Carbon fiber fork repair or adapt
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
Hello. I had a request to paint a carbon frame.
But there is a problem, the fork has a crack. Also the fork had already been cutted into the most low limit...
On amazon i found that there are some adapters that can extend the lenght of the steering tube.
I was thinking to cut the steering tube were the crack is localed and then use the most long adapter i can found.
Do you think this solution is safe enought?
Quoted: 4210 Post(s)
Liked 3,876 Times
Without more/better info (like photos as a start, or maybe a link to one of those "adaptors") I can't say much that isn't opinion. However the steerer is the only frame tube that is attached at only one end...think about what the after failure inability to control your steering does to you day.
I'm no carbon expert but every steerer tube replacement or extension that I have heard about (and it's quite a few over the years) involved steel steerers and either a brazed in sleeve or a welded butt joint. I suppose that one could join an extension to an existing carbon steerer but that one has to ask suggests that someone else, more experienced, might best do the actual work. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,699 Times
I just don't see why you would do that on any bike, especially for someone else. Those extenders are not intended for this application, and it really seems like a bad idea.
Before painting is the perfect time to get another fork so it can be painted to match.
Likes For unterhausen:
Quoted: 333 Post(s)
Liked 168 Times
here the adapter
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
He must really like his dentist. I'd run away from that as fast as possible.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Likes For Cynikal:
Randomhead
Liked 3,699 Times
If it really lets loose, it's facial reconstruction surgery followed by a couple of years of visits to an oral surgeon. I'm not sure I would trust a regular dentist with that.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Liked 3,876 Times
Thank you for at least photos of the extender you are considering. These extenders are designed to accommodate the stem's positioning higher up the steerer than the OEM length (or cut length) allows for. They are not intended to support the upper headset's bearing race. As I don't know yet where's the steerer crack or how it id shaped or how long it is I can't say if the amount you'd need to cut off will result in that upper bearing race now resting on this extender, or not. The only way I would consider using these extenders is if the OEM steerer is long enough (after being cut) to insert through this upper race.
BTW the majority of these extenders that I have worked with are not meant to be used off road, for racing or foe doing trick riding with. They just don't hold up as well as the OEM steerer would in those conditions. Andy
AndrewRStewart
AndrewRStewart
Quoted: 333 Post(s)
Liked 168 Times
Will be a solution only for letting the stem to be installed by gaining more space.
Quoted: 333 Post(s)
Liked 168 Times
Liked 3,876 Times
One aspect that concerns me is that crack. How long is it? Was it from poor previous cutting methods or a pressure plug that was tightened too much or maybe a missing plug and the steerer collapsed from the stem's binders?
The steerer extenders that we have sold and installed (for fitting needs, not for repair reasons) were not intended for a carbon steerer. The issue that I was told of is that the extender's expanding plug, that goes into the steerer, will be trying to crack open the steerer. Al and steel steerers don't have a grain or directionality and resist compressive and expansive forces far better than a carbon tube does. Carbon steerers are designed to have a stem on the outside of the steerer, where the pressure plug is inside. The two clamping forces will tend to cancel each other out (or get very close if torque settings are respected) and the trapped between steerer will see nearly no forces trying to pull it apart.
I strongly suggest that the OP does their homework very carefully WRT if those extenders are carbon steerer compatible (I tried a brief search for them w/ no luck finding any more info about them). If there's no mention about this consider that the lack of info might suggest something. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
The whole idea of this gives me the heebie-jeebies. I wouldn't extend a steerer at all, ever unless it was a braze job with a sleeved insert.
Think about it. How much expansion in a carbon steerer is effected by a compression plug? For super small weight-weenie plugs it's enough to noticeably swell a bulge the steerer enough that the stem can be difficult to install. That system only works because the stem also clamps the opposite direction squeezing the steerer in a plug/stem sandwich.
This? What is outside the steerer to counteract & balance the expansion force? Nothing. Then add some lever action at the top of the improperly stressed steer tube from the rider...No. This has "bad outcome" written all over it.
Buy another fork. Consider it the cost of admission.
Car dependency is a tax.
Likes For base2:
