Garmin’s Varia light and radar
#76
So I went out and got a Bontrager Ion 200 RT so I would have a complete daytime lighting system controllable from my Garmin 130. The real fun has now started - on more than a few occasions I've found either RTL510 or the Ion 200 RT even thought the 130 was off. Yesterday I couldn't get the Bontrager to turn on at the start of the ride. Then I figured out the battery was dead. It must have been on all night. Today the RTL510 was on, blinking away, 4 hours after I finished my ride, even though it was off when I powered off the 130 at the end of the ride. I'm starting to think the only solution is to completely power off both the RTL510 and the Ion 200 RT after every ride.
#77
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Maybe the hours are achievable if only used as a light, and the unit is unpaired with any radar device?.. and also on a completely empty road for the full 15 hours, so it never gets a hit on a car and has to transmit anything? IOW, turn it on and stick it in your sock drawer...
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
#78
Quoted: 408 Post(s)
Liked 122 Times
Another one of my friends recently purchased a Varia radar. However, he bought the new RTL515 which has Bluetooth and another light mode. He uses RideWithGPS when using routes and navigation and since the new 515 is compatible with RWGPS it was a no brainer. He sent me the following photos of how it appears on RWGPS and I thought that some of you might be interested in case you want to purchase a Varia but didn't want the added expense of having to purchase a GPS computer as well. He walked to the corner of his street to test it, thus the slow speed.
No car detected
Car detected
No car detected
Car detected
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
#79
Quoted: 241 Post(s)
Liked 232 Times
The key to getting this to work is to have the head unit add the lights when everything is in position on the bike. My firmware architect worked on a project a few years back that investigated the use of ANT+ in an industrial setting. He remembered that ANT+ would attempt to determine the "quality" of the connection and would adjust during operation to optimize it. He remembered the initial pairing established a base setting and if this was too far off the system couldn't adjust sufficiently, with inconsistent communication as the result. So I tried what he suggested and it seems to have made a difference.
As far as finding the lights on at random times, I figured out that when I unmounted the 130 from my computer after syncing it would create a network with the lights, turning them on based on the time of day. But my bike lives in the basement when not in use, and the computer I use to sync it is upstairs. The 130 couldn't (still can't) reliably create a light network that far apart, thus the lights would sometime be on, or off, or at seemingly random states. Now I take the 130 off the computer and place it on the bike after syncing and everything is good. I haven't had any random operation of the lights since starting to do this.
Overall I'm really liking having the radar.
Likes For RGMN:
#80
After playing with this and a chance conversation with my firmware architect at work I actually have the Garmin 130, Garmin RTL510, and Bontrager Ion 200RT working reliably. Both the RTL510 and the Ion 200RT turn on when the 130 powers on, they turn off when the 130 powers off, they change modes reliable, and I can control each one independently if I want. I've found that if I keep the Light network Configuration to "Auto" the 130 adjusts the light modes of both the Ion 200 RT and the RTL510 depending on the ambient conditions. If I switch the Configuration to "Independent" both switch to the last state the lights were in when they were last in the "Independent" mode. I have both set to "Off" so I can quickly shutoff the lights when I need to.
#81
No car detected
Car detected
No car detected
Car detected
#82
Quoted: 18883 Post(s)
Liked 10,646 Times
Does the RWGPS app work with the previous generation Varia on phones that have an ANT+ antenna?
#83
Quoted: 408 Post(s)
Liked 122 Times
I'm not sure! My only suggestion is to download the app and try it. You may have to update the Varia's firmware to the latest version for it to work but I'm also not sure of that. I have the RTL510 so I can't connect it to my phone. The radar connection/configuration page in the app, with a free account, isn't disabled. I'm guessing this feature is available for free accounts, On an Android, I don't know if you can connect via Ant+ or no; even if the phone supports it.My friend has his connected to an Android phone (not sure what make/model) via BTLE.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
#84
I have the RTL 510. I absolutely love it. I was hesitant riding on the road but this device increases your confidence. I ride later in the evening on quieter roads. With the RTL I take the whole lane. The RTL gives me lots of warning about approaching cars, long before I hear them. Once the alarm goes off I pull over to the far right to give the car lots of passing room.
#85
The one issue I have noticed with the RTL 510 is that it drains the battery on my Garmin 1030, much, much quicker. Quite a noticeable increase in battery drain.
#86
Quoted: 1020 Post(s)
Liked 463 Times
BTW, I also added a small camera lens cap strap to the Varia, just it case it should ever fall off its mount.
Ride safely.
#90
Quoted: 800 Post(s)
Liked 512 Times
Yup. Most definitely with the 520. I think I calculated it out to 1% battery life for every 2km.
Likes For NoWhammies:
#91
Thanks. I have a 1030 which has a large battery and when running the Varia, the battery drains fast. I disconnect the Varia when I hit the offroad sections of my gravel ride.
Likes For alanw2005:
#94
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Though, that's not additional/incremental. A 50 mile ride would would probably use maybe 30% without the Varia.. so maybe overall incremental of +50% battery usage.
Likes For Sy Reene:
#97
Quoted: 20810 Post(s)
Liked 9,456 Times
Battery drain is evidently an issue with some head units as it'll kick on the backlight when an approaching vehicle is detected. A guy in my club connected to my Varia during a century and he had to disconnect after a few hours because he didn't think that his 520 would make it the whole way. I believe that some here have experimented with backlight settings and have deceased the drain rate significantly.
I recently picked up a 530 (after using a Wahoo Bolt for the last two years) and was happy to see more than acceptable battery life when using the Varia; I think that it would easily cover back-to-back centuries.
#98
Quoted: 800 Post(s)
Liked 512 Times
WhyFi I think the 530 allows you to turn the backlighting off completely. The 520 does not. I've reduced the backlighting to 30% and it did help prolong battery life. I think I'd be ok with the 520 for a century. Mind you if there were a LOT of cars zooming past me, it might be close.
#99
Liked 9,456 Times
