What bottom bracket do I neded for a pinarello fp8?
Quoted: 7 Post(s)
I've got a Pinarello FP8 frame. The bottom bracket has some wording around it: "OVER SIZE BOTTOM BRACKET", and some strange word in an odd font that I think says CROXOVER.
I measure the inside diameter of the threaded socket at 34.26 mm. I measure the width as 71.5 mm but the carbon fiber protrudes slightly from the shell a bit, so I suppose it's just 70mm.
I want a bottom bracket that will fit my Shimano 105 crankset.
I'm confused a bit. I bought the Shimano BBR60 and I can tell they accidentally sent me the 68mm English threaded even though I ordered the 70mm italian threaded. But I wonder if any of you can comment on this ... The bottom bracket outside diameter is smaller than the inside diameter of the frame. I mean, I can just put the thing inside the frame without any turning. But the 70mm and 68mm refers to the width of the shell. But I'm finding that the shell diameter is different too. I can see bottom brackets I can buy that say italian threaded and 70mm but does that mean the diameter will be correct? I thought the threading meant the threads per inch, but perhaps in this case it implies a larger shell diameter also. I don't know.
Thanks in advance for your knowledge!
Steve
Steve
Senior member
Quoted: 945 Post(s)
Liked 660 Times
Is this a recent production Pinarello? They did follow the herd and offer press fit bottom brackets for a while, but they saw the light and reverted to threaded bottom brackets. All Italian as far as I know.
If it is Italian threading, an English threaded bottom bracket is too small in diameter to engage the threads, which is a good thing, because the Italian is right hand thread both sides, whereas the English is not.
So,go find a set of Italian threaded Shimano cups and you should be set.
Bikes: Spcialized RockHopper (free) 1992 Trek T100 Tandem ($220) 2006 Quintana Roo Seduza ($350) 2016 Giant Fastroad ($1100)
Quoted: 46 Post(s)
I have the same bike made around 2011. And, it has Italian bottom bracket.
SHIMANO Dura-Ace BB-R9100 Bottom Bracket Black, 70/Italian
Here is the link on amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Make sure it's 70/Italian
Quoted: 7 Post(s)
Quoted: 7 Post(s)
hcgaloi, thanks for you reply! You people are the best.
OK, it sounds like my only problem is that the people who shipped out my order sent out the 68.
Quoted: 1438 Post(s)
Liked 1,092 Times
Italian (also French) bottom brackets need the drive side cup tightened very firmly to keep them from loosening, a weakness of the designs.
Really Old Senior Member
