Need help with linear brakes
Quoted: 10 Post(s)
I have a Mongoose legde 6061N and I've been having issues with my back brakes for quite a while. Some time ago , I noticed that when I squeezed the back brakes, instead of springing back, the rear brake assembly kinda slowly eased back into place. I tried everything from replacing the pull cable to messing around with every possible tension combination. In the end I completely stripped off the rear brakes and it kind of sat there for like a month. Today I finally got around to trying to reassemble them and I noticed one thing. The left arm of the brake springs back correctly, but the right one moves back slowly to the starting position. I tired readjusting the spring tension but no go. What could be causing this? Is the spring faulty or is this something like too much grease? Do I have to find a whole new brake assembly or is there a simpler fix? Need answer ASAP
Quoted: 1439 Post(s)
Liked 1,094 Times
It is possible that the end of the mounting stud has gotten flared out by overtightening. It happened to me and a little judicious file work made it right. Does that brake arm slide/rotate smoothly along the stud or does it stick?
Quoted: 1572 Post(s)
Liked 644 Times
Mongoose says "low end components" to me.
My experience has been that you can struggle with that brake (Pro-Max?) and get it to function for a period of time. It's so much easier and not much more money to simply replace it with a medium priced Shimano V-brake. That's what I would do.
Take every thing apart, take the brakes apart, clean it, reassemble with a light coat of grease, install new cable and housing. I run into this problem weekly, dirty old grease is usually the problem.
Quoted: 10 Post(s)
The mounting stud is fine, the arm rotates freely. I think it's the arm itself
Quoted: 10 Post(s)
The brake does seem a little grease clogged, but I have no idea how to take it apart. I'm not completely new to bike repair, I just can't figure how to take apart the spring assembly
Quoted: 10 Post(s)
Liked 644 Times
The good news is that they'll all fit. If it was me, I'd buy the second cheapest. That'll still be loads better than a ProMax brake.
Quoted: 10 Post(s)
[QUOTE=Retro Grouch;19968553
The good news is that they'll all fit. If it was me, I'd buy the second cheapest. That'll still be loads better than a ProMax brake.[/QUOTE]
Is Amazon my friend on this one?
Quoted: 10 Post(s)
For brakes ive settled for shimano BR-T4000 from amazon.
And while I'm at it does anyone have any suggestions for a rear derailleur. The one that's currently on the bike is bent and wasn't all that great to start with. I'm looking at something shimano from $15 to $30
Edit: I'm looking for a 7 speed derailleur with a hanger, no direct mount.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 766 Times
Those T4000 brakes will be just fine. Assuming your bike has anywhere from 7 to 9 speeds in the back, an Altus M310 or an Acera M360 rear derailleur would work great. These can usually be found from $15-20. Both are available in both black and silver colors. Might as well coordinate with your new brakes, right?
Quoted: 10 Post(s)
Quoted: 10 Post(s)
My bike came with a Shimano Rd-tz 31 7speed Hub Bolt Mount Rear Derailleur that was attached directly to the hub. How would I attach a Shimano Acera to that. I'll attach an image in the next post as I don't have 10 posts yet
Liked 644 Times
Honestly, I've probably adjusted more Tourneys than any other single rear derailleur model. You aren't going to get any style points but I've found them to be perfectly functional. 7-speed simply doesn't require the precision of 9+. What are you using for a shifter? Tourney's work better with lower end shifters because they have a little "fuzzy logic" built into the indexing.
Quoted: 10 Post(s)
Probably a Tourney.
Quoted: 10 Post(s)
And one more question. My current derailleur is attached directly to the hub bolt. How would I go around attaching a different derailleur?
