spoke length and tension; Front and Rear DS and NDS for Peugeot triathlon 86'
Bikes: 2015 Raleigh Tamland 2; 2018 Brompton S6
Hello, I got my first broken spoke in months since I got my bike and restored it. Can you please help me with telling the spoke length and tension specifications, the hubs are Normandy luxe competition, with Maillard helicomatic freewheel and 36 spokes. gauge and nipples also if that is an useful piece of data when replacing broken spokes. If you need more description, please let me know. thanks.
Quoted: 5793 Post(s)
Liked 2,585 Times
I assume your spoke broke at the elbow. If so, all you need do is spin it out of the nipple, and measure it. Spokes are measured from the end to the inside of the bend, so you have exactly what you need.
If you unscrewed and discarded the nipple, you just learned the first rule of mechanical work --- never discard anything until you're absolutely sure you won't need it. The safest way is to never discard anything until 4 days after the repair is completed, checked, and road tested.
However you still have a bunch of spokes to measure, place a ruler along any spoke and measure from the elbow out to the end which you can gauge using your X-ray vision.
As for the tension, if the wheel was OK before the spoke broke, don't touch any adjacent spokes, and tension the replacement until the wheel is aligned. You can confirm that it's a close match to the rest of the wheel by spinning the wheel with your thumbnail pinging every spoke and co paring the pitches.
FB
Chain-L site
FB
Chain-L site
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Or, remove another spoke from the same side of the same wheel, and take it to bike shop to measure and replace.
While you are replacing the broken spoke, you should check tension on the wheel. Maybe the spoke broke simply because it was old, but maybe not.
Mechanic/Tourist
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
the advice above sounds good
but i have one slightly peripheral
huh
to espouse
this sounds like an odd combo
i wasnt aware that any company other than maillard
ever made a hub to fit helicomatic freewheels
i am sure someone will inform me of my ignorance
though
huh
to espouse
though
Liked 2,585 Times
BTW- I vaguely remember that Maillard isn't the corporate name either, but it's been over 40 years since I did business with them so I'm not sure either way.
FB
Chain-L site
FB
Chain-L site
