zwift trainer difficult setting
Bikes: yes, i have one
Quoted: 1155 Post(s)
Liked 1,200 Times
i started a "Please come back" free 30 trial last night. wanted to go up the tower. got to the first climb just after that Howard Hughes spruce goose looking thing. 10% grade, man was i spinning fast. then realized that damn setting. i could not find it. where have they put it? but now wondering if i connected to my trainer incorrectly. i connected as an FEC trainer. "C" as in controllable. but i recall seeing a resistance option too. do i need to connect with that? i'll give it a go tonight again.
Quoted: 4637 Post(s)
Liked 5,170 Times
If your trainer is up to it, the Radio Tower is a nasty piece of work in it’s 100% full glory. I was grinding up it in a near 1:1 gear at a cadence in the low 40s at around 250W the other day. Some other riders were spinning at 80+ alongside. I guess they have the difficulty set at the default 50% or less.
The setting is now on one of 2 tabs on the settings screen. I think you might have to scroll down the page too, but it’s not too hard to find.
Liked 1,200 Times
ok. i'll check out those menu locations. i know the tower is tough at 100% but wouldn't have it any other way. my last season with zwift (2021) i used to do the tower 2 or 3 times once zwift put in that shortcut to get back. it was my more interesting training session.
Liked 5,170 Times
Going full gas up the Epic KOM and then hitting the Tower climb is a tough challenge. I’ve been well into the red a few times when starting the RT climb and then it becomes a survival challenge!
Liked 1,200 Times
found the setting. for some reason zwift automatically connectged to my trainer as both a power source and resistance. i don't recall that from a couple of years ago.
got to do the tower twice again. i am impressed with myself. back in'21 i always had to do that OOS. this time i was able to stay seated the entire way up and for me pushed some pretty big numbers. second time was more relaxed and definitely OOS just before the altitude sign.
speaking of altitude sign, i just figured out what those signs mean. i always thought they meant an alternate route x meters away
Likes For spelger:
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 478 Times
I keep that setting at 50% and my trainer can only simulate 12% grades or something like that? and I still struggle going up those damn KOMs. More power to someone who kicks that up to 100% and enjoys it. I try and choose the flatter routes when I have the option.
Liked 5,170 Times
I’m OOS for nearly all of the Tower climb in my lowest gear (35/33). Cadence is just too low to stay seated for long unless I’m hitting well over 300W. But I’m not really a fast climber at 82kg. If I take it easy on the Epic KOM I can average 300W on the Radio Tower, but not when I ride hard on the KOM.
Liked 1,200 Times
thanks. i consider it an achievement for myself. today will be an easy slow day. not sure if i'll do a slow group in zwift or in rouvy. thinking zwift since the ride just goes on and on and on.
don't try this at home.
Quoted: 989 Post(s)
Liked 536 Times
wow, 100% setting. I would just bog down until my cadence got so low that the Kickr would boost the resistance so high for that cadence that I couldn't turn the pedals, even while standing up.
I do lots of 8%, 10%, 12% local climbs outdoors with no problems, mostly staying seated. The equivalent in Zwift seems a lot harder. Maybe because even a slight pause or hesitation in my pedal stroke will drop the cadence down.
35-45% approx is what I use, perfect for my "old guy" watts, 80 to 95 rpm even on the steepest bits.
I really like the Zwift climbs at these settings. The Climb Portals are a lot of fun and a challenge. I see some riders doing 30-40 rpm on them -- I don't think they know about the adjustment.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 191 Post(s)
Liked 179 Times
Sir Mark, Knight of Sufferlandria
Liked 1,200 Times
i like the trainer because it can mimic reality so i keep it at 100% on those apps that allow it to be changed. that said, i would assume your pace would be the same assuming your power is the same regardless of the difficulty setting. but then i have not experimented with this.
Likes For spelger:
Quoted: 989 Post(s)
Liked 536 Times
Not to hijack the thread but IRL I climb a local grade that I think averages 6% but has plenty of 8-10% parts at a rather low cadence, 30-40 rpm. In Zwift i have my difficulty set at 50%. Are you saying that if I dropped that down I could for the same effort spin faster on climbs? Would that also slow my pace? I try to run a balance of time and distance. I have goals for both. Strava goals are distance based to take in multiple apps and outdoor. Zwift weekly goal is time based and a bit lower than Strava to allow for completion if I choose to do other apps. My understanding is that if you decrease difficulty you will go slower. Zwift requires a set amount of work (watts) to gain altitude and there is no changing that other than switching to workout mode.
(Even in ERG mode in a workout, Zwift still has accurate climbing speeds. I was just doing a cooldown at the end of an interval workout. 70 watts at 12% grade is just 1 or 2 mph, as indicated! My avatar was crawling up the hill, but it's legs were spinning away. I do like ERG mode workouts, since the terrain doesn't affect the scheduled workout at all.)
