Chain drops between rings when downshifting
Quoted: 7348 Post(s)
Liked 2,473 Times
This is my wife and my Burley Zydeco tandem. It came with a 3x7 drivetrain. I replaced the rear hub, cassette, chain, rear shifter, and rear derailleur to 11-speed. I kept the crankset, front derailleur, and shifter. Since then, the chain has a tendency to drop between the big and middle chainrings when shifting down to the middle. The spacing does seem wide.
I could replace the crankset, but I would rather not, as it would be expensive.
One idea is to machine down the surface that the big chainring is on, bringing it closer to the middle ring.
Another is to build ramps on the big chainring somehow, to guide the chain down. I'm not sure how, but I'm picturing machine screws.
Having the chain hang up and hold the drivetrain still on a tandem is a lot worse than on a single bike. I really need to solve it.
Tips and insights will be appreciated.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I got into a big fight about this on the tandem sub awhile ago. Basically I was told I was wrong & that I was a dumb idiot because it should work, so I "must be doing it wrong."
The only solution I found at the time was to sub in a Sugino 10 speed triple. It's been great ever since. On another unrelated note: That frame is retired now. Cracked from long life & many miles.
Sorry.
Sorry.
Likes For base2:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I'm surprised an 11 speed chain would even fit on 7 speed chainrings. Given that the 11 speed chain does fit on a 7 speed chainring, maybe something like a Shimano Deore 10 speed triple crankset (48-36-26) would work. The aesthetics would be off a fit, but it wouldn't be very expensive.
You could get a more aesthetically fitting retro looking 3x10 crankset for more money.
Liked 2,473 Times
Thanks, @base2. I'm pretty good at finagling front derailleurs, but I haven't solved this yet. I change the angle. I bend the cage in various ways. But the spacing between rings looks too great.
I like using my bench grinder, but I'm not sure I can get sufficient accuracy for this job.
I just substituted the big ring which was 48t with a ring with 54t. The problem is no better or worse, so I'll keep trying with the 54t. We need a higher top gear.
made worse because you could not see it being under the stoker with the captain shifting the lever?
perhaps this is where 11 speed cranks benefit closed up the gap between chainrings..
- machine the spider thinner between the chainrings ?
- drill and put some anti jam pins just under the teeth of the middle chainring?/ so it can be shifted out?
- bolt the 2 chainrings together there and so pulling them together tighter..
Quoted: 3813 Post(s)
Liked 3,344 Times
prior to thinning the lands i would check the lateral tooth edge to tooth edge distance between the chainwheels of the chainset and compare this with others you own
i know it sounds wacky but there have been chainsets produced with intentionally overthick lands/spacers so that a rider could run the "X" combination on a two plateau drivetrain without the chain rubbing on the inner face of the outer chainwheel
one such was the Sakae Ringyo Silstar of the late '60's and early '70's era even using a full width 3/32" chain one could experience wedging of the chain between chainwheels
it would be much cheaper to test fit a different drive chain than to replace the chainset...
Quoted: 2026 Post(s)
Liked 1,096 Times
This type of problem surfaced when 9-speed, with its significantly narrower chain, came out and riders wanted to keep their 8-speed or fewer speed cranks. As an expedient Shimano recommended shifting while sitting down which, of course, reduced the tension on the chain.
You've have a real extreme since you are using the narrowest chain available with a really wide spaced crank so I'm not at all surprised the chain wants to wedge into the chainring gap.
There are really two fixes; 1) a newer crank or 2) thin down the spider arms to reduce the chainring spacing. A 10-speed crank should be fine and a new one doesn't have to be that expensive.
Old fart
Quoted: 3589 Post(s)
Liked 3,400 Times
Your crank is spaced for a 7-speed chain width so the 11-speed chain is narrow enough to fall between the rings. You may need to replace the crank with a newer model with narrower spacing between the rings, or carefully file the ring mounting tabs on the crank so they're thin enough to catch the narrow 11-speed chain without letting it jam between the rings. Or you could revert to a 7-speed cluster on the rear wheel and run 7-speed chain on the current crank.
Really Old Senior Member
- Chain Width-
- 6 speed – 7.8 mm (5⁄16 in) (all brands)
- 7 speed – 7.3 mm (9⁄32 in) (Shimano HG), 7.1 mm (9⁄32 in) (SRAM, Shimano IG)
- 8 speed – 7.3 mm (9⁄32 in) (Shimano HG), 7.1 mm (9⁄32 in) (SRAM, Shimano IG)
- 9 speed – 6.6 to 6.8 mm (1⁄4 to 9⁄32 in) (all brands)
- 10 speed – 6.2 mm (1⁄4 in) (Shimano, Campagnolo)
- 10 speed (Narrow) – 5.88 mm (7⁄32 in) (Campagnolo, KMC)
- 10 speed (Narrow, Direction) – 5.88 mm (7⁄32 in) (Shimano CN-5700, CN-6700, CN-7900)
- 11 speed – 5.5 mm (7⁄32 in) (Campagnolo, KMC, Shimano CN-9000)
- 12 speed - 5.25 mm (7⁄32 in) (SRAM)
Liked 2,975 Times
separate the 3 rings & slide in a spacer using the next size smaller/larger tooth ring to the drive ring being used, just with the teeth ground off.
IE:
If yours is this: 26-36-48
It would end up like this:
26---32grounddown---36---42grounddown---48
IE:
-Oh Hey!
-Oh Hey!
