Shimano 9 Speed Compatibility Question
Old 07-05-21, 07:03 AM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
I am pretty sure all Shimano 9 speed road and MTB components are compatible, but I wanted to double check. Will the newer 9-speed Sora STI road shifters work properly with a 9-speed Deore MTB long cage rear derailleur?
Thanks
dwmckee is offline
Old 07-05-21, 08:20 AM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 533 Post(s)
Liked 312 Times in 236 Posts
Yeah, will work fine.
cpach is offline
Old 07-05-21, 10:00 AM
CliffordK
CliffordK's Avatar
Quoted: 18378 Post(s)
Liked 4,512 Times in 3,354 Posts
You should be OK.
So far the only inconsistency I've read about is that Shimano 4700 Tiagra (10s) uses the same shift ratio as the 11s components.
CliffordK is offline
Old 07-05-21, 12:48 PM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 853 Post(s)
Liked 1,437 Times in 819 Posts
I am using Tiagra 4500, 9 speed, with a Deore long cage RD. No issues.
delbiker1 is offline
Old 07-05-21, 10:34 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
Hold on one second. The latest Sora R3000 2X9 drivetrain uses the 4700 pull ratio for the FD. So the R3000 FD and front Brifter are not interchangeable with earlier 9 speed drivetrains.
Now the Sora R3030 3X9 drivetrain, on the other hand, does use the same pull ratio as earlier 9 speed drivetrains, and is interchangeable with earlier drivetrain.
icemilkcoffee is offline
Old 07-05-21, 11:10 PM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
A bit different from what you want to know, but you can get 9 speed freewheels and 9 speed cassettes. They are not compatible without changing the hub or wheel.
alo is offline
Old 07-06-21, 09:22 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Knock it off.
cxwrench is offline
Old 07-07-21, 09:30 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Thanks. I am only asking about rear derailleur compatability though so I guess I should be fine then?
dwmckee is offline
Old 07-08-21, 01:03 AM
Welshboy
PBP Ancien (2007)
Welshboy's Avatar
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times in 106 Posts
I seem to recall that later Specialized AWOL's used today's Sora with an Alivio RD and 12-36 cassette.
Welshboy is offline
Old 07-08-21, 11:26 AM
icemilkcoffee
The RD should be compatible all across the board for all Shimano 9 speed shifters and brifters
Old 07-08-21, 03:13 PM
cxwrench
cxwrench's Avatar
Bikes: lots
the rd should be compatible all across the board for all shimano 9 speed shifters and brifters
ftfy.
cxwrench is offline
Old 07-08-21, 06:59 PM
veganbikes
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times in 2,666 Posts
Generally yes it all should work quite nicely. As some have noted there are some minor bits and bobs that are odd especially as things get more modern and 9 speed starts getting further relegated to the bottom end but you can generally get it to work or just go Gevenalle and forget the complex STI levers that you can't really rebuild. Friction front shifting is superior anyway unless you have Di2 or similar.
Freewheels became sort of dead with 7 speed, yes one could find one up to 10 speed last I remember seeing but why? Seriously they are junky and the design of the freewheel hub just isn't as good as a cassette hub. Very important for old 5 or 6 speed stuff where cassettes are tough to get unless looking at old Uniglide stuff or trying to build your own cause your crazy but at that point IRD has quality freewheels so no need to worry.
veganbikes is offline
