need a chain guide?
Thanks
Thanks
mosquito rancher
Maybe?
There are a few ways to lower the odds of chain drop. A chain guide is one. The others are a narrow-wide chainring and a clutched rear derailleur. The current generation of SRAM Red and Force derailleurs have a fluidic clutch-equivalent; Shimano makes a version of the Ultegra derailleur with a clutch, and I believe all their GRX derailleurs have clutches. There are lots of 1× bikes that don't have chain guides, which seems to indicate you can do without.
Adam Rice
Adam Rice
Quoted: 1438 Post(s)
Liked 1,092 Times
Maybe?
Quoted: 46 Post(s)
My crank will be a Sram Rival 1 42t and rear cassette Shimano 105 R7000 CS-HG700-11 11-34T and rear derailleur is SHIMANO Shadow RD-R7000 105 11 Speed.
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
Yes, adamrice is correct. If you're using a narrow-wide chainring and a clutch-type rear derailleur, you don't need a chain guide. I converted my home built gravel/crappy weather commuter bike to a 1x set up last year, and so far it's performed flawlessly. The frame I built is steel and very similar to most vintage bike frames. I made a Youtube video on all the parts I used to convert the bike that might be useful to someone looking for ways to do a durable, inexpensive 1x conversion.
Totally agree with adamrice and Le Mechanic - I did a Ritchey Breakaway Cross with a SRAM Force 1 1x11 - it's one of the smoothest, trouble-free setups I've got in the stable. For all the trips the bike has literally needed zero fiddling in the past year. I'm a big fan of this setup.
Half way there
Quoted: 990 Post(s)
Liked 884 Times
I'm using a narrow-wide chainring and clutch DR on my 1x10 and have had no chain drop issues. I have another bike set up as a 1 x 11 with narrow-wide ring and just a road DR. Although I consider it more of a road bike, I have run it for many miles on unpaved trails that were a bit rough in some places. Still no chain drops since I installed the narrow-wide.
If you haven't already bought the 105 derailleur, I'd get a GRX derailleur instead for the clutch.
