Looking for a front rack that mounts to the upper or middle fork
So, after using my ladies bike to run a couple errands (as mine was flat) I have found that I would like a front porteur style rack on my trek district. Unfortunately I do not have anchor points by my axle, and I'd prefer not to use one that is axle mounted. I do however have 2 anchor points on each fork blade, one about midway up the fork, the other closer to the crown. Does anyone have or know of a good porteur rack that could be mounted to my machine?
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times
This one may work.....optional fence available.
It is axle mounted but also attaches at midpoint of fork.
Soma DELUXE PORTEUR RACK – BLACK CRMO
https://www.somafab.com/archives/pro...eur-rack-black
The Porteur Rack is a great option over the standard pannier rack or mini rack. With its wide platform, it is better at carrying odd-sized and bulky loads like a pizza or box full of kittens. You can strap a basket it and some bag makers are making bags specifically for this style of rack.
- UPDATED: Additional interface with fork mini rack eyelets (If your fork doesn't have mini rack eyelets, you can still use the rack. This is just for additional stability and safety)
- Designed for 700c and 26" wheel bicycles.
- Adjustable height
- CrMo construction (also available in Stainless Steel)
- Mounts to hub axle
- Platform is 14.25”w x 12”d
- Lower horizontal strut can take a small bag or pannier
- ED black
- Optional fence available
- Extra eyelet for dynamo lamp or other gadget
- Maximum Load: 10 kg (22 lbs.) - Weight: 2.65 lbs.
- Installation instructions
- Adjustable height
- ED black
Quoted: 48 Post(s)
Liked 15 Times
thanks guys! I ordered the priority cycles porteur front rack, now the waiting game begins
Quoted: 2604 Post(s)
Liked 1,933 Times
Also, now to get a sunlite rack basket and find a way to add spring clasps to attach it to the rack... That way I have the ability to use a basket if needed or just the rack to haul larger boxes
unterhausen
7
05-22-19 06:23 AM
Road Fan
7
04-06-11 08:26 AM
