Snapped my chain, gouged my frame :(
Bikes: 2009 Specialized Tarmac Elite, 2001 CCM Heat
I was biking the other day when I encountered a 15% grade. So, I dialed it up and when I did I heard a snap, and then a sickening crunch. Luckily, I was able to clip out before hitting the ground. Not-so-luckily, I inspected my frame and saw that the chain, after being snapped seemed to have bunched up between the chainrings and downtube and cause some damage (pics at the end).
I took it to the LBS, and they said my frame was toast. They would look into the Specialized crash replacement program and notify me of the cost. I was wondering, what are my best options to take?
1. Check my insurance policy, see if bike damage is covered ($500 deductible).
2. Go with crash-replacement frame (est. $1000).
3. Get repaired by Calfee ($~300, + the rest of the riding season).
4. Buy cheap frame off eBay.
5. Talk to the chain manufacturer and take it up with them?
6. Anything else?
Any help in this matter would be very much appreciated! On the bright side, I'm cross-training more than I normally would .
6. Anything else?
Bikes: '06 Trek 1000, '09 Gary Fisher Supercaliber, '10 Trek XO2
Wow! Completely toast? Just looks like a chip to me, but I don't know much about CF fames. Kind of makes me leery about going CF for myself.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
5 will get you 10 the "taking it up with the chain mfg." is a fruitless endeavor. I would Calfee the thing.
Edit- My reasoning is simply the cost issue. $300 bucks is a lot easier to take than a grand, and 700 bones can go to your next frame in a year or so. Granted, the frame is tied up at Calfee, but I would rather just have the frame mended and move on.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Wow that sucks. Did you have like a ton of miles on the chain??
I would try the all options starting from the cheapest option. I would contact the chain manufacturer and see what they say. Good luck.
Lost
i doubt any insurance policy you have would cover a bike damaged riding.
i know calfee does some good work, but if it were me, i'd toss the frame and hunt for something new. that will get you back on the road the fastest.
that bike nut
Bikes: 2010 Motobecane Immortal Force 90' Trek 1400; 90' Trek 850; 06' Trek 520; 01 Iron Horse Victory
Quoted: 25 Post(s)
How common are 10 speed chains breaking? I keep hearing stories. I've never broken a chain before and don't carry a chain tool when I ride. However I ride mainly 9 speed. BTW do report this to Shimano. Could be a QC issue.
That sucks. I had something similar happen. I had some chain suck and it got lodged in my BB area. It only scratched the coating of the frame though, so it's nothing I'm worried about.
Not at all! In fact I'm kind of ashamed to say I had less than 3500 km on that chain...
I also have a MTB, but yeah as far as road riding is concerned... I was also considering sending this to Calfee and buying a TT bike to hold me over until it's back lol.
I ride a 56 cm.
Dang, that's a close one! I wonder if a chain keeper would prevent all this headache...
snapped mine not too long ago, powering out a corner standing and the chain snapped on me, scratched the chain stay/seat stay drop out and the carbon around it. not where near as bad as your but it's still sucks balls.
Gimme back my gears!
Bikes: Cannondale Caad9-5 2009, Scattante XLR TT 2009, Trek Y-Foil 77 1998
I sh-- you not, but I have a deeper gouge out of the chain stay on my y-foil and I still trust that damn machine under my 215 pound body.
no idea, but I bought a used bike off eBay last year and the chain (campy 10spd, low end I'm guessing) broke on a flat section after less than 500 miles by me. I assume that there weren't that many total miles on it since my cranks and cassette are still smooth after replacing with a KMC chain that's held up for over 1000 miles. I always carry a chain breaker now and a couple missing links since my 6 mile walk home was no fun after that.
i wonder how many 10spd chain failures were caused by improper use. both shimano and campagnolo chains require special pins to connect them.
edit:
if you shove one of the peened pins back through the chain i could see it compromising the link in the above manner.
edit:
When that happened on my steel frame, i made repairs with a little bottle of nail polish. Dab-dab-dab, scratch filled, ride on.
Seriously, I'm sorry about the damage, but that's one of the main reasons I like steel.
Specialized may give you some help, but I'll be surprised of the chain people do anything. They'd be admitting liabiity, which isn't about to happen.
Portland Fred
However, you can also break a chain using poor technique . I've broken two chains, both on intense grades, and both because I didn't shift properly when going up. Unless the chain is defective, you won't be strong enough to break it -- otherwise it wouldn't survive a hard sprint.
Neither of my broken chains was 10 speed -- those were broken in the early 80's. I always carried a chain tool after that, and only recently stopped carrying one. The only two times I've not been able to finish my ride were due to destroyed wheels, and there's nothing you can do about that anyway.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
If and when I were to get a cf frame I think I would fabricate some stainless steel or aluminum guards and install them using 3M double side tape at critical locations that I have found in the past to be damage prone--like the one in your pic. I would fab the guards to follow the contours and to appear as if factory installed. I might also wrap the right chain stay in an old tube. CF is strong but not tolerant of damage, particularly impact damage or anything that gouges/cuts fibers. A cut fiber is a dead fiber and it cannot be repaired and it DOES affect strength.
Yeah, a steel frame, clean up the scratch, some touch up paint, get back on the road good as new.
that bike nut
Quoted: 25 Post(s)
I am considering getting a CF bike and was wondering if there is something you can put over the Chainstay to help protect it from the chain should it drop off.
Someone mentioned it but I would get a cheap aluminum frame and transfer components and send the frame to Calfee, then sell cheap AL frame when your frame is returned. Cheapest option while still riding over the next couple of months.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
same here. took off a patch of paint. i looked really carefully at the underlying carbon and it wasn't even scratched. i said 20 hail marys
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
