wide rims, skinny tires, quick questions
Lost
i'm about to buy a set of rims for an interesting build i've got going. rims are salsa delgado cross. rim width is 22.5mm, they are box section rims. can i safely run a 23c tire on these?
Extra Medium Member
Well, I've never run these rims and I'm sure that someone who has will chime in, however.... I don't think you should have too many issues running a 23, a true 23mm tire on them. Years ago, I used to run 22mm sew-ups on 22mm rims and never had any issue ever. A little bit of an apple to your orange, but not that much different.
Droping the hamer since '86
Lost
on reconsideration, i think i should be fine, the current crop of HED rims appear to be 23mm wide, and they are commonly run with 23c tires. good to go right?
bikebreak
6
07-26-15 06:55 PM
MajorMantra
Road Cycling
36
08-08-12 10:15 AM
dalava
10
01-03-10 10:00 AM
