Spoke gauge on Schwinn Super Sport
Bikes: Raleigh Gran Prix, Raleigh Gran Sport, Peugeot UO, Liberia, Condor M93, Schwinn Super Sport
Liked 5 Times
Here is a puzzler. On Friday, I rescued an early 1970s Schwinn Super Sport as a new project. Digging into it today, I find that the rear wheel won't true up. Then found a broken spoke. Went looking on fleabay auctions for spokes and the sellers advertise replacements as .080 like my other road bikes. This Super Sport has the Weinmann Alloy Rims and the spoke thicknesses mic at .070 using dial calipers. (!) Front wheel is OK but spokes are also .070".
Leading question is: does anyone know what spokes are correct for this application? Should they be .080 with the alloy rims or .070"? It could be someone's re-lacing experiment, true, but the bike appeared to be wearing original or at least period Bell tires, 27x 1 1/4 : with the green tread marker visible, so I suspect the tires had little or no use. .
Deal for the bike was made locally through social media PM, when I went to retrieve it I never thought to check the spoke gauges, but then again this is my first Schwinn so maybe a learning curve is a given.
Appreciate any input. Cheers, nd2
Quoted: 3814 Post(s)
Liked 3,345 Times
you do not mention if spokes plain gauge or butted
you do not mention material
models below this such as Varsity, Continental, Suburban use Union galvanized 80 gauge
reasonable to think that since this model features a chromo frame and forged dropouts a lighter gauge may have been employed...
Liked 5 Times
Are the spokes the same diameter at the ends as in the middle? Some spokes are butted, the last inch or so on either end will be thicker.
mycocyclist
Quoted: 910 Post(s)
Liked 821 Times
But, Butt...
(Same as OEM 1964 SS. Some things didn't change?)
Not digging out Micrometer.
Pics if you please?
Pay the Piper...
Likes For machinist42:
Liked 5 Times
Upon further digging, you are correct. Double butted spokes, .080 at the ends and .070 in the mid-run. Galvanized. Approx. 11 5/8 inches long but I will have to remove the broken one to be sure.
This is exactly what I needed to know, from another SS owner. Thanks for that. nd2
Likes For newdoc2:
mycocyclist
Quoted: 910 Post(s)
Liked 821 Times
Illustrative Aid
Liked 3,345 Times
if you look at the spoke heads you will see they exhibit the Union logo
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Super Sports are fun projects, either to keep original or to modify. I've had a couple and the next evolutionary step, a '75 Sports Tourer. You should be fine with a straight gage .080 spoke as a replacement.
BTW, the tires, pedals, saddle, and bar-tape, are all replacements. Not a big deal, but this might guide you to lean towards modifications. We're here to help and look forward to seeing your progress.
Bob
Bob
Quoted: 2486 Post(s)
Liked 2,956 Times
Just to confirm that the tires were not original to the bike: Bell-branded tires, tubes, etc., did not appear on the market until the middle or late 1990s at the very earliest, long after that bike was manufactured.
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
They're probably 14-gauge (2.0mm) straight spokes with brass nipples, 305-310mm length. The wheels appear to be four-cross pattern, so the spokes have to be longer.
Just about any stainless spoke in that size should work for replacement purposes.
Likes For daverup:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
^this
Right length, spoke gauge = nipple thread and Bob's your uncle.
Quoted: 3811 Post(s)
Liked 6,715 Times
Because you don’t want the ghost of Ignaz Schwinn to haunt you.
spondylitis.org
Quoted: 121 Post(s)
Liked 97 Times
Stainless builds tension nicely, in silky, linear fashion - particularly when butted and / or forged. My experience and opinion, but I'm sure others who have built wheels have noticed the difference between stainless and zinc-coated mild steel wheel builds.
Also, at this point, it might be easier to acquire stainless at the bike shop.
spondylitis.org
Quoted: 121 Post(s)
Liked 97 Times
Likes For kunsunoke:
