Sunglasses for dry eye
Old 05-26-14, 03:23 PM
cnguyen0320
I'm looking for a new pair of sunglasses. I'm looking for something that will block out much of the wind due to my dry eye and spring allergies. I am currently using a random pair of under armour sport sunglasses I got years ago. I also just got a pair of Tifosi Podium sunglasses to try out but these still don't do the job. Short of goggles, does anyone have suggestions for a pair of good sunglasses that will do the trick?
cnguyen0320 is offline
Old 05-26-14, 04:38 PM
shackelford
Bikes: 2014 Trek 1.1
Bought these a week ago. I have the same problems with my eyes and allergies as you. These glasses work really good
https://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
shackelford is offline
Old 05-26-14, 05:31 PM
m_b_b
Would love to hear any recs for this too. I end up incredibly congested and blowing snot rockets on the side of the road on every ride. I went from a cheap pair of Performance-brand glasses to only slightly-less-cheap Serfas Gladiators from the LBS. The Serfas are definitely better, but the problem isn't solved and my helmet interferes with the earpieces. Googling brought me to some things that are foam-rimmed, but not sure I need that much, just some glasses with a lot of coverage.
Anyone have any other ideas?
m_b_b is offline
Old 05-26-14, 11:13 PM
f4rrest
Farmer tan
f4rrest's Avatar
Bikes: Allez, SuperSix Evo
Quoted: 2870 Post(s)
Liked 28 Times in 23 Posts
I used to get dry eyes, and absolutely LOVE my POC Do Blades.
f4rrest is offline
Old 05-27-14, 06:46 AM
rpenmanparker
rpenmanparker's Avatar
Quoted: 6556 Post(s)
Liked 58 Times in 36 Posts
If you do not use a modern antihistamine eye drop, you should immediately consult your physician (ophthalmologist, allergist, general practitioner, even ENT) or optometrist to get a sample and prescription for one like Optivar, Lastacaft, etc. These are far superior to the old fashioned antihistamine drops which can still be obtained over the counter at the drug store (various brands). I use the old fashioned ones in between doses of the modern ones if I need a booster fix of protection in between the 12 or 24 hour dosage interval. Oral antihistamines do not protect the eyes from allergy symptoms, because the medication does not cross the barrier between the circulatory system and the eyes.
Robert
Originally Posted by LAJ
No matter where I go, here I am...
rpenmanparker is offline
Old 05-27-14, 07:46 AM
LAJ
So it is
LAJ's Avatar
Quoted: 11386 Post(s)
Liked 4,713 Times in 2,748 Posts
Unsure if your issues are related, but cold and wind would cause me to gradually lose my sight. Wiley X, with the foam padding around the lenses, ended up being a wonderful solution. One downfall is a little loss of peripheral, but when it's that type of weather, I'm not usually in a group ride setting.
Wiley X | Outdoors Climate Control - Wx Arrow
LAJ is offline
Old 06-05-14, 02:33 AM
anthonylynn
go to this store www.savealotdiscount.com buy discount oakleys only 10$
anthonylynn is offline
twodownzero
General Cycling Discussion
26
09-08-17 05:52 AM
luusyphre
Road Cycling
42
04-27-16 05:54 PM
dynikus
Road Cycling
70
09-11-12 01:51 PM
Gege-Bubu
Road Cycling
28
06-29-11 02:55 PM
bernmart
Road Cycling
27
04-12-11 03:52 PM
