Tire wear, how do you deal with it do you rotate your tires or replace the rear tire?
Bikes: Fuji roubaix 1.1
Quoted: 20 Post(s)
SO i was wondering how you guys do it i usually. what i usually do is rotate my tires so i can get an even tire wear but, i've never tried moving the front to the back and replacing the most worn tire with a new one. Which is best ??
Always put the tire with the least wear in front. When a rear wears out, put a new tire on the front and put the old front on the rear. Seems counterintuitive since the rear wears faster, but the idea is that its much safer to have a blow out in the rear as opposed to the front. This is pretty standard advice.
en fuego
Bikes: Trek Madone 3.1
Typically, when wire bead appears in a spot or three or four on the rear, I move the front to the rear and put a new tire on the front. rinse and repeat.
As I'm lazy I just replace the tire that's worn. Honestly do whatever ritual makes you feel good. It really doesn't matter.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
My wheels rotate when I ride.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Ditto,
Quoted: 1096 Post(s)
I usually replace both at the same time, regardless. If I were more thrifty, I would do as others above mentioned and replace a rear tire with one that had been on the front, but I'd never replace a front tire with anything but a new one.
Quoted: 6556 Post(s)
Liked 58 Times
By the way that rotation scheme is not quite so desirable for tubulars. I mean who wants to remove a perfectly-well glued on front tubular to move it to the back. That is just asking for trouble like rims that need glue cleaned off, underside tire tape coming off the tire, etc. In the case of tubulars I think that leaving the front in place and just replacing the rear makes more sense. Or replacing both tires to switch to a different brand, size, or model. After all it is important to preserve that matchy-matchy.
Should Be More Popular
Quoted: 22604 Post(s)
Liked 8,929 Times
Bikes: Colnago EP with Campy chorus
Quoted: 23 Post(s)
I usually replace the rear tire once a year and the front once every 2 years . No rotation here .
A similar topic (but more contentious) in the moto world is whether it's ok to have tire of different types/tread patterns front and rear. I don't imagine anyone who ever rides a knobby tire would consider running a slick on the same bike, but other than that, tread really isn't an issue for us road cyclists, is it?
Rotation is not bad but is unnecessary.
Quoted: 18379 Post(s)
Liked 4,512 Times
Hmm, I'm trying to think if I've ever blown through the tread of a tire. I did blow a rusty wire bead off of a trailer tire once. Of course, I've had a few ordinary flats in my life
I don't go out of my way to rotate tires. But, if I do happen to have both front and rear tires off at the same time, I may choose to put the one with the least wear on the rear. Or visa-versa, depending on my mood.
I'm not a stickler for matching tires, but will periodically go with a matched pair.
Tire wear seems to be a combination of tread depth wear (quicker wear on rear), as well as an accumulation of small cuts (happens to both tires), and if mileage is low, also age (happens to both tires).
I've been working on getting my current pair worn down to the threads. I've had the "close" feeling for the last 2000 miles
Farmer tan
Sometimes I just replace the rear.
Sometimes I rotate front to back.
Sometimes I replace both.
Sometimes they don't match.
Doesn't matter.
Doesn't matter.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Bikes: 2007 Ridley Excalibur, 2003 Orbea Orca, 199? Cannondale Headshock MTB hardtail
Quoted: 520 Post(s)
Liked 10 Times
And now for the expert opinion.
Tire Rotation
Tire Rotation
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I replace when a tire begins a pattern of regular flatting. It signals when the tread isn't thick enough for the routine conditions.
I've flatted three times within a week on my commuter's rear tire. All punctures through the tread. Time to replace it. Tires ordered this morning...
On rotation, as others have said, the front gets the better tire.
Liked 58 Times
Also for some folks the front would get really old being used up so slowly. If you ride a rear for a year before using it up, you might ride a front (barring any road hazard destruction) for five years. That is a long time for a tire to be exposed to the elements, especially ozone. It is not uncommon for a dedicated front like that to show signs of ozone attack, cracking, drying out, etc. The rotation scheme assures that both your tires are relatively fresh.
It is supposedly for better steering and control as well as some better protection about flats and blowouts that could be catastrophic if they occurred on the wheel that contributes to steering. No matter how you approach it, you still have the same amount of rubber between both tires to wear down on the road. There is no gain or loss of tire life doing it one way instead of the other.
Can't be that important having ridden for so long not doing the rotation and never having problems as such.
Quoted: 520 Post(s)
Liked 10 Times
That used to happen more often whan I started commuing into the city. I think it can be mitigated by learning all the nuances of your route (sidewalk seams, potholes, goatheads, etc). I could never get away from tiny pieces of glass or rock. But they won't kill the tire, either. I also had a spectacular blowout rolling onto the sidewalk from the road once. My rear wheel slipped on the metal edge of the curb in a driveway since I was riding in at an angle and I think it was wet out. It ripped a huge hole in the sidewall. So I now either take it at less of an angle and/or more slowly (especially in or after a rain).
