Please Help Me Date 1970's Sunshine High Flange Hubs
I have these Sunshine high flange hubs from my 1978 Univega Gran Rally. There is the Japanese industrial symbol followed by the numbers 5345, which I understand is a type of standardization number found on many different Japanese components and does NOT reflect the date codes.
I researched on vintage-trek.com and see that Sansin & Sunshine hubs were made by the same company. They each have specific alpha numeric formulas for their dates, and one paragraph discusses at least one known outlier. Mine is apparently an outlier. Here's the link-Scan down to Sansin & Sunshine for explanations:
Date of Manufacture of Bicycle Components can be used to date a bike: component dating
My front hub has the letter "P" or possibly an inverted "d" to the right of the 5345. No other markings whatsoever anywhere except the word Sunshine. See below.
Sunshine High Flange Hub by velocivixen, on Flickr
Sunshine High Flange Front Hub by velocivixen, on Flickr
Single Letter "P" on Hub by velocivixen, on Flickr
I'm guessing these are original to the bike as can be seen on the 1978 Univega Catalog here:
https://2.bp.blogspot.com/-J4t9-Kc6my...talog+WM15.jpg
So, what gives with my date code? The rear hub has the letter "m" in lower case with the rounded "humps" vs a capital "M" with pointed humps. I am hoping that @tmar will chime in with insights.
Regardless the rear has nice cones and races and I tracked down some smooth cones for the front, and the races are fine. They have this grey brushed look to them that I haven't seen. Usually on alloy parts they get that white look to them, but this looks like fine dark brush marks of dirt, but only thing that takes it off is sandpaper. So far I've found 210, 400 wet, 600 wet, 1000 wet then Mother's Mag gives a good look. I have not worked on these yet as far as sanding & polishing
Hope to lace these to some 700c rims for the Univega.
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
I have no idea what year those are , they are nice looking hubs, If you have access to a Buffing wheel it will make this job a bit easier.
Before
During rebuild
After
Your hubs are really nice! Thanks for showing me what potential they have. I only have a dremel with various buffing wheels. No normal sized wheels. Hmmmm. Maybe that on my list of tools I "need".
@Michael Angelo - what sequence of buffer compounds & types of buffers did you use? I see harbor freight has basic bench buffers inexpensively. Thanks.
Quoted: 4722 Post(s)
Liked 3,036 Times
I can't help you with the year, but the hub model is Gyromaster.
Edit: Sunshine was the brand name for hubs manufactured by Sanshin Matsumoto Works Co. Ltd.
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
I have one of these mounted on a workbench. One grinding wheel is replaced with a cloth buffing wheel.
Ideally, it would be mounted on a post with soft material below and behind the buffer. It's tough to keep a grip on bike parts and the buffing wheel tends to grab the parts and pull them out of your hands. Then the parts go flying at high speed.
When buffing, wear gloves, goggles, and old clothes- the buffing compound goes everywhere and sticks wherever it hits.
No doubt a professional has better recommendations for a good buffing setup.
Jeff Wills
Jeff Wills
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,286 Times
I don't recall ever seeing a higher-grade surface finishing of this style hubshell that the Gyromaster hubs usually have. This style of shell never had more than a machined finish that I can recall, and so look nearly as-cast to my eye. They thus will require removal of significant surface material to look like a premium hub.
I polished up the previous high-flange model with the round holes, and those also required more work than a finer finish would to look polished.
At some later date, I believe Sansin's date codes may have fallen into line with Suntour's 1984 dating sequence.
Excellent information. Thanks.
My intent isn't to make them look "new". I didn't show a photo of the rear one, but it's heavily oxidized? I guess. Anyway, would like to shine them up a bit.
Liked 1,286 Times
Yep: 5" Bench Grinder
One of the first steps I've used on un-finished surfaces is the "unitized" or "deburring" wheel mounted on a buffing motor (extended shaft vs. bench grinder).
The unitized wheel is essentially compressed Scotchbrite-type material wound directionally into a grinding-wheel shape. It is soft enough to conform to metal surfaces, so cannot dig into a surface like a grinding wheel. I have even used these wheels to effect a polished finish on bare rusted steel surfaces, sort of like chroming but with out any corrosion resistance.
My deburring wheel gets a lot of use, as when smoothing over the cut or ground end of a bolt shortened and then shaped with the bench grinder.
Any powered polishing of aluminum should always be done with adequate dust evacuation in place, the dust is neuro-toxic (as are many other metals).
For a quick clean-'n-shine of dirty/corroded aluminum parts, I usually use a soap-bearing (i.e. Brillo) steel wool pad with water. It's a pretty fine finish when done wet!
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 163 Post(s)
Liked 101 Times
A couple years ago khatfull (well-known here for his buffing skills) sold me a pair of these hubs. He had given them his treatment and they were beautiful.
My hubs don't say "Gyromaster" on them as many on a web search indicated. Was the label "Gyromaster" stamped on later hubs? These also have simple loose cup/cone bearings with QR axles.
