"Future proof" wheels (TA vs. QR)
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I'm thinking of getting new wheels. Bike has QR skewers, but since the industry is moving to thru axles, wouldn't it be a good idea to get TA wheels and use adapters to use QRs now?
Any downsides to this approach?
And I suppose a 15mm front TA hub and a 12mm rear TA hub would provide the most adaptability going forward - true?
Quoted: 18415 Post(s)
Liked 15,546 Times
TA vs. QR is the new best frame material.
Subscribed.
Subscribed.
Self analysis.. Who Are You?
Are you easily drawn into the latest Industry driven , marketing trend? Or, would be perfectly happy hanging out with The C&V Eroica crowd..?
It's up to you...
As Yogi Berra said "when you come to a Fork in the Road, Take it "
It's up to you...
Randomhead
Liked 3,698 Times
If you are talking road, then 12mm f/r would be best. I think they will stick with 12mm. 12mm rear on a QR bike is a bit of a problem, you would need a convertible hub. Lots of hubs are convertible though.
No. The thinking is, in 5 or so years, if I decide to get a new frame, I'll have more options.
Rohloff? https://www.rohloff.de/en/products/speedhub/ they modify for TA 142, 148, (XL shell) 177 & 197..
whole hub internals Assembled around a different core than the TS or CC..
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
It depends. I like the TA with QR. If you know what you want, just get it, but I assume you wouldn't be posting.
Main issue is width. The TA (rear) is generally not going to fit well in a std road bike.
For the tandem I bought a 142 TA powertap, then am making and adapter for 145. I expect it will work fine.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Both my bike's axels are NUTTY. They will last a long time, if not the rest of my like. Rohloff rules the heavyweights, QR ? Pffft
Sturmey Archer hubs ongoing since 1903. DeFailleurs SUCK.
Interocitor Command
I can't help with your decision, but 5 years is a long time. Perhaps you could get an interim set of wheels to hold you over until you do decide to get a new bike. And in 5 years you will know for sure which direction the industry has taken.
Liked 2,011 Times
It seems like there are all kinds of adapters out there, and I don't quite understand the landscape. My naive thinking is that if I get hubs with the biggest holes (15mm TA front, 12mm TA rear), I can get adapters to use 9mm skewers (needed for current bike), and I could also get an adapter to adapt the 15mm front hub to 12mm, if needed.
So I want to know if the part underlined above is possible and if there any problems with it.
the QR is not going away in 5 years and As I'm seeing ..... way up the coast from you and where I did Navy Boot camp.. [50+ years ago]
the rear of TA Frames are trending wider and wider and that may present a problem if you insist on buying the trend setting marketing driven performance focused bikes
utility bikes likely will not change ..
Randomhead
Liked 3,698 Times
the reason I suggested going with 12mm for road is that 12mm forks will not always take a 15mm hub. 15mm road forks will probably still be around, but 12mm are going to be more common. I think you should look for convertible hubs.
Jedi Master
There is no such thing as future-proof. I would get hubs that fit my frame. That would give me an excuse to get a new wheelset in 5 years. I always think I'm going to be able to reuse parts later, then just end up buying new parts anyway for one reason or another.
Look into DT swiss wheels they have adapters for pretty much whatever spacing/release you want and are reasonably priced. Is your current setup disc brake or the other kind? Disc brakes have pretty much taken over the market and in five years probably more so.
I think from TA you can always convert to QR with adapters but not the other way around. I have a two year old set of Mavic Ksyrium Disc wheels that came QR along with adapters for TA for the front. I wanted to swap the wheels to my TA road bike so emailed Mavic for the kit part number to convert the rear and they told me its not convertible. I think most of the road wheel set today are probably convertible front and rear just make sure before yo buy.
Quoted: 4806 Post(s)
Liked 3,928 Times
Ben
Liked 2,011 Times
https://www.amazon.com/VeloFuze-Cycl.../dp/B00IQG6JNM
Seems much more economical than going with the DT Swiss convertible hubs. So my question is: is there a downside to this approach?
Jedi Master
