31.8mm (Steerer tube) Stem Riser
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 58 Post(s)
Liked 31 Times
The "31.8" advertised on most stems is the handlebar clamp diameter. Even if the pictured stems do have a 31.8mm steer tube diameter, they move the bars up and away which is the problem.
I have a new fork on order, It should be here Wednesday and that should work fine.
Quoted: 58 Post(s)
Liked 31 Times
Fork arrived from Santana today. Now for a quick coat of paint! A 1-1/8 steerer tube slides nicely inside the fork’s 1-1/4 steerer tune, so I can get away from the lack of stem options.
Quoted: 58 Post(s)
Liked 31 Times
Depending on how it fits, I may insert a 1-1/8” tube into the fork which will allow me more adjustment and also get me out of the 1-1/4 stem nightmare.
Quoted: 58 Post(s)
Liked 31 Times
It’s a new fork so the star nut isn’t installed. I’ll use a 1-1/8” star nut in the new tube or drive the 1-1/4” star nut deep enough not to interfere with the new tube.
Quoted: 332 Post(s)
Liked 744 Times
You may want to talk to a frame builder about the logistics here, keeping in mind that you’ll probably want it brazed, will need access to the star nut for headset adjustment, and a cross bolt would interfere with headset/spacers. This is not a part of the bike you want kludged together, especially on a tandem. It might make more sense to track down the 31-8 - 28.6 adapter referenced above. I probably would’ve gone the 28.6 + headtube reducers route to keep it simple.
