Cycling for Abs
Quoted: 5 Post(s)
Cycling for Abs
Hello,
Is it possible to build abs and muscles only by riding? I can't find any trustable source about it.
So is there anyone who gain those only by cycling?
Quoted: 4227 Post(s)
Liked 2,488 Times
Most people, with the right diet will be able to see some ab definition without much exercise.
If you're eating right for your body, so that you're not putting on fat, or exercising enough to burn off enough calories by any method (cycling, running, weight lifting, etc) to be in a deficit over a long period, your body will burn fat and show some ab's.
Dedicated ab exercises ( and again, the right diet with enough protein) will give you bigger abs, but again, even with big abs a thin layer of fat will conceal them.
Get your diet right and ab's will eventually just show up.
jj
Quoted: 140 Post(s)
Liked 110 Times
“Cycling”: no. Not at all. It won’t even “build your glutes” like many people think it will, no matter how hard & long you ride. It can be really great cardio work, though.
bmxing (sprinting/climbing while standing up & bunny hopping as big as you can over/up onto everything you can 40-80 times per ride, at least three rides per week): yes. It’ll cut & build your entire core. Stick with it for a few years and you’ll even develop “back-abs”.
It’s a lot cheaper to build your abs doing boring prison cell exercises than to do it via bike. You really need 48 spoke doublewall rim wheels $$$ built and bolted onto a non-kids Pro-level bmx $$$ which you’ll probably find yourself needing serious 3 piece cranks $$$. $$$+$$$+$$$=$,$$$
You really should try to connect with an Athletic Physical Therapist (not at all the same thing as a “trainer” at a gym) to collect the whole batch of core strength exercises and how to do them correctly so you don’t over build some muscles and underbuild others in a way that has you being forced by your doctor to go see a Physical Therapist due to back pain fifteen years in the future. Ask me how I know.
These biomechanically correct exercises will build your abs and everything else really well.
Liked 2,488 Times
Actually abs are build by using them for what they were designed for and if you don't use it you loose it... Eating right won't make your abs stronger, it may make them visible but it won't make them strong. Abs and core need to be used in order to make them stronger.
Likes For wolfchild:
if you want bigger abs, thats body building and again massively dependent on diet, but also more dependent on training than simply losing fat to show your skinny abs.
Quoted: 576 Post(s)
Liked 1,003 Times
Abs for cycling
Its the other way; abs for cycling. Burn fat and do stomach crunches and your cycling will improve.
Likes For DorkDisk:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Not only is it true that “abs are made in the kitchen”, but cycling by itself does little for core strength, though it benefits greatly from it.
Likes For Kapusta:
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
Yup, and the benefit of studio spin classes is that it is easier to "pull stroke" thus adding to the core workout, especially the lower core.
Quoted: 1851 Post(s)
Liked 679 Times
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
From my experience, yes. I see most people answering no, but I've been cycling for three years now and have noticed my abs have developed over that time. I was running before I gave that up (bad knees) for cycling, so I wasn't moving from couch potato to cyclist but from runner to cyclist. I don't think I'm imagining this, and I certainly didn't expect it.
Advanced Slacker
Liked 2,537 Times
Yes, riding does call on my core, but it does not really strengthen it, it just gives me back problems if it is weak.
Likes For Kapusta:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
Likes For Flip Flop Rider:
Quoted: 365 Post(s)
Liked 419 Times
As many people have said above, it is your cycling (and your back) that will benefit from a strong core, not the other way around.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
Cycling builds up the back, glutes, and legs, but not the abs really at all, IMO. You can end up with back problems from this unbalanced situation just like I did, because the abs can't counteract and counter-balance all the forces being exerted elsewhere.
I like doing planks for abs, very simple, they work the abs right where you need them for cycling, and a minute or so is usually enough.
"Bird Dogs" are also helpful for strengthening the lower back, and lower abs to some extent, so that the two areas have somewhat equal strength and can balance each other out while you're on the bike.
Likes For Lemond1985:
Quoted: 2488 Post(s)
Liked 2,957 Times
Liked 2,957 Times
Precisely. Except for short durations of sprinting and attacking on hills, cycling doesn't (and shouldn't) invoke much use of core muscles. I've never done any weight training or "core" training, and until I reached 65 years of age 4 years ago, I was always able to keep up with the strongest cyclists I'd ridden with, including guys 30 years younger.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
When I’ve used the elliptical or done my circuit training, I’m able to work with more intensity and for longer, so that hasn’t suffered for the heavy rotation on biking. But I’ve changed a lot of things up to make that happen and riding more like BMX than road.
Edit: it occurs to me that beyond the much higher fraction of standing work, there is probably a lot more core and upper body work needed because I raised the bars to be about an inch above saddle height. Since my trunk weight isn’t helping as much, I have to maintain more tension on the bars through the arms and core to keep from sliding back off the saddle.
Otto
Grupetto Bob
Liked 5,648 Times
Ab development is ridiculous. I ride to develop my pecks... and they are awesome.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: cruiser, bmx,road
Quoted: 7 Post(s)
You could just ride with your core engaged. As you ride make sure you engage your abs, and then release, maybe make a game out of it.
Packers Fan
No. I do sit-ups, bicycle crunches, and flutter kicks daily. At least 100.
I also do various types of pushups, working up to doing hand stand pushups, plus lunges.
I love riding, but I don't want a cyclist's body either.
cycling to build 6-pack is like eating potato chips for ur daily protein intake (with the 1g of protein in them).
ok, may be not... u might get a 6-pack with enuf cycling... but chips? yummmm, LISA, where is that blue colored pack of salty stuff?
