Newbie: Need help finding a bike on a budget
Hello! As I’m sure you’ve gathered, I’m new to this whole thing. I’ve been reading around after a bout of frustration at the fact that biking is something I’ve wanted to do for years now only to find that it’s not the easiest thing to get started doing at my weight. That landed me here where my head is kind of spinning with all the new information.
As of right now, I’m 5’ 6” and around 400#. My goal is to use biking to help me lose weight as well as a recreational activity (especially with the social distancing!) I’ve read around a bit and been perusing Craigslist in an effort to find a good bike that will hold me for a decent price. I’m on a tight budget where $250 is pretty much the most I can spend. Initially, I was going to go for one of the more expensive Wal-Mart bikes, but my research deterred me from that.
Basically, I need help figuring out what bike to look for on a super tight budget (I know I’m not going to get anything new with my limit). I’d also appreciate any advice on sizing if possible, as there are no LBS’s open near me right now.
If the issue is to get out and get started. IMHO at your size/weight you might look for something along the lines of a Beach cruiser. With the beefier wheels and frame, along with a lower seating height with a nice comfortable seat it will at least get you out the door and rolling.
see if it works and look for a better bike after you’ve dropped a little weight.
Quoted: 2604 Post(s)
Liked 1,933 Times
I'd be looking at a rigid mountain bike (no shocks), in the appropriate size, at your weight. Watch your diet and ride that bike for a while.
Size? There's any number of fit calculators out there. Your inseam is probably more important that total height. Starting guess would be about 16" (bottom bracket to top of seat tube). Note that most beginners have their seat set too low; you want your knee only slightly bent when the pedal is at the bottom and you're sitting on the saddle.
Likes For pdlamb:
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
I will be honest. There are zero new bikes you can find on your budget of $250 that will hold you at 400 lbs. I would suggest an old mountain bike or hybrid at a small to medium size frame, or about 16" to 17.5" frame. Something like an old 90s era Trek 800. 820, 830 or 850, or 720 to 750, Specialized Rockhopper, Bianchi Advantage (I had one of these. fantastic bike and still ran great when I gave it away a few years ago), or equivalent from any of a dozen bike brands (Giant, Kona, Raleigh, GT, Cannondale, etc..). IT MUST BE A SOLID FORK. NO SUSPENSION FORKS, AS THESE WILL NEED REPAIR OR REPLACING WHICH YOU CANNOT AFFORD. You may or may not need to upgrade the wheels, but at a minimum, 36 spokes, or even better if higher spoke count. If you buy something like this privately, you will probably need to change out worn parts like chain, freewheel, brakes, tires, etc) so keep that in mind. So if you can find such a bike from a seller in ready to ride condition, it is worth spending a bit more than something that is right out of someone's garage or shed, and needs some work.
Quoted: 2338 Post(s)
Liked 2,827 Times
where are you located at.....if you give a general location or craigslist are people can give ideas of things that look good
are your going to be riding on streets only or ???
also are there any coops near you
I think you're going to have a difficult time meeting both your weight and price requirements, new or used. There are very few bikes available that can safely handle 400lbs without modification (probably less than 1% of the bikes on the market) so finding one will be difficult. Adding to that your price limit, compounds the difficulty. I searched Craigslist within 200 miles of me (the distance limit) and found none.
If you're interested in an adult trike there are many more possibilities and you may be more successful.
Having said all that, I commend you for your desire to ride and hope you're successful. If you find a bike and want some feedback, post specifics.
Liked 208 Times
Yes, I do, perhaps with the addition of a seat. If we accept the manufacturer weight limit as accurate, though, 400lbs is hard to come by. The other issue is cost and heavy duty rims are likely to cost at least $100 for the pair. Getting the bike and rims for $250 will be difficult, at least I think so. That's not to say it's not possible.
Likes For Tony P.:
Quoted: 529 Post(s)
Liked 255 Times
You want mountain bike tires, or fat bike tires. Narrow tires may squash all the way to the rim, and be damaged.
You will most likely want to buy a large seat. A small seat may be too uncomfortable.
At your height, many frames will be a good size.
If you are on a budget, I would suggest checking out second hand bikes, until you find a suitable one.
A fat bike like I have would be ideal for someone like you. You would just want to change the seat for a large one. I have seen fat bikes advertised second hand at cheap prices. Someone gets one as a gift, and doesn't like it, so they sell it cheap. My fat bike is really tough. I ride on rough tracks often, and the bike is about as close as you can get to unbreakable.
Liked 208 Times
Quoted: 529 Post(s)
Liked 255 Times
Racing bikes have small, light weight saddles. Many people think these are ideal, and get the same. Then they find they are uncomfortable, so they need padded pants. I think, if the average casual rider has a larger saddle, it will be comfortable, and padded pants are unnecessary.
There are large numbers of different individuals, who all have different experiences. They can all decide for themselves.
Liked 208 Times
Just making suggestions. The OP can decide what suits them.
Liked 2,827 Times
also a cheap bike whether new or used is a pain.. any bike that has recently been a "thing" like fat bikes are often going to have cheap used bikes that were cheap walmart/target etc bikes
many frame sizes is also not true there would be range in road bikes and in mountain bikes.. that would fit, but not many
I would suggest looking for and older specialized stumpjumper ro rockhopper (these were pretty common) at a 19 in frame size and as noted avoid shocks anything like that. if you are on roads only swap out knobby tires for smooth tires and your are set
Thank you all for the advice.