Quoted: 700 Post(s)
Liked 473 Times
Did the AdZ tonight on that Tour stage 6, got a PR having not done it for over a year, and suffered greatly.
Randomhead
Liked 3,802 Times
Since we drifted to the other end of the scale from the OP, I dropped my trainer difficulty to 25%, and I like it a lot better. Still enough that you can pedal downhill, but the climbs aren't as bad. You can always shift up. I should try zero trainer difficulty, but I suspect that would feel weird.
Likes For unterhausen:
I did the climb today and about halfway up the KOM I set the difficulty to around 25% to give myself more gears. But that's all it really does. It doesn't make the climb any easier. It just lets you spin more easily but you then go slower, just like shifting to a lower gear would. I left it there through the end of the ride even on the big downhill.
Likes For zacster:
Quoted: 700 Post(s)
Liked 473 Times
Randomhead
Liked 3,802 Times
I started using my kickr with trainerroad, and I liked that I never had to shift. In fact, my front shift lever is on my downtube because I never had to use it. Zwift is going to make me change that. One thing that always annoyed me about zwift was that I had to shift. I'm pretty sure there is less shifting with lower trainer difficulty, but I'll admit it confuses me. I changed after I rode the climbing portal and I didn't have low enough gears for the hill I was on. I live in an area with plenty of 20% grades, and zwift's 20% grades are ridiculously difficult in comparison.
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 629 Post(s)
Liked 939 Times
I'm finishing up a few months of zone 2 training. The harder climbs with the trainer set at 100% didn't really allow for zone 2 work - I'm not climbing ADZ in zone 2 at real power levels. I'm really not climbing the radio tower or the raised roads in NYC at Z2 levels. For me 17% grade in real life = above threshold.
Even if I did ADZ at a higher level of power, the cadence won't match real life conditions. 250w at 85 RMP is a whole different animal than 250W at 65-70 RPM.
And my trainer gets wonky at high grades and low power output, even with some cadence in the mix.
My Z2 phase is over, and my training goals are for upcoming rides in the Alps - with the trainer now at 100%, the climbs are different animals.
Likes For Jughed:
Liked 1,200 Times
the only reason why i wanted to set the difficultly level to 100 is simply because i have no choice outdoors. and the reason why i have a trainer in the first place is to maintain my ability for when outdoor riding becomes feasible for me. before the trainer i always felt like it was nearly starting over again. not any more.
while poking around Rouvy's settings i found a difficulty setting too. did not know they had one. it goes up to 150% (IIRC). thank you, but, no.
Quoted: 700 Post(s)
Liked 473 Times
I agree that it doesn't simulate real climbing because of the cadence mismatch but I detest real climbing anyway. I'd rather put my own eye out with a stick.
I like real descending though so I put up with it.
The difficulty setting does NOT make the hills easier, it gives you a lower range of shifting. 15% is 15%. If you lower the setting like I did I could spin on a 15% grade in my lowest actual gears. In real life though you may be going so slow as to stall, but you never stall in Zwift because you are on a trainer. At one point I was doing 2mph. So, is that realistic? Maybe not. But from an effort standpoint it is still the same. When my butt started to hurt I stood and had to go to my big ring so I had enough resistance to stand. At that point I was around 250 watts, which I couldn't maintain anyway. I'm 69 years old and there's only so much I can do. That I do it at all surprises me sometimes. I had the setting at 25%. If I had it at 50% I'd have put it in a lower gear to get the same overall resistance/watts while standing. If at 100% lower gear still. But at 100% I'd have run out of low gears to spin and that would make it impossible for me.
10 years ago I attempted to climb Mt Haleakala in Maui, 10,000' of climbing over 36 miles. I had to stop at around 5800' not because I was too tired, although I was, I had just run out of gears. My low gear was a 34/28, which was lower than my own bike, but still not low enough. I'd have liked to have had a 34/34 so I could spin out where the grade had lessened enough to do that as a recovery point. 36 miles of continuous uphill is very hard even if it only goes to around 8% at points. When I attempted Haleakala in Rouvy I couldn't even make it up the first section. Something about Rouvy always seemed off, but that was years ago since I tried it.
The choice with Zwift is to have a bike with the gearing you ride with outside, or the gearing you might have if you are regularly doing 15% grades over a long distance. I would never even attempt a 15% grade to the radio tower, especially after already having climbed the KOM. I'd take one look and say fuhgeddaboudit. I was already close to the bottom of the list for the KOM.
Anyway, it is what it is. You have a choice.
Quoted: 700 Post(s)
Liked 473 Times
It does let you use imaginary gears that you don't really have though. I think physiologically as well as psychologically it makes it easier for most people. A cadence of 50-60 is very challenging for any length of time.
Liked 5,170 Times
