Will a Shimano 10sp RD work on a 9sp system?
Quoted: 6963 Post(s)
Liked 10,963 Times
Thread title is the whole question. Rest of drivetrain is 9sp: shifters, cassette, etc.
Quoted: 350 Post(s)
Liked 122 Times
Tiagra road 4700 10 speed would not work with 9 speed since it uses the same cable pull ratio as 11 speed road.
From what I've seen on the threads, the other road 10 speeds, like 105 series, could work with road 9 speed, but someone else should be able to tell you. You can also find the answer if you do a quick Google search.
Likes For tomtomtom123:
Quoted: 2026 Post(s)
Liked 1,096 Times
Yes, all Shimano 10-speed road rear derailleurs, with the exception of the Tiagra 4700 10-speed noted above, will work with 9-speed (or 8 or 7-speed too) drivetrains. Shimano 10-speed MTB rear derailleurs will not work.
Liked 10,963 Times
Thanks to both of you - I will go ahead with this project now.
