"Stripped"
"Stripped"
I talked with a guy who said the crankset on the bike he is selling is "stripped."
I asked him what he means, and he said it turns, but doesn't turn the wheels. Assuming he has a chain, and it's connected ( ), I'm thinking that something is wrong with the freewheel, and at worst, I may need to replace it. What say ye experts- any ideas on what might be going on with this "stripped" bike?
Quoted: 413 Post(s)
Liked 109 Times
Busted freewheel. Unless its Shimano front freewheel system, then it would have busted front freewheel.
Sometimes freewheeling freewheels can be lubed and flushed to make it freewheel like a normal non-busted freewheel should freewheel when its freewheeling correctly.
Quoted: 4722 Post(s)
Liked 3,039 Times
1. Gummed up pawls in freewheel are the likely culprit and easily fixed as per Jim's post.
2. Broken pawl springs in freewheel.
3. Stripped the threads on the hub and/or freewheel body.
4. Stripped the threads on a freewheel cog, but this would cause problem only in one gear.
Hopefully it won't be these:
Or just say no...
Thanks all!
getting bent
Bikes: 2008 Rans V3, 1984 Trek 620
Unless it's an old Helicomatic, in which case it will probably require replacement. Mine did.
Liked 3,039 Times
Had a #4 in the shop, just last week. You don't run into them too often.
Mass Mover
Bikes: KHS XXL
I'm sorry, when I saw how many times you could get freewheel in one sentence, and continue to make sense, (dramatic pause). Maybe it's just me, but I cracked up reading it.
I just cleaned and oiled a freewheel and it is now spinning great...
that being said, I bought a freewheel and cassette a few months ago at the used shop near me...together they were under 10 for sure and both looked barely used
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
Just as an interesting aside, it is possible to have a "stripped bottom bracket" in the sense that you have an Ashtabula crank set with bad threads.
This happens when the threads to get the cones on are ok, but at the point where they sit for running are so worn or damaged that the cone comes loose and then the cranks just free spin and rattle about in the dead zone where the bad threads are. Usually its the threads used to mount the cones (outside) that are bad but I have seen a crank or two where the threads in the running zone are bad. You try to save them with a needle file and loupe, but sometimes a new crank is the best way for that.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Back In The Saddle
Bikes: N+1
Quoted: 87 Post(s)
Liked 8 Times
How about a swagged crank that "broke loose?" That would spin without the wheels moving too.
You really need to have a look at it and report back.
In life there are no mistakes, only lessons. -Shin
