Super glue for tubeless internal patch
Old 07-07-21, 02:45 PM
Redbullet
Quoted: 388 Post(s)
Liked 76 Times in 49 Posts
I had my first small cut (max 0.5 mm) on my tubeless road bike tire and it was not sealed by tubeless sealant. The sealant did part of its job: very small drops went out through the cut, preventing the air to flow. However, the sealant remained liquid: even at the third ride after the event (5 days later), the very small drops continued to appear, spraying forever during the rides, sticking hard on the frame, clogging the brakes and front shifter. So, my tubeless needs a repair even for a cut below 0.5 mm.
The question is: do you think the super glue below can be used to bond internal patch on road bike tubeless tires? That is because all the packs with tubeless patches I bought have dried glue…
Redbullet is offline
Old 07-07-21, 05:34 PM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times in 694 Posts
Made for just that job
The patch is not like a regular tube type patch.
They are fabric reinforced.
Barry
Barry2 is offline
Likes For Barry2:
Old 07-07-21, 05:54 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
I've actually had good luck with Gorilla Tape. It was meant to be a temporary fix, but it worked so well I just left it. This was an old tire I was trying to wring a few more miles out of, so maybe not recommended for a newish tire?
caloso is offline
Likes For caloso:
Old 07-07-21, 06:24 PM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
Some super glue sets rigid, and I would not use if for a tire. It appears that the one pictured remains flexible. I would use it.
alo is offline
Likes For alo:
Old 07-07-21, 08:20 PM
BCDrums
Recreational Road Cyclist
BCDrums's Avatar
Quoted: 257 Post(s)
Liked 252 Times in 134 Posts
Barry
I hadn’t seen this Rema kit. I recently patched a 5mm cut in a tire from the inside using a standard Rema patch & fluid, is holding well. This is in a tubeless tire used with a tube.
BCDrums is online now
Likes For BCDrums:
Old 07-07-21, 11:27 PM
alo
Quoted: 529 Post(s)
When you think about the glues available, in many cases you could cut pieces of old tube, and use for patches. They ones you cut from a tube, would not have tapered edges, but in many situations they would work. If I patch the inside or a tire, I may use a piece cut from a truck tube, because it is thicker.
alo is offline
Old 07-07-21, 11:46 PM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Liked 204 Times in 151 Posts
Have you considered getting a set of bicycle tire plugs?
Geepig is offline
Likes For Geepig:
Old 07-08-21, 04:12 AM
Redbullet
Quoted: 388 Post(s)
Yes, but I dropped the idea. It is a 0.5mm cut in a 23 mm tire. I'm afraid that enlarging that cut up to 4-5 mm (the thickness of the tire plugs tool) would damage the structure of the tire.
Likes For Redbullet:
Old 07-08-21, 04:25 AM
Redbullet
Quoted: 388 Post(s)
Barry
I can't find that in my region. i hardly found the one attached below. But the glue was mostly dried, so I can only use the patches. I noticed that the glue (although dried) smells a little like super glue - I think the name of the ingredient is "cyanoacrylate". So, I was thinking that a flexible formula of a ready made superglue from any shop might do the job...
Old 07-08-21, 06:04 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
I've used tube patches (like those) on small cuts like you describe that didn't seal. I've never tried it on larger cuts (>2mm).
Badger6 is offline
Old 07-08-21, 07:15 AM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
When the tire is cut it goes through the reinforcement in the casing.
That rema tubeless patch has reinforcing in it.
I got mine from Amazon and Sports Basement.
BTW - Superglue is not a great choice. A vulcanizing glue is the magic stuff, as supplied with almost all patches.
Barry
Barry2 is offline
Old 07-08-21, 07:30 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,584 Times in 2,344 Posts
yes, worth a try, I use that stuff all the time, including on small scab type tears on car tires. the little scabs stay closed & sealed. my wife's car tire has a repair that's been almost a year w/ no issues. just clean the inside of the tire well, maybe w/ alcohol? I have no idea, I've never tried to seal a tubeless tire. you have to maintain pressure until it dries & it takes 24 hrs to fully cure, I think. so if you use it, apply pressure for 24hrs. it doesn't work instantly
but have you considered Park Tool TB-2 Emergency Tire Boot (Pack of 3) I carry them in my bike trunk even tho I use tubes, just in case I tear a tire
rumrunn6 is offline
Old 07-09-21, 05:55 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
Cant say I tried exactly what you describe, But SG does adhere well to rubber. I successfully glued shut a pinhole in a butyl tube and a cut in a clincher tyre. I say give it a go. Clean it up, glue the cut. If it doesnt hold, get the patch kit.
EDIT: Come to think of it, the sealant was supposed to close the cut in the first place and is touted to close cuts much larger than yours. In that light a patch should not be necessary. Glue should suffice.
Racing Dan is offline
Old 07-09-21, 08:53 AM
bjjmaestro
Worth a shot and short test ride but I would be concerned about tire flex and the glue being rigid.
bjjmaestro is offline
Old 07-09-21, 02:59 PM
Redbullet
Quoted: 388 Post(s)
Fully agree with you: the sealant was supposed to work. But unfortunately, it does not. I use good quality and expensive sealant – Schwalbe. The tubeless is rated as 6-9 bar and I use it at 6.5.
So, I must accept that tubeless solution is poorly developed for road bikes. There are lots of nice stories related to the sealant that silently seals the small cuts, but the reality proves that the high pressure in a road bike tire does not allow the sealant to permanently seal a cut. It is a good emergency solution, since the liquid flows out of the tire at a much lower rate than air, but you cannot ride forever with a continuous spray from your tire, clogging your mechanisms and dirtying your frame.
MTB experience might be different, due to lower tire pressure.
Old 07-09-21, 06:47 PM
zandoval
zandoval's Avatar
Quoted: 967 Post(s)
Liked 1,631 Times in 1,047 Posts
Sure... I carry a tube of unopened Super Glue with my Vulcanizing Cement because the the VC can dry up in the tube even if its not opened. This flexible super glue should be even better. Be sure to post your experiences...
zandoval is offline
Old 07-10-21, 07:06 AM
Pop N Wood
Quoted: 668 Post(s)
Liked 529 Times in 355 Posts
Lots of good solutions.
I would use a seam sealer instead of super glue. Super glue dissolves with certain solvent, acetone turns it back into a liquid. Maybe it is compatible with all brand of sealant but who knows.
I carry a tube of seam sealer when I bikepack. It is made for tents, air mattresses, rain gear etc. I've used it to patch pin holes in water bladders. Should work in a pinch.
Pop N Wood is offline
Old 07-10-21, 03:55 PM
Redbullet
Quoted: 388 Post(s)
Thanks for the answers!
Unfortunately, I see lot of uncertainty in the opinions, which probably means that there is no standard and reasonably safe solution developed, for permanently repair a pinched tubeless road tire. That is quite bad news and I think this is a serious reason for which the tubeless alternative does not have a future for road bikes...
Old 07-12-21, 04:12 PM
Pop N Wood
Quoted: 668 Post(s)
Did you not see this post?
Barry
Old 07-12-21, 05:05 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
Half a millimeter? or like .025in. What the hell awful sealant doesn't take care of that?
Genesis 49:16-17
Darth Lefty is offline
Likes For Darth Lefty:
Old 07-14-21, 02:32 PM
Redbullet
Quoted: 388 Post(s)
I have no idea. During 3 rides after the moment when the cut appeared, the sealant continued to spread as a very thin jet of spray over the frame and rear brake - it never really seals, although it blocks the air to flow out. My intuition says that the issue is the tire pressure, which is higher for road bikes compared to MTB. If my intuition is wrong, then I have no idea about the real reason.
Old 07-14-21, 02:39 PM
Redbullet
Quoted: 388 Post(s)
Yes, thanks!
But it is much harder available than the solutions for tubes. I hardly found something similar at only one shop, but the glue inside was almost solid and unusable. I might need to pay 15-20 EUR transport costs for buying a 2-3 EUR tire pack abroad... Quite bad experience for a user.
Also, since the sealant can't deal with such small cuts, I can't see the advantage of tubeless over tubes anymore...
But maybe that is only my particular bad experience with the tubeless.
P.S. Sure, I am also biased by the hard work I had to do to clean all the old sealant on the tire, only to fix a 0.5 mm cut...
