Compact drop bars and a quill stem
Edventurer
Bikes: 1998 Trek 5200, 2005 Cannondale Bad Boy, 2004 Cannondale Scalpel 2000
I have a 1998 Trek 5200 and I'm trying to improve my riding position.
I'm not as young as I once was and can't ride on the drops very long.
I'd like to switch to a compact drop bar and raise the bars a bit.
The limitation seems to be the quill stem with 1" steerer, (22.2mm quill)
Quill of that vintage typically have a 26mm bar clamp.
To raise the bars I've found a longer quill stem from Nitto,
or have seen other stems with more extension angle (intended for MTB).
The only 26mm compact drops I have found are:
Deda Elementi - Reach 80mm, drop 135mm
Dead Piega – reach 75mm, drop 130mm
Nitto Noodle 177 Bar - reach 95mm, drop 140mm
Soma Highway 1 - Reach 75mm, Drop 130mm
They all require special order and if I don't like the fit its a shipping exchange process if at all.
Are there others?
There are many more choices for 31.8mm compact drops and they can be found in local shops.
I looked for 22.2 x 31.8 quill stems and found Nitto makes one.
I've also found a couple with raised angles (again for MTB).
The other option is a quill to thread-less adapter, then use a modern treadless stem and 31.8 compact drops.
Most of the quill to thread-less adapters seem heavy and clunky.
Best I've found are from Nitto or Profile Design.
What have you done upgrading your quill stemmed bike to use 31.8mm bars?
Thanks
Are there others?
Thanks
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...on the two occasions I did something like this, I just found myself a tubular steel welded stem, as in this photo. These stems are much more forgiving in fitting various diameter bars because the clamp is steel, thus less fragile/more ductile. Also, if you look around, they're available in a wide range of upward angles...so you can get something that is of shorter reach that brings the bar closer to you. This helps in establishing an upright position.
Old Rider
BF Member JoeJack951 has created a very nice option for a threadless conversion.
https://www.bikeforums.net/classic-v...n-headset.html
Probably have to PM for availability.
Also,Nitto M151 handlebar is 128 drop and 76 reach
Edventurer
I like JoeJack951's design, but I'm kinda new so can't sent PM's yet.
Boosting my PM count now.
I've started to look into Profile Designs quill to thread-less adapter. One of the better / lighter options.
Quoted: 18378 Post(s)
Liked 4,512 Times
I suppose another alternative would be to get a 1" threadless fork and shim and use a standard threadless stem.
Nonetheless, that is a unique solution above.
Liked 4,512 Times
I've gone with these stems.
https://www.ebay.com/itm/253289874010
https://www.ebay.com/itm/351784121927
They only seem to come in 80mm and 90mm sizes (or are all the same size with different measuring).
Only 2-bolt. But, so far so good.
I like the flat top bars (aero), so the open face is useful.
Quoted: 399 Post(s)
Liked 274 Times
I had to switch to shorter reach, shallower drop bars some years ago, myself
JoeJack951's set-up looks pretty cool, perhaps if it had been around, and I found it back when I went through the "change", I'd have gone that route, but ordinarily I am genetically predisposed against threadless adaptor doo-hickeys. And along the way I also tried Factory Five's 31.8mm quill, which is the original version that CliffordK's fleabay knockoffs copied, but found it slightly flexy and even worse - a little odd-looking.
Anyway, I think you may be rushing to judgement in giving up so quickly on compact 26mm handlebars...
Besides suggesting that threadless headset conversion - jan230 also mentioned the Nitto M151, which I can tell you from experience is a good one, but it seems to have gotten glossed over here.
You might also consider the Dajia Cycleworks shallow drop handlebar that is available from VeloOrange. I liked mine and found it comfortable, but foolishly let it go when I sold the bike it was on.
I have 2 remaining vintage-ish steelies...
One has the Soma Highway 1 that you mentioned in your OP. I really like and recommend it highly to you. Even if you do have to special order one, it is cheap...errr...inexpensive enough that it won't hurt you if you do decide its not for you.
The other short, shallow bar I am presently using, and absolutely loving, is Nitto's M106 NAS Chinook. It has a somewhat rounder, more traditional-looking shape so nobody I ride with has ever caught on that it is a modern, "compact" bar until i told them.
Good luck and have fun...
Edventurer
Thanks for the 26mm bar info. My list has grown.
