degree of incline
Quoted: 19 Post(s)
Liked 24 Times
degree of incline
I've seen a lot of posts in different threads where riders talk about hills and degree of incline. Other than seeing a road side sign indicating the degree of the hill, how does one know that the degree is? Is there a method? I know that a twenty degree hill would mean that for every hundred feet the road rises twenty feet. I'm not saying that the knowledge of the degree will make it any easier to climb the hill, I am just curious. My ratings of hills goes from "this isn't too bad" to "OMG, why did I pick this road?"
Likes For spelger:
Quoted: 2495 Post(s)
Liked 739 Times
Quoted: 6196 Post(s)
Liked 4,810 Times
Grade just sounds better and gives us a larger number to deal with for our egos!
A 10% grade that makes us struggle climbing is only 5.7°. Even a 20% grade that we feel gives us bragging rights is only 11.3° <grin>
The formulas for various ways to figure slope/grade by percentage or degrees are here......
https://www.engineeringtoolbox.com/s...de-d_1562.html
There is a calculator you can plug in rise and run 1 or 2 clicks scrolling down. And a angular representation that shows what it looks like with the degrees and percentage shown below it.
There is a table a little further below the calculator that you can download and print out if it helps you for whatever you are doing.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
It’s a big world, so I guess it’s possible somewhere. Where was this?
Likes For terrymorse:
Quoted: 19 Post(s)
Liked 24 Times
That may well be true, however I have (and the o.p. too, obviously) seen inclines expressed in degrees. The o.p. question is not wrong, degrees are a valid way of expressing incline. I've never been that interested in the details but I just found this with not that much time invested.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times
20° slope is 36.4 feet rise over 100 foot run. 20% slope is 11.31°
Sir Mark, Knight of Sufferlandria
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
Likes For spelger:
Quoted: 4414 Post(s)
Liked 4,867 Times
My Garmin tells me what the slope gradient is in real time. If I have a route loaded it also has any significant climbs listed with gradients and length etc.
Likes For PeteHski:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Roads are listed in percent grade because they are designed by engineers who are looking at flat maps with gradient lines on them, and the lines were mapped by surveyors. So they measure a length, and then they subtract the lower elevation line from the higher elevation line and get a percent grade. Also road construction manuals list maximum gradients for different types of roads, and those manuals are also written by engineers. Nobody is out there using protractors.
Most GPS computers will have a screen that shows current grade, but I think they use data rather than calculations. And if there's a Strava segment on your ride you can check it out there:
Here are some guidelines:
5% = maximum grade for an ADA bridge.
10% = a good climber can stay in the saddle
15% = a good climber can do it out of the saddle
20% = only the strongest climbers will be able to do it at all
25% = ridiculous grade used for exhibitions and contests
30% = almost nobody will make it up
Likes For DiabloScott:
Yes always percentage never degrees for cycling or roads and trails in general. For rivers and streams ww paddlers use feet per mile or meters per kilometer as the usual measure.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
5% = stay in the saddle
10% = knees will be happier if I stand
15% = couldn’t stay in the saddle if I tried
over 15% = this is a good time for a walk.
Otto
climber has-been
Liked 3,567 Times
I did some steep but short climbs yesterday where Garmin displayed 15%, and up to 20% in short bits. Wanting to work my legs, I stayed in the saddle while doing a tempo power, but my cadence dropped to 50 much of the time. It wasn't that difficult aerobically, but my legs were much happier when the grade fell to "only" 11%.
A little steep segment from yesterday:
- distance: 0.14 mi
- av. grade: 14.6%
- av. speed: 5.0 mph
- av. cadence: 50
- av. power: 3.72 W/kg
Liked 4,867 Times
A single speed? Yikes! I can't imagine doing double digit climbs on a single speed. My low gear is 34/28, and it's just about right for me on steep grades.
- distance: 0.14 mi
- av. grade: 14.6%
- av. cadence: 50
Likes For PeteHski:
climber has-been
Liked 3,567 Times
Safe to say there's no chance of that happening. Not without some amazing medical breakthroughs (which I might consider).
Quoted: 896 Post(s)
Liked 2,065 Times
Best to not use degrees, lest we really feel like wimps.
One might think a 20% grade is approaching 45 degrees, but it's a pedestrian sounding 11.3 degrees.
We are gravity challenged.
Likes For downtube42:
Quoted: 1829 Post(s)
Liked 3,376 Times
For instance, this indicates about a 9% grade....
The best measurements are achieved when stopped, but you can get decent readings when riding too.
Steve in Peoria
Likes For steelbikeguy:
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
As to how we know, many if not most of us have a device on the bike which measures distance and elevation, does the math, and shows the percent of a climb on the screen as we ride up it. There are also occasional road signs which show percent, usually for the benefit of truckers on long descents.
On the other hand, backcountry skiers express slope angle in degrees to get some idea as to avalanche possibility. And we do carry little gadgets to measure slope angle.
Results matter
Results matter
Liked 1,938 Times
We have a 26X40 on our tandem and I use a 26X30 on my single now. Back in the day when I could really ride, it was a 30X25 .
Results matter
Results matter
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 303 Post(s)
Liked 136 Times
I use ridewithgps to map out rides as do most of the ride leaders in my area (bike club discount) and have found it universally
understates slopes. On hills I know to be 10-12% ridewithgps never finds more than 6%. The overall elevation changes
are generally pretty close to others like Garmins, Wahoos and cell phone apps but the inclines are not.
My phone says my driveway is 24%, I can ride up it ok in 32/34 gearing, but it is only 30 yds or so.
climber has-been
Liked 3,567 Times
I don’t think the Avocet displayed grade. The early Garmin units didn’t. I used to do math in my head to get a rough idea of the grade, and the rate of ascent (VAM). Having these on the display is quite the luxury.
