Aero bikes for “average” rider - any real advantage?
#102
And you're saying that with the exact same wattage, give or take a watt or two, you were producing the exact same speed, within less than say .05 mph? I really don't believe that. What bikes were used? And was it the same rider/kit? Exact same position on the bike?
#103
Using a regression analysis or virtual elevation, it isn't necessary to reproduce the same speed or wattage.
#105
Quoted: 18883 Post(s)
Liked 10,646 Times
That's impressive.
#107
Really? Blather 'bout Bikes: Aero Field Testing using the "Chung Method" - How sensitive can it be? Since we seem to be referencing Tom's blog here.
#108
Dean V didn't claim that it was that close. He said that it was a lot closer to 3W than 20W. .05mph at 20mph would tend to be on the order of 2-ish watts.
#111
What Dean V claimed is that it was closer to 3W than 20W, and that he could easily detect anything bigger than 10W. While he may have determined a value, he didn't explicitly claim this; the only thing he's claimed is an upper bound for the difference.
#112
Quoted: 1067 Post(s)
Liked 259 Times
Giant Propel 0.15 kph faster than Giant TCR. +/- 0.05 kph.
230w and 36kph.
2 water bottles. Same kit, helmet, position, wheels etc.
The test was hardly the ultimate in accuracy but was good enough to give me a fair indication.
230w and 36kph.
#113
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
The upper bound would be 11.5 watts then? (if closer to 3 than 20).
I've seen claims of 6 watts, at nebulous speeds, well some higher that I discount to puffery but mostly in that range so I don't have a hard time believing Dean. I think that aero bike should include aero wheels though.
#115
Bikes: Nashbar Road
Liked 341 Times
But the same wheels on both bikes. Not saying that you didn't measure a difference between frames, just that aero frame with aero wheels would be an "aero bike" vs non-aero frame with non-aero wheels.
#116
Hrmm. It’s worth considering that perhaps the propel is a very slow aero bike. The cycling weekly video above tested the propel as 19 watts slower than the madone.
#118
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times
#119
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times
What we're really trying to determine is how small of a change in drag we can reliably detect. The Tom Compton Challenge tries to measure the change in aero drag, but a change in any version of drag should also work -- virtual elevation itself is a way to "translate" a difference in aero drag into a difference in elevation. So I've had luck in doing delta mass tests: a test where I compare runs with an empty water bottle and one filled with sand. The empty and full water bottles should have the same aero drag -- the only difference is in the total mass, so you should be able to see a difference in rolling resistance. Rolling resistance scales *exactly* like slope so virtual elevation works really really well for that.
#120
We went through this last month.
#121
Lol possibly . But it does seem you're actually trying to get real results from it, and not just throwing out random anecdotal thoughts on the internet. I'd be interrsted in what you measure the madone at if you do do it.
#124
Look, I'm not trying to be insulting. But I can promise you that whatever it is you're trying to do with your work, it's being lost on everyone here. You have to explain it. Nobody here, or at least the vast majority, do not have the technical background to decipher the dozens of pages of research article you keep linking and then not commenting on. Most are just too proud to say so
#125
But what you write is simply not true. For people who have read the explanation of virtual elevation and taken time to digest it, Robert has been very willing to enter into discussions. Just look at post 119.