Where do you source a 5 speed shifter?
Getting the FDER to span 5 rings may be a little problematic too.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
That big chainring looks like it's from the 6-speed era. Going back in time certainly isn't going to help.
New and used 10-speed triple cranks can be had fairly cheap nowadays. You know it's the right solution to this problem...
Didnt read the other answers, but if the chain drops between the rings, its too narrow for the crank. Imo, you should bite the bullet and get an other crank. Im sure you can find something used that is not too pricey. Like a Tiagra or Deore tripple, depending what gearing you like.
Liked 2,975 Times
ADDING additional spacing is going to exacerbate the problem unless "something" is machined away.
A proper width crank is the SIMPLE answer.
Liked 2,473 Times
OK thanks. I see the crankset is really the best solution.
The bike has MTB 26" wheels. It's a tandem, which means we need a very low bottom gear and a very high top gear. Well, I'll admit that "need" is more like "want" when referring to a top gear, but it's extremely easy to spin out in a 113" gear (48/11x26) on the flats. So looking at cranksets, I see the big chainring is very small in the current trends. Many have a 42T large chainring. That makes sense on single bikes but not tandems.
Also, cranks are getting long. My wife is about 5'4" (162cm) tall, and I would not subject her to cranks longer than 170mm. Even I can't stand cranks longer than that, and I'm 5'9" (175cm) tall.
Furthermore, most newer cranks don't use square taper spindles, so I'd need a new BB.
So it take some searching.
I'm not going to undo the upgrade I did in the rear. Not only do I really want the wider range and the closer spacing, but the rear derailleur and shifter are absolute champs. And I had to buy a new hub and rebuild the wheel to get it all together.
I might try another front derailleur, which is not likely to help, but ya nevah know.
One thing I like is that the front shifter is friction based with no click stops. I think indexed front derailleurs are a misguided idea.
Liked 2,473 Times
For the time being, my wife has asked me not to risk that shift, which limits our gear range.
I just got a wacky idea. How about putting the big ring in the middle position and then just having two rings? They would be 28 and 54. The front derailleur might or might not be able to make such big shifts.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
I’ve had similar problems except not where the chain jammed. I have always been able to spin the crank and redo the shift. On the tandem it would happen on, I think the middle ring was a bit warped. Are your rings true? That crank was not mismatched. I’ve run 9 and 10 speed chains on “5” speed cranks with only very rare failure of teeth to engage (again, just spinning w/o jamming) but these were on singles and much easier to tolerate than on a tandem. Just wondering if switching to 9 speed cassette and chain may work better? But before trying that I would try a different front derailleur with a flat outer plate. It looks like yours has a bump out at the lower end of the cage and I’m wondering if that is limiting the push on the chain inwards as the chain is falling? I guess that wouldn’t eliminate the risk of jamming but with care may make it avoidable.
Liked 2,473 Times
Great stuff, @L134. Thank you! You've reinforced my idea of trying another FD. I have several in my bins, and it's not hard, much easier than changing chain and cassette. Well, then again, I have some spare 9-speed cassettes.
Blamester
It's easy enough to experiment with the lands on the existing crank but going by the chain thickness guide a above you may have to remove too much.
Have the land thicknesses changed over time? Are they also narrower on modern cranks which would be a strange place to save material on a critical part.
I don't know but perhaps some modern 11 speed or 10 speed chainrings may work better if perhaps the lands are the same thickness but the rings shaped differently.
Now that's just me thinking I have no idea if that's true or not.
If somebody happens to have an old and a modern crank to compare they may be able to confirm.
Liked 1,096 Times
You might look for a 10-speed road triple crank. Shimano's HTII 10-speed 105-level FC-5703 crank came OEM as 50/39/30 but had a separate 74 mm BCD for the granny chainring so you could exchange the 30T for as small as 24T. I have these cranks on a couple of bikes set up as 50/39/26 and they work extremely well. They are out of production but should be available NOS with some searching.
First Tiagra 10-speed cranks triple cranks, FC-4603, also came 50/39/30 but the granny was bolted to the middle chainring with a 92 mm BCD so 30T is as small as you can go. These are also out of production and available only NOS.
Liked 2,473 Times
Thanks, @HillRider. That makes sense. But I can't use a two-piece crank, as the stoker's left crank needs a chainring.
Maybe grinding down the spider makes sense. I might ruin it, but since I'm moving towards the replacement of the crank anyway, that's not a big loss.
Quoted: 303 Post(s)
Liked 136 Times
We had a similar problem with our tandem, a 10spd triple. I was able to machine down the width
of the mounting arm on the crank and that helped but it was a dicey thing gripping the crank in a
sufficiently rigid fashion and deciding how much to remove. I have a milling machine.
I have found that 11spd cassettes work fine with 10spd chains so you might consider that option.
IF your cassette has no single tooth steps between cogs, then a 9spd chain would probably work
as well. It might be a bit noisier. If you are up for several hours of fiddling an aluminum rated
file with the narrow side teeth removed (ground off) and very good technique would allow thinning
of the crank arms. Filing flat requires some practice, it is easy to rock a bit.
I considered fabing some ramps to mount on the big ring to guide the chain to the middle ring but
my seat on tandem was taken over by the pilots GF and I stopped riding it.
Liked 1,096 Times
Liked 2,975 Times
The rings added would retain as close to original spacing yet put in place a chain guide jam prevention device.
-Oh Hey!
-Oh Hey!
