Mount ONE taillight on which seatstay?
Old 11-04-10, 11:15 PM
vol
Liked 18 Times in 12 Posts
If you are going to mount just 1 taillight on one of your seatstays, would you mount it on the left or the right one? It seems to me it should be the left one, because usually cars are not on your right. Opinions?
On another note, a seatstay-mounted light doesn't seem to be very useful unless your seatstay is high up. I saw some people's light on their seatstays are in very low position and wonder if the drivers see them most of the time or not.
vol is offline
Old 11-05-10, 02:06 AM
Grillparzer
Grillparzer
Grillparzer's Avatar
Bikes: Surly Cross Check
Liked 2 Times in 1 Post
I'd mount it on the left for the reason you stated, but I personally use a seatstay mounted light placed immediately below the saddle. If I don't have anything on the rear rack that seems to work fairly well. If the rack is loaded and the seatstay light isn't obvious then I have a short piece of PVC pipe with two inexpensive lights mounted on it that I Velcro to the end of the rack.
Grillparzer is offline
Old 11-05-10, 08:25 AM
dcrowell
Fat Guy Rolling
dcrowell's Avatar
Bikes: Bacchetta Agio, 80s Raleigh Record single-speed, Surly Big Dummy
I have one bike without a rack, and I have the light mounted on the left seatstay, just below the brake. The other bikes have the lights mounted elsewhere.
dcrowell is offline
Old 11-05-10, 12:09 PM
Richard Cranium
Richard Cranium's Avatar
Location: Rural Missouri - mostly central and southeastern
Bikes: 2003 LeMond -various other junk bikes
Quoted: 78 Post(s)
Liked 44 Times in 35 Posts
I still think my "rubber hose" idea is great. All you do ic cut notches in a 4 inch piece of hose and wedge it into the seat rails. Then "firm up" the the hose with tape around the notched areas.
Perfect placement, you can turn it on and off while riding.
Richard Cranium is offline
Old 11-05-10, 12:43 PM
slowandsteady
Faster but still slow
slowandsteady's Avatar
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
I have it on my left seat stay. That said, i just bought another and now have it on both seat stays. I also have a blinkie on the rear rack. So there is a triangle of blinkies. Hard to miss.
slowandsteady is offline
Old 11-06-10, 12:33 PM
curdog
curdog's Avatar
Bikes: Cannondale Synapse
I would have it on drive train side in case the bike needs to be laid down for some reason.
curdog is offline
Old 11-07-10, 04:21 PM
BarracksSi
Bike ≠ Car ≠ Ped.
BarracksSi's Avatar
Bikes: Some bikes. Hell, they're all the same, ain't they?
Liked 5 Times in 4 Posts
On my road bike, it's on the left side because the seat stay is so low that the wheel would block it if it were on the other side.
If I were in the UK or Japan, I'd put it on the right side.
BarracksSi is offline
kabt53
27
11-01-20 07:50 PM
meyers66
Touring
4
03-10-19 01:57 PM
veganbikes
Touring
15
12-07-14 08:22 PM
fourknees
2
09-01-13 06:42 AM
tsappenfield
Classic & Vintage
5
04-08-10 01:03 PM
