Vintage Raleigh
Vintage Raleigh
Trying to figure out what model my Raleigh is as it has no decals or paint. “Raleigh” is engraved on the lugging near the seat post, the frame number is WH60034. Would appreciate any help.
thanks!
thanks!
Quoted: 4722 Post(s)
Liked 3,038 Times
Based on the serial number, your frame was manufactured by Raleigh's Worksop division during June 1976. Typically, Worksop only manufactured the better frames with Reynolds 531 tubesets. I'm not aware of Raleigh having used embossing at this time. Photos?
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Pix. Make two more posts and then you can show us what it is.
Ok I’ll take some photos
Liked 3,038 Times
This isn't quite what I was expecting. In 1976 there wasn't stay cap embossing or top tube cable tunnels, at least on the models we saw in Canada and the USA. However, it's clearly from this period based on the bridge hanger for a centre-pull brake. So, I'm thinking you're in a non-American market? It looks like it was previously used as fixie, as the derailleur hanger, eyelets and chain stay mounted cable stop appear to have been removed.
Liked 2,446 Times
Definitely an oddity.
Seńor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
Checking the 1986 US catalog by color, and not finding a likely match.
My suspicion is a Grand Prix, or a Kodiak.
Likes For USAZorro:
Liked 3,038 Times
This shouldn't be from 1986. The serial number indicates Worksop manufacture, but they closed down in the very early 1980s, It should be a 1976-1977 model manufactured in mid-1976. I figure it's foreign market, possibly UK.
Seńor Member
Liked 1,095 Times
Worksop closed after the fire, but production was shifted to Nottingham and the serial scheme remained intact until the end of the 80's. The stamped seat stay caps and top tube cable tunnels put this in the 80's. From looking at online catalogs, the rear brake arch was around on some models until 1986, before disappearing altogether in '87.
Liked 2,446 Times
Measuring the chainstays or putting a rear wheel in the frame to show the spacing from tire to seat tube would narrow down the choices.
Liked 3,038 Times
The 1986 catalogue that you are referencing is for Raleigh USA. The bicycles with the brake cable stop bridge are all touring models with cantilever brakes and vertical dropouts. The Reynolds 531 models all use side-pull brakes, have brazed-on shift lever bosses and even a pump peg. All the 1986 Raleigh USA models I've seen, with the exception of the competition framesets, were made in Japan or Taiwan and used the American head badge. It clearly doesn't match anything in the USA market for 1986 and I strongly suspect it is foreign market.
Disraeli Gears
I've only seen those embossed seat stay caps on mid-80s Raleighs contract-built in the West Pacific -- I've no idea why the headbadge would state Nottingham though; maybe I just don't pay enough attention. If the frame was "hacked" to make a fixie of it (it appears to have been repainted) then it's probably lost canti bosses as well as dropout hanger. The BB shell appears to have a hole (filled) for attachment of a plastic under-BB cable guide.
Seńor Member
Liked 1,095 Times
Thank-you for posting. I was not aware that Raleigh continued to employ the Worksop S/N format after the facility closed. I assume that if they continued with it, that it was under the same conditions (i.e. Reynolds 531 frames)? While I agree that embossed stay caps and brake cable tunnels would seem to be indicative of 1980s, I'm having a hard time accepting a 1986 frame of that level using centre-pull brakes and clamp style shift levers.
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
After consulting the 1987 “Handbuilt Lightweights” U.K. Catalog on Kurts website it appears there are two models from 87 that have centerpull brake bridges, the Granada and the Royal. Both bikes are good enough to have been made at least in part with Reynolds 531 tubing. The Granada seems to be a very close match except for the color scheme. The subject bike is clearly a repaint but the underlying blue color is way too dark to make this a perfect match, perhaps there is a 1986 U.K. Granada? I wonder if Kurt has any more catalogs that haven’t made it onto his website yet because that’d be neat.
Quoted: 323 Post(s)
Liked 690 Times
And a few minutes later, after googling 1986 Raleigh Granada, I believe I found the correct model. I’m useless when it comes to dragging the image over here though. Perhaps someone could help me with that?
Quoted: 323 Post(s)
Liked 690 Times
Quoted: 938 Post(s)
Liked 2,944 Times
Ding! Ding! Ding! The C&V sleuths have done it again...
