Legality of colored bike headlights?
Cycleway town
We are not allowed green headlights in Britain. Green means 'go' so it wouldn't be wise to fit one if you expect to find on-coming traffic!
White front, red rear, amber side but amber is also ok all around. Amber pedal reflectors are legal requirement. And in my opinion, a flashing amber light is safer than a red one because it represents a hazard beacon.
I don't see why green would be used for ground symbols.
Quoted: 1591 Post(s)
Liked 1,018 Times
It isn't really a headlight so I don't see that it would likely fall under existing law. But it would be a worthless accessory. As others have noted, if it's dark enough for a laser projection to be sufficiently visible standard lighting will be more than ample. Being visible at night is only an issue when there is ambient light and laser light doesn't show up well in those conditions.
The reason why you don't see a row or bar of lights across the front of cars is because federal laws also prohibit any additional type/color/intensity of lights except those already approved. I don't think the laser is visible except for its projection on the ground.
Palmer
Quoted: 1668 Post(s)
Liked 1,821 Times
The kernel of the idea was to keep taxis & buses from left hooking London cyclists:
and to keep pedestrians from stepping out in front of cyclists:
Sez Beryl: "The Transport Research Laboratory report showed that the Laserlight projection can help a cyclist achieve up to 97% visibility in the blind spot of vehicles when cycling in the dark."
"The projection is proven to make you up to 32% more visible* (*independent study by Transport Research Lab)."
They're currently soliciting on Kickstarter for investors/backers for another, cheaper 'improved' model.
I shudder to think what the fussy-about-bike-lights Germans would do if you rode through Stuttgart at night with one of these!
The Vienna International Convention on Road Traffic, Chapter V "CONDITIONS FOR THE ADMISSION OF CYCLES AND MOPEDS TO INTERNATIONAL TRAFFIC", ARTICLE 44, offers:
1. Cycles without an engine in international traffic shall:
(a) Have an efficient brake;
(b) Be equipped with a bell capable of being heard at a sufficient distance, and carry no other audible warning device;
(c) Be equipped with a red reflecting device at the rear and with devices such that the cycle can show a white or selective-yellow light to the front and a red light to the rear.
Hmph, that says what you have to have in the way of lights and reflectors. I don't see an prohibition on having something additional. That phrase about 'white or selective-yellow', though...
Bedtime story: Once, long ago before you were born, we didn't know how to make white LEDs! Shocking, but true. The first 'Front Safety LED Lights' for bicycles were bluish or greenish. I still have a first generation Cateye front safety light that glows green. FWIW, nobody never said nothin'.
Palmer
Liked 1,821 Times
Someone said that in the UK it's okay, but not in the US.
I believe bicycle headlights are regulated by the states, so you would have to search the regulations by state.
Sec. 547.002. APPLICABILITY. Unless a provision is specifically made applicable, this chapter and the rules of the department adopted under this chapter do not apply to...
(5) a bicycle, a bicyclist, or bicycle equipment
Specific bike law requires a white headlamp and either a red reflector or red tail lamp for operation @ night, but there are no other requirements or restrictions.
There are federal and state restrictions on the (mis)use of laser pointers, but these bicycle lights don't meet those definitions.
Quoted: 5 Post(s)
This is from Pennsylvania's bicycle manual. Colors are specified.
Section 3507. Lamps or other equipment on pedalcycles. (a) Lamps and reflectors.—Every pedalcycle when in use between sunset and sunrise shall be equipped on the front with a lamp which emits a beam of white light intended to illuminate the pedalcycle operator's path and visible from a distance of at least 500 feet to the front, a red reflector facing to the rear which shall be visible at least 500 feet to the rear, and an amber reflector on each side. Operators of pedalcycles may supplement the required front lamp with a white flashing lamp, light-emitting diode or similar device to enhance their visibility to other traffic and with a lamp emitting a red flashing lamp, light-emitting diode or similar device visible from a distance of 500 feet to the rear. A lamp or lamps worn by the operator of a pedalcycle shall comply with the requirements of this subsection if the lamp or lamps can be seen at the distances specified.
Quoted: 7348 Post(s)
Liked 2,470 Times
So in PA, you must have a white light, but if you have another light of another color, the law doesn't mention it. It sounds like it will be OK.
