Rubber/Plastic seal of the handle missaligned
Hi,
While cleaning my bike I found that the handle seal is partially pulled out. I am not sure how this happened as the bike is just one week older.
Can someone plz guide me how I can fix it?
Note: I am not able to attach the image, as its asking to post atleast 10 posts :S
thanks
thanks
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Better get your post count up to where you can upload a picture. It's not at all clear what you're referring to here.
But if the bike is only a week old, take it back to the shop where you bought it and have them look it over.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
If you are referring to the plug that inserts into the end of your handlebar, just tap it back in. If it's something else, we'll need more info.
Welcome to Bike Forums, I hope you stick around.
Old fart
Liked 3,400 Times
Quoted: 427 Post(s)
Liked 699 Times
The pic looks like it shows the headset may not have been installed correctly into the head tube of the frame. Looks like I can see bearings, and that the bearing retainer ring is bent.. Is the fork wobbly? Get that to the shop and have it corrected. If it is a loose headset, you don't want to be riding it.
Quoted: 837 Post(s)
Liked 1,061 Times
Dangerous Old Man
No bueno, it looks bent. Assembled incorrectly...
