Bad link in chain?
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times
Bad link in chain?
I just bought a used bike that has a skipping chain. This link in the photo is very stiff, it won't bend easily there and that is when it skips.
New chain needed? Can I replace that link? This is on a 1984 Trek with a 6 speed triple.
Thanks!
Bikes: (2) 1994 Cannondale R900, red, Silver Trek hybrid
Quoted: 69 Post(s)
Before replacing it, get a chain tool and try to make the link more flexible by forcing the pin deeper into the side plates so the link will flex more.
Likes For jack002:
Really Old Senior Member
Just grab the chain on each side with your thumbs on each side of the bad link and bend in both directions the way it DOESN'T want to bend.
You can usually loosen them up quickly. Just don't overdo it. It will take a "few" pounds of force.
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
The black link looks like it was spliced in at some point. It's possible whoever did it didn't ensure the link was freely moving. @Bill Kapaun's advice is sound; flex the chain sideways at that link and it should free up.
If it doesn't, you may be able to replace it with a master link, but it's possible a modern master link might not fit that vintage 1980s SedisSport chain. If that's the case, a new chain, and likely a new cluster will be needed. Try the simple fixes first.
Quoted: 171 Post(s)
Liked 278 Times
Thanks guys! Just flexing it helped some. Maybe now getting it off and cleaning and lubing it will do the trick.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
That looks like a non-peened-pin chain link spliced in to a peened-pin chain. For a 6 speed, I would source and install a new non-peened-pin chain.
However, if the current chain is very worn, the cogs will likely be worn to match and the chain might skip violently under load.
Quoted: 171 Post(s)
Liked 278 Times
Campagnono
Bicycle Mechanics
8
07-16-14 06:11 PM
TwoFourOne
Bicycle Mechanics
27
05-02-12 03:36 PM