26mm Compact Drop Bars Use a standard 22.2 x 26 quill stem
Soma Highway 1 - Reach 75, Drop 130mm
Nitto M177 Noodle Bar - reach 95mm, drop 140mm (too much drop)
Nitto M106 NAS "Chinook" Bar – reach 78mm, drop 128mm
Nitto M151 bar – reach 76mm, drop 120mm
Nitto M151F (flat ramps)
Nitto M151-SSB 31.8mm
Dajia Cycleworks Shallow Drop Handlebar – 75mm reach, 120mm drop
I think Soma might be from San Francisco, just up the road from me. I'll check into them.
Since raising the bars is part of my fit plan, I'd need to find a taller quill stem or one with more extension angle.
I'll look for stems
I'll look for stems
Liked 4,512 Times
ODD LOOKING?
I suppose one could go with a MUTANT instead.
I like my IRD Blackbird 26.0 Aero Ergo bars. But, unfortunately they're discontinued, and I've been unable to find a second set. I'd prefer compact curves to ergo curves, but they work well enough.
I even contacted IRD, and they had no interest in bringing them back.
Quoted: 399 Post(s)
Liked 274 Times
I wanted to try 31.8 bar on my road-going old steelie track bike so I rode with a Factory Five Titan stem for a little while. Yes, I stand up to pound my way up bridges and/or causeways that serve as hills in my locale, and so yes, there was some flex.
OP - if you search, there is a buttload of vintage and modern quills that will help you raise your handlebar, if that is what you think you need after swapping to anything on that list you made.
Have fun...
These Velo Orange drop bars have gotten me back to actually riding the drops comfortably for significant distances.
The shallow drop and large flair also offers a feeling of good control and I find the position (hands farther apart than traditional drops) opens up my breathing.
https://velo-orange.com/collections/...-bar-handlebar
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
You might could avoid the expense of replacing the stem, by changing the setup. I almost never ride in the drops. My cure is to move the levers higher on the bars, and rotate the bars a bit so that riding on the hoods is the comfortable position for me. I have no problems braking from the hoods that way, and it avoids the awkward-looking angled stem.
Edventurer
Here is my solution to changing my riding position. (forgot to post these notes a while back)
I found several 26mm (clamp) compact drops on-line but none I could try out.
I also found several quill stems to give more bar height.
I really wanted to “see” and “feel” them and didn’t want weeks of shipping cycles.
I went to bike shops to get the “feel” for what’s on current bikes.
To give some feel to the dimensions I'd collected.
I also looked at what handlebars were available.
In one shop, I found a compact drop bar called Pro Discovery.
Pro is a Dutch bicycle company.
In addition to compact drop it has compact reach, a 12-degree sweep and ergonomic / flat bar tops.
With the sweep, the 44cm bars are 46cm c/c at the end of the drops.
On their website, they are categorized as gravel bike bars.
It has a 31.8 clamp diameter so requires a steer adapter.
I got a 100mm FSA Gossamer stem with 84/96 degree rise depending on which way you flipped it.
The steer adapter is by a company called Dimension
I got some gel/cork bar tape.
Riding position changes:
• Seat tip to bar tops, stayed same 56cm
• Bars are 5cm higher. (easily increased with steer adapter)
• Hooks are 8cm closer (compact reach).
• Drops are 4cm higher (compact drop).
I did a test ride today. Near where I live we have a classic ride behind Stanford University called the loop.
On the back side of the Loop is a famous climb called Old La Honda.
I did the Loop with Old La Honda. 25.5 miles and 2440 ft of climbing.
Old La Honda is a 3.5 mile, 1350 foot climb.
There was plenty of distance to try out all the hand positions.
Being slightly more upright felt good. Having the hoods a little closer felt good.
The gel/cork tape was comfy. The ergo/flat tops were comfortable.
Having the hoods closer to the bend in the bar gave more support and lined up with the gel pads in my gloves.
The slight flare causes the hoods to line up better with my hands.
I even could ride on the drops for long periods. All good.
The critical test was the long old La Honda descent.
The position of the hooks being higher and closer allowed me to see quite comfortably.
I also tried descending on the hoods and the flare put the brake levers in a better place.
Better brake control.
There seemed to be a void under the brake hood where my palms rested.
I stuck some foam under the hood and improved the feel.
Go to go.
Go to go.
Edventurer
Update, I've ridden several 100 miles and 10,000's feet of climbing, I am loving the setup.
