Making Rims Reflective: Alternative to Limited Selection Reflective Tires
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
75% of my riding occurs after sundown, and it's the reason all my bikes are equipped with reflective tires. The reflective tires immediately signal "BIKE" to the brains of persons driving automobiles, far better than anything else reflective, according to subjective experience AND research.
Dilemma: a friend just handed me a pair of Clement Xplor tires and they have been exactly what the doctor ordered! I like them better than my heavy, reflective Schwalbe Marathons. Unfortunately, they're standard black and not reflective.
Is there any company out there producing reflective materials for rims?
I have found these forums to be a much better use of time v.s. multiple Google searches. Thanks in advance!
junior
Bikes: 2020 Surly ECR / 2018 Norco Search XR steel gravel bike with GRX / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's)
Quoted: 72 Post(s)
Liked 12 Times
Do you have disc brakes? There are stickers, black stickers, that you can apply to your rims that are reflective at night. this is just one example. obviously would not work on the rim's sidewall if you have rim brakes
https://a.co/d/iMYYPZE
eric/fresno, ca.
eric/fresno, ca.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Oralite reflective conspicuity tape.
https://www.orafol.com/rs/americas/en/frontpage
https://www.hhsignsupply.com/product...Vinyl-c753.htm
I have used it on all my wheels. Video below.
@michaelm101, PM me your address and I'll send you an 8x10 sheet of the stuff, probably enough to do several sets of wheels as shown below. Or you can order it by the foot at H&H Sign Supply linked above.
-Tim
-Tim
Quoted: 1074 Post(s)
Liked 295 Times
Check out Albedo 100 reflective spray:https://www.albedo100.se/
Quoted: 225 Post(s)
Liked 39 Times
Quoted: 3459 Post(s)
Liked 1,465 Times
I know someone that put some form of reflective material on his spokes. Google - reflective bicycle spokes price - and see what you think.
I bought some wheel reflectors several years ago, they were not very reflective at all. So, that I am not recommending.
patches of reflective tape, if not using rim brakes, they can wrap over that.
Decades ago I brought back from NL, a ring of reflective plastic tubing,
with a steel wire through it ..
it interlaced through the spokes of the wheel , so above the rim
and so not getting darkened by road and rim brake smunge,
like sidewall reflective bands do..
... unless you keep cleaning the sides of the tires...
75% of my riding occurs after sundown, and it's the reason all my bikes are equipped with reflective tires. The reflective tires immediately signal "BIKE" to the brains of persons driving automobiles, far better than anything else reflective, according to subjective experience AND research...
https://www.bikeforums.net/2559821-post15.html
Some taillights emit light to the sides in addition to rear. You could mount tailights directed to each side, which may be more conspicuous/safer than reflective tires or fenders.
Why not just get the Schwalbe tires you need?
Nearly all current models are reflective.
schwalbe.com/en/start.html
Quoted: 225 Post(s)
Liked 39 Times
If you can fit full fenders to bike, they make an excellent surface for the application of retroreflective sheeting like 3M Scotchlite. Fenders offer perhaps 10X more reflective area than the little shiny strips on some tires, reflect ~180 degrees from left, rearwards and to the right and keep road debris off your clothing, bags, bike and drivetrain.
Quoted: 225 Post(s)
Liked 39 Times
I put a couple patches of 3M 680 reflective tape on my rims and crankarms. I've had drivers and other cyclists comment on how recognizable I was (as a cyclist) from a distance. I use a mix of white, red, and black reflective tape, depending on where it's going.
On the rims, I put 4 patches evenly spaced around. They're roughly 1" x 2" each. They extend from the bottom of the brake surface around the 'V' to the bottom of the other brake surface.
On crankarms, I use a strip roughly 3/4" x 4" on the front and back of the crankarm. In my experience, this provides comparable visibility to reflective leg bands, but it maintains its reflective properties when wet.
Quoted: 225 Post(s)
Liked 39 Times
This is what you're talking about, I think. These
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
I used Lightweights on my spokes and frame, I like it a lot and they have lasted through harsh commuting conditions.
Additionally, I like the Cateye spoke light
Quoted: 4806 Post(s)
Liked 3,928 Times
A really simple reflective approach is to take short pieces of tape and wrap them around two adjacent spokes. So with a 32 spoke wheel, you can have 16 pieces of tape. I"ve seen it down. Works really well and is cheap.
Ben
Ben
My spoke lights provide amazing night visibility of my bicycle.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
We use 3M spoke reflectors, such as , on all our bikes. They work great but over time get dirty. On a frequently used bike they need to be taken off and washed maybe once a year. Reflective tires still make it better, but become less critical. To note is that the reflectors come in different lengths and under different brand names. As a reference in Europe a set may cost few euros.
Quoted: 225 Post(s)
Liked 39 Times
VERDICT: I'm selling the French Clement Xplors and going German! Schwalbe or Contis with reflective sidewalls! I have them on my other bikes and wheelsets and they truly stand out and make a difference...
Quoted: 14 Post(s)
I've got a Monkey Light on my commute bike, and honestly, every time I've used it, if I pass a pedestrian they smile and wave, and I've had drivers pull up to me and tell me how much they enjoy the lights. The only problem, I guess, would be if I they got so entranced that they ran into me...
Quoted: 7348 Post(s)
Liked 2,465 Times
Reflective material is just not as reliable as lights are. The angle has to be right, and often, it is not. It's so easy to put a Nite Ize Spokelit in one of your wheels. You can be sure people will see it, and I would not worry that it will anger people.
You could use two or more, of course. I use one in my rear wheel only because it distracts me in the front wheel.
