2017 CAAD12 disc frame opportunity
Quoted: 7652 Post(s)
Liked 3,473 Times
As a person who bought a couple frames and all the parts and built a couple bikes just to have the bikes I wanted, regardless of whether I spent a few dollars more or less ... I would naturally suggest you buy the frame and the parts you want and ride the bike you want.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
FYI, here's a 2017 CAAD12 105 Disc for $1,199.00.
https://www.trekbicyclesuperstore.co...5-278003-1.htm
edit: woman's. and only one size left at this price.
Bikes: Scott CR1 Pro, Eimei
Quoted: 59 Post(s)
My goal is an Ultegra-level build with discs. This config would sell for $2,600 as a complete bike, if Cannondale sold it here (they don't).
If the frame is $400, the groupset is $800, the bike shop wants $300 for labor (just a guess) and the cockpit is $300 (also a guess), I'm at $1,800 before wheels. Now I can go straight to decent wheels instead of the cheap ones that come on the complete bike.
Maybe I've spent a little more overall, but the whole thing is fully custom and the frame color is better. I also get discs on a CAAD which I can't get under this config. The only remaining consideration is not getting the Hollowgram crank, because it's too expensive.
If you can turn a screw you can do 80% of the work yourself. You only really need a professional to press bearings and glue tubulars. There are some specialty bike tools such as a good hex set and some torx bits for the odd stem maybe. Then you'll be under $2500 with great wheels. Also, get the big ticket items used and you'll be at a good place to spend more when the build calls for it.
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
So I have a question on the Ultegra groupset for the CAAD. The Internet retailer proposed a Wheels Manufacturing Eccentric BB to go with the Ultegra crankset. I think it's adapting a 24mm crankset to a 30mm BB.
I don't really understand what I'm dealing with here. Can someone explain what's an ideal setup for the crank and the BB? It doesn't have to be Shimano.
Liked 3,473 Times
I think Cannondale uses a proprietary BB standard--PF-30, i think.
The spindle 9the shaft sticking out of the right, drive-side crank) is 24 mm on a Shimano crank, 24 tapering to 22 on SRAM and FSA (if I recall,) and Cannondale is just stupid. Wheels Mfrg. makes all kinds of adapters and replacement BBs and threaded BBs to avoid press-fit for those who prefer more weight and reliability. I'd go to their site and check out what you need. I am pretty sure unless you use approved Cannondale cranks, you will need to replace or adapt the BB.
looks like thse would be the replacement BBs https://wheelsmfg.com/bottom-bracket...ano-black.html
https://wheelsmfg.com/bottom-bracket...ram-black.html https://wheelsmfg.com/bottom-bracket...ale-pf30a.html
As far as I can tell, the Eccentric BB is to convert to single-speed (https://wheelsmfg.com/bottom-bracket...nks-black.html)
I'd do an online chat with Wheels staff to sort things out.
Quoted: 562 Post(s)
Liked 64 Times
Does anyone make a BB that doesn't require an adapter?
Liked 3,473 Times
The first two I listedf don't need an adapter---they are the entire BB for a PF-30 shell but sized to take the slimmer SRAM or Shimano-standard cranks. None of the manufacturers that I know of make 30-mm cranks except whoever Cannondale owns---but if you want to use a Cannondale BB ....
Thing is this---if you want Ultegra, the Ultergra Hollowtech II BB only fits threaded frames, not press-ins. I believe you can get Shimano press-ft BB cups (I have never looked but I think I recall reading something in passing,) but in any case, you will need a BB, and it has to fit both the Cannondale frame's BB shell (designed around the bigger PF-30 BB) and the slimmer Shimano (or SRAM) crank spindle. You can google "Shimano press-fit bottom bracket" and see what comes up ... but as fasr as I know Wheels is one of the few that bridges the gap between Cannondale's useless proprietary BB and Shimano's excellent crankset.
An alternative would be using a crankset already sized for PF-30---You could google "Crankset 50-34 30 mm spindle" and see what come up.
I' do it, but the more I play at work, the longer I have to stay at work, and it cuts into riding time. My apologies.
Quoted: 562 Post(s)
Liked 64 Times
Still trying to wrap my head about the BB issue. Called the Praxis people thinking they might have a good solution. Basically, they said they don't, and they don't even offer a crankset that works directly with the BB30a on the CAAD12. So it got me thinking: Are there any options that don't involve either a design compromise or paying boatloads of money? If not, then I'll stop here and buy a complete bike. Otherwise, I'll proceed on and continue with my project.
Thank you,
robert
Thank you,
robert
Thank you,
robert
Thank you,
robert
You can either chose the cheaper Wheelsmfg.com BB or the more expensive C-Bear BB with ceramic bearings.