Liked 1,286 Times
Might have been labeled on later models. But these look like older ones. They were produced for several years(!), a widely-spec'd OEM hubset it was.
There are several variations of Gyromaster hubs for sure. The name was used for many years, both as cup/cone and cartridge-bearing style. I recall the cartridge-bearing versions being the first that came in to the Fuji dealer where I worked in the late 1970's, with the front hub being of a medium flange size that flummoxed one's attempts at fitting an Avocet computer magnet ring. The front hubs of that vintage were much more well-polished than the rear hubs.
@dddd - Thanks for the additional information. I will take photos of the rear one as a "before" and maybe post on the "before" & "after" thread. The one in the photo has been worked on a bit, so I could get images of the print.
I think they are very simple but pretty hubs. Sometimes I prefer simple to the ornate.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I aquired a set (?) of low flanged hubs on 27" Araya rims a few months ago, where the rear hub is nutted & marked Sunshine, but the front has a QR and is marked Sansin. They came on a 1984 Univega, but the model decal is gone, and so is my memory, lol. Anyways, the grease inside the hubs had hardened pretty good, so I tried using isopropyl rubbing alcohol, on Q-tips, to soften it up. It worked great for that, plus it cleaned up the oxidation on the exterior pretty well. It's funny, the frame really showed it's age, but those bearing races came out like new, & spin forever, once adjusted.
I've used a 4" high speed hand held grinder with a brass brush attached. Place items to be cleaned in vise. Excellent results removing heavy deposits of rust and corrosion.
Liked 3,036 Times
The Gyromaster high flange hubs can be distinguished from other models by the number and shape of weight reduction holes in the flange. The Professional and Pro-Am hubs had six but the Gyromaster had eight and they were more trapezoidal. As stated by member ddd, the Gyromaster came in various designs over the years and were available in standard cup and cone version at least into the very early 1980s.
FWIW, I've seen mid-1980s Sanshin hubs with open yy format date codes.
Liked 1,286 Times
My understanding over the years has been that Gyromaster branding always went on upscale hubs with smoother bearings. There were OEM versions with a simple brushed finish, but still with exceptionally smooth races.
I'm thinking there may have been both Standard and Gyromaster versions of Sunshine hubs which used the same hubshells and cutouts, but with different bearing grade and different finishing.
Like DiaCompe brakes though, there can be a million variations depending on each OEM's requirements.
Suntour also sold this exact style of hub branded "Road VX".
Quoted: 78 Post(s)
Liked 30 Times
After the hubs are all disassembled, I use a small file to remove any burrs from the spokes holes. These are only found if the hubs have been built one or more times. Then I use 600-1000-1500 2000 grit wet or dry sand paper. I wet the sand paper with water and flush the paper often. Always being careful around any lettering, numbers, or details you may want to keep looking new. I have a Polisher buffing wheel set up, on the left wheel I use the Brown polishing Tripoli, and the right buffing wheel if for final buffing with mothers compound. Be careful around details and lettering. Also wear gloves, goggles, and a respirator. I also wear a Shop apron. Once the piece is polished, I wash it with warm soap and water, dry the piece and wax with Carnauba wax. Some of you may have different methods for polishing metals, but this system has work very well so far. Also it gets the job done very quickly.
Liked 3,036 Times
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
smelling the roses
Liked 901 Times
TIA
Quoted: 1627 Post(s)
Liked 630 Times
Zombie thread, but a cool one
I'm surprised I missed it the first time around because I've been hanging onto a pair of (mid 70s?) Schwinn Approved hi flange hubs that I finally got around to polishing. Gently frosted white for decades as VV mentions early up in the thread. No wet sanding to finish, just Mother's on the tip of felt Dremel polisher, but they turned out better than the pixactually look here.
So, @T-Mar, @dddd, @Michael Angelo, since you're the guys doing the heavy lifting on this thread, maybe you can date these things for me and tell me who made them. The seem like OK quality. OE on a repainted Schwinn with LeTour components and steel rims built to these alloy hi flange hubs, if that helps.
Liked 1,286 Times
Those round-hole Sansin/Sunshine hubs were stock on my 1973 Nishiki Competition, and I still have 'em. I had to replace the rear spokes at some point fairly early in their life, seems those early ss spokes from Japan were brittle and had a very short fatigue life (same severe problem on my '79 Fuji Professional and on my 1977 Centurion Semi-Pro).
The Schwinn-approved hubs with triangular cutouts came from France (Atom) early on, then from Japan (Sansin) around the very early 70's, and finally from France (Atom) again after 1974 or so.
The Japanese ones had smoother and much more durable bearings than the French ones imo.
I think I got the cones at my local bike shop - they keep random cones in a box for people like me. They’re generous about searching their stash & just giving them to me.
smelling the roses
Liked 901 Times
My hubs are a match for those of Mr.66
