Chainring Nut Wrench for stock Kilo TT Stripper Crank?
Old 10-08-15, 05:11 PM
bike manhattan
bike manhattan's Avatar
Got a new chainring. Did not realize I need a special tool to take the old one off and put the new one on. Can anyone recommend a chainring nut wrench that will work with a stock Kilo TT Stripper's crank bolts? Will this guy get the job done?:
Amazon.com : Park Tool bike tools CNW-2 Chainring Nut Wrench : Sports & Outdoors
I've read some conflicting reviews which is why I ask..
Thanks.
bike manhattan is offline
Old 10-08-15, 05:34 PM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
Conflicting reviews of a ****ing chainring bolt wrench?
That's the one you need. Just buy it.
Scrodzilla is offline
Old 10-08-15, 05:40 PM
bones_mcbones
Bikes: Fiori Fixie powder blue w/ granny bars
Quoted: 6495 Post(s)
Liked 29 Times in 28 Posts
they're a lil' tricky to use. good luck
bones_mcbones is offline
Old 10-08-15, 05:54 PM
bike manhattan
Cool, will buy.
And yeah, I just read one guy say he had this very same tool and couldn't get two of the 5 bolts off of his Kilo TT crank with it no matter how hard he tried. He ended up taking it to his LBS to finish the job. Whatever though, I'm sure it will get the job done just fine.
Old 10-08-15, 05:57 PM
Scrodzilla
Scrodzilla's Avatar
Quoted: 640 Post(s)
One of my all-time least favorite tools to use ever.
Instead of changing my chainring, I usually just throw my bike in the dumpster and get another one.
Old 10-08-15, 06:03 PM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times in 432 Posts
Originally Posted by bike manhattan
Cool, will buy.
Even with that nut tool, it can be difficult to keep the nut from rotating if the bolt is very tight. In some extreme cases, it has been necessary to drill the bolt out and install a new bolt and nut.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 10-08-15, 08:57 PM
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
Get knurled chainring bolts, or dual hex/torx. Knurled is more convenient. You can also glue/epoxy the backs into the rear of the crank.
taras0000 is offline
Old 10-08-15, 09:22 PM
TejanoTrackie
Veteran Racer
Knurled only works with real track crank arms that have counterbores for the nuts on the rear of the spider. Otherwise, the knurled sides of the nuts sit outside the spider and do nothing to keep them from spinning when the bolts are tightened or loosened.
Old 10-08-15, 09:54 PM
ThimbleSmash
The Viceroy
ThimbleSmash's Avatar
Bikes: SE PK Ripper FG,Trek Classic Steel, Free Spirit FG, Raleigh Pointe, Centurion Sport DLX, Schwinn CrissCross
Do people actually own those silly things? I have yet to encounter a bolt I couldn't hold in place by hand and get loose. Not that I work in a shop and encounter the mess some people may bring in for fixing, but I do fix up the occasional neglected entry level bike I find in the trash for a quick flip on cash. I've used nothing more then a hex key, my hands, and maybe some 50/50 mix of acetone & transmission fluid to break rust to get them off.
ThimbleSmash is offline
Old 10-09-15, 09:07 AM
Scrodzilla
Scrodzilla's Avatar
Quoted: 640 Post(s)
I've encountered a good number of chainring bolts that couldn't be removed and had to be drilled.
At the shop, I use a VAR chainring bolt tool because I build and work on bikes for a living. Most people probably don't want to spend a hundred bucks or so on something they'll only use a couple of times.
Old 10-09-15, 12:42 PM
50voltphantom
50voltphantom's Avatar
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times in 47 Posts
That thing is badass.
Personally, I'd just get these awesome doo-dads
Set of 5 Chainring Bolts+Nuts for 1X ? wolftoothcomponents.com
4mm + 6mm allen keys. The way nature intended.
50voltphantom is offline
Old 10-09-15, 12:50 PM
TejanoTrackie
Veteran Racer
Sorry, but it's strictly steel threaded fasteners for me.
Also, if alloy is used for a threaded fastener, then it better use a Torx key rather than a hex wrench if you don't want it to strip out after a few removal/tightening cycles.
Old 10-09-15, 03:14 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 27 Times in 18 Posts
This eludes the industry's brilliant engineers. They want to sell you light weight and torque wrenches.
hairnet is offline
Old 10-09-15, 03:38 PM
TejanoTrackie
Veteran Racer
Thing is, the weight savings are miniscule. Also, don't blame engineers for this, blame the marketting idiots.
Old 10-09-15, 04:22 PM
TenSpeedV2
TenSpeedV2's Avatar
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times in 20 Posts
You could hold a chainring bolt by hand and tighten it? I don't think I want to ride on a bicycle that you have worked on. The last thing I want is my chainring to come off while I am riding at 22mph down the street. Brake or no brake, that is not going to end well.
TenSpeedV2 is offline
Old 10-09-15, 04:24 PM
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Yeah I at least fudge with with a screwdriver holding the back.
seau grateau is offline
Old 10-09-15, 04:39 PM
jlafitte
Pirate/Smuggler
jlafitte's Avatar
Quoted: 13 Post(s)
Liked 7 Times in 7 Posts
The flipside of what Scrod says, if you're just gonna use it a couple times the Park tool that goes for three or four bucks works perfectly well.
jlafitte is offline
Old 10-09-15, 06:27 PM
bike manhattan
Seriously! You want those things on tight!
Anyway, ordered the Park Tool chainring wrench. Also ordered the Flying Wheels titanium silver chainring bolts and the Park Tool Y-design hex wrench to get my Amazon order up to $25 since the chainring wrench is an add-on item. Should be pretty sweet brahhhs.
Old 10-10-15, 06:57 AM
ThimbleSmash
The Viceroy
I commute roughly 4K miles a year on one bike that has chrainring bolts that are merely tightened by hand. I do a full breakdown of the bike about every 6 months on the bike. Haven't lost a chainring bolt and there is no noticeable play in the chainring and have been riding it like so for 3 years. Maybe I don't ride as hard as you.
Old 10-10-15, 08:01 AM
TejanoTrackie
Veteran Racer
The OP is talking about holding the chainring nuts at the rear of the crankarm spider, so that the bolts at the front of the spider can be loosened. Yes, chainring bolts can often be tightened sufficiently w/o holding the nuts with a tool, but that is a totally different issue.
Old 10-10-15, 09:19 AM
TenSpeedV2
TenSpeedV2's Avatar
Quoted: 943 Post(s)
I am glad that nothing has happened. I would suggest using the proper tools for the job however.
Old 10-10-15, 10:52 AM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
The tool is generally useless except for when nut & bolt are hard to remove or when you can't tighten the bolt because the nut is turning with it, in which case the parts probably need to be cleaned and lightly greased. I hardly ever use it and it usually does a poor job when I do.
hairnet is offline
Old 10-10-15, 02:12 PM
50voltphantom
Quoted: 481 Post(s)
They really are poorly designed for their intended purpose. Every one of them.
Old 10-10-15, 02:14 PM
50voltphantom
Quoted: 481 Post(s)
I think for mere mortals they'd be fine. I understand what you're saying and agree, but I really don't think the alloy ones I linked to would disintegrate if used properly.
Old 10-10-15, 02:27 PM
TejanoTrackie
Veteran Racer
The ones you linked use a hex wrench to tighten/loosen and are likely to strip out over time. It has nothing to do with being a mere mortal. The Sugino 75 DD crankset I recently bought came with alloy bolts, but they sensibly use a T30 Torx driver to install and remove.