With regards to where I’ll be riding, I’ll be on paved trails and roads. Nothing super taxing on the bike terrain-wise. Keeping in mind that my tax return should be hitting soon, I’d be willing to up my price range to $400-$450. I’ll also be willing to up it significantly more once I know whether I’ll be receiving the stimulus check. The issue now is that I’m living on a teacher salary that just doesn’t let me toss $800-$1k on a bike regardless of how much I’m willing to commit to the sport.
I also live on the Indiana Illinois border. I know someone asked for Craigslist reasons.
Liked 2,827 Times
ok used terra haute craigs list as a base (big guess)
here are some examples
this is about as large as you should go $180
i really like this one as it has swept back bars which IMHO are more comfortable than pure mountain bike bars
https://indianapolis.craigslist.org/...102345435.html
cannondale
https://bloomington.craigslist.org/b...087236971.html
11111
1984 Schwinn High Sierra Mountain Bike - $240 (Downtown)
https://indianapolis.craigslist.org/...101908941.htmlcannondale
11111
I don't know if you have hills, but if your area is flat, this cruiser may be an option. Note that it is an older ad so it maybe gone.
https://indianapolis.craigslist.org/...092599653.html
I don't usually suggest these types of bikes, it's a lower end bike, but should be overbuilt. Just make sure the tires are properly inflated. I'd offer $40 on that one.
I also like this Rockhopper, but not sure the stem would work for you.
https://indianapolis.craigslist.org/...103566605.html
I just found a Trek Skye-Comfort/Hybrid on facebook marketplace for $225. Wheels are brand new (36). It looks almost brand new. Does this sound like it could fit the bill?
I believe the Skye has front suspension, which may not work well for you. It may be OK permanently locked out (if it has a lockout).
Liked 208 Times
2. It is a Women's bike.
Liked 208 Times
Going forward though, there is always the hope that as you lose weight, you will get the cycling bug and want to ride more. And should cycling become your thing, then get used to the prices of new bikes. $400 to $500 is really pretty entry level, $800 to $900 is still just a step above entry level. And the real sweet spot in terms of cost/quality/performance is probably closer to the $1,500 price point. Though that sounds like crazy money, hear me out for a minute or two. With cycling, most of your expenses are up front, with nothing but routine maintenance/repairs for the next 10 or 15 years after the initial purchase. Compare cycling to other activities such as classes where you have to pay for expensive monthly gym dues, or golf where you pay for expensive gear and monthly club fees, or skiing, where you have to pay for gear, plus lift tickets, lodging and transportation costs.
You can achieve your goals. When I was more active on the touring forum maybe a decade ago there was a guy who was overweight and lost over 100 lbs just cycling every day, over the course of about a year. At first he could barely ride around the block but he kept at it, got stronger and rode more and more. He posted regularly and it was an amazing story.
I agree with the other guys that a used mountain bike from the late 80's or early 90's with a rigid fork (no suspension) will do the trick. They can be found for $2-300, are steel and practically bombproof. Something like a Trek 850, 870, Rockhopper, etc. Spend half your budget on the bike and keep the other half in reserve for a tune-up, misc parts and a strong wheelset. I'd say $5-600 total.
Good luck Casek.
Good luck Casek.
Quoted: 529 Post(s)
Liked 255 Times
I have sometimes picked up decent women's bikes in the trash, and ridden them. If the bike does the job, I am not concerned what other people think. One even had surface rust on the frame. I liked that bike. Apart from being comfortable, it was a bike nobody would want to steal. A couple of women's bikes I rode for many months each, until I found a better bike in the trash. I know, not everybody is like me.
Quoted: 529 Post(s)
Liked 255 Times
I was looking on Amazon. There is a new 26 inch fat bike for sale for $379.99, with Shimano gear. You don't need to spend a lot of money.
This one was available. But they have a lot less models available than usual, with the current situation.
I’m deffinetly no expert and there’s a lot of knowledge here. But I can talk about my experience.
When started riding many years back I was 6’ 350lbs. I was concerned about bike choice and cost. Asking here raised my concerns about cost. But I went to the LBS and bought a very basic entry level bike a GIANT Bolder SE. It seemed comfy and sturdy but had a cheap non lockout suspension fork I was warned about. But I figured I can ride it till it wore out an replace with a better fork with a lock out when time comes.
Well in three years of riding and dieting I had lost 100lbs. And the bike was still functioning just fine.
un related to the bike I then got very injured (hit by car on my motorcycle) and was unable to return to cycling till this year (7 years later). But after a quick service I dragged that old mountain bike out with its cheap fork and am cycling as weather and pain levels permit since January.
Its not a great bike. It’s not pretty and it’s not glamours. I’m sure that forks screaming at me every ride. And I’m not doing massive mileage (never was). But I got out there relatively inexpensively, Turned some cranks, reached some goals, and most importantly had fun doing it.
I did buy a better bike over the years but the boulder se is still the bike that seems the most use. I still find it more comfy. And it just feels special to me for some reason. This year I intend to cycle as much as I can mostly for strength building and fun. And I know that old mountain bike though fun is probly due to be replaced or at the very least upgraded for any serious riding. But I suspect it will be in the garage first to the door for some time, just for puttering about around the neighborhood and with my daughter (she’s 3 and on a balance bike) for some time still.
Me at 350lbs
today I stand at 260lbs but shorter now thanks to injuries in said motorcycle accident.
My point is. Though what every one is saying is most deffinetly correct. The most important thing is to get out there. Even if the bikes not ideal. Find something your comfortable on and with financially and get out there and have some fun. You can always upgrade later as $$$ permits.
Me at 350lbs
