Anyone else have a rear derailer hanger fail this weekend?
So yeah that happened. Rear derailer hanger broke, not sure how. So, have to figure out what the next step is.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Most non-steel frames have replaceable hangers. Can't tell on yours.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6768 Post(s)
Liked 5,482 Times
Dayum! That's ugly!
I've been on replaceable hangers for around 6 years now and never had a problem.
Bent up a few steel ones...
Artificial Member
Liked 5,482 Times
My theory is your RD rear housing somehow got caught by a cog.
Super Moderator
Liked 927 Times
Did you mean spoke ? That's the most common cause. Doesn't take much mis-adjustment to happen.
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times
Looks to me like he shifted over the top of the cassette, dropping the chain between the largest cog and the spokes, at enough speed to whip the RD around and lock up the rear wheel. E: see how far out his low limit is?
OP: the good news is that the replaceable hanger sacrificed itself like it was supposed to- saving your frame. Amazingly your wheel looks fine. A new hanger, an RD and a cable and rear housing and you should be good to go. might want to have a shop take a look anyway and see that your frame is still in alignment. You can check as well, is the wheel still centered between the stays (both pairs?)?
Artificial Member
Liked 5,482 Times
But IthaDan's theory sounds pretty good.
pan y agua
Quoted: 1450 Post(s)
Liked 730 Times
You could get lost and die.
You could hit a tree and die.
Descends like a rock
Older I get, faster I was
That would be last week for me. Broke a spoke, then the hanger broke as the drive train got sucked up into the wheel and the wheel locked.
I was not shifting at the time. Just riding up a slight incline in the saddle. The bottom picture is the rear housing after being chewed up a bit. They are jagwire housings. It protected the cable as it was undamaged somehow.
How often should the hangers be replaced?
Bikes: Wizard, Eisentraut, Paramount, Litton, Turner, Surley, Trek, Kona, Landshark, Hujsak, Masi, Tesch, Holland, Retrotec, Spectrum
Quoted: 37 Post(s)
How often? Never......unless something is messed up with tuning of the drivetrain.
Bikes: Klein
Go to the 50+ forum and look for this thread. Read to the bottom about soft derailleur hangers.
https://www.bikeforums.net/showthread...Cervelo-Update
