Housing for NR shifters/RD
Using a set of Campy NR shifters with a NR rear derailleur. Need a chunk of housing between the seat stay and RD body. I know steel housing is period correct, but I want to know what works.
Any suggestions?
thanks
Any suggestions?
thanks
Quoted: 4556 Post(s)
Liked 6,513 Times
I have always thought they used the bare housing with special end partly because it really limited the outlay for that piece being the only shift cable housing needed for the DT shifters that existed for a millennia. May have also been bare so it would not hang onto moisture much, what do I know.
I also think most covered cable casing was fairly crappy for most of that time so they saved money and avoided other problems along the way.
Now days most good cable casing works well and doesn't suffer the things it used to as much.
I personally would and do use leftover pieces when needed and they always seem to be fine these days, again, just my 2c, what do I know.
Bad example
Quoted: 876 Post(s)
Liked 358 Times
If you are referring to the coiled steel housing, using a short piece of it from the frame stop to derailleur does not hurt the shifting. But in any case, I have used Jagwire cable housing with the NR and other derailleurs of the period. The only issue is that the housing is stiff and will not bend in as tight a loop as the old housing can.
Thanks for the answers. I’ve run into sporadic slippping of Campy shifters in the last few years. None in decades past. Since I’m building up this bike from the frame, I want to eliminate all variables to try to solve the issue once and for all. Sounds like thousing isn’t critical.
Quoted: 1325 Post(s)
Liked 1,967 Times
I would look in a local co-op for some of the stainless housing. We ordered it in 50 foot rolls back in the1980's and it was always available. Now days it seems hard to find, but there are bikes that come in with bar con levers that are dismantled and the small bits of stainless are just tossed in the used housing bins. HTH, Smiles, MH
Quoted: 1209 Post(s)
Liked 1,378 Times
Mr. Spadoni
I can gift you a foot of this housing. I dont see myself building any steel bikes soon.
Message me your address and I'll send you some in the mail Monday.
2015 Bianchi Intenso
Likes For malcala622:
Mr. Spadoni
Likes For Mr. Spadoni:
Death fork? Naaaah!!
On my NR bikes I use the classic coiled housing, but I also run a length of teflon lining through it as well.
Top
Top
aged to perfection
Quoted: 856 Post(s)
Liked 1,289 Times
depending on the frame's braze ons you may need the special stepped end piece.
hard to find. I have a few.
/markp
/markp
Thanks. I think I have the right one, but will know as soon as I cut the housing. malcala622 Kindly offered some up, but I just now found a bit buried in a box where it was not supposed to be.
Still, its funny that those ends, a bitty part, can cause a project to grind to a halt.
Liked 6,513 Times
blahblahblah chrome moly
Quoted: 1212 Post(s)
Liked 2,684 Times
Although some modern ferrules such as Jagwire can fit and shift just fine, they look wrong. If you're stuck in the past like I am (hey, this is C&V is it not?) then you want real Campy ferrules # 619 and 620.
#619 if you use the bolt-on housing stop clip on the chainstay, #620 if you have a Campy #621 "diver's helmet" braze-on or equivalent.
Here's an ebay seller with acceptable ferrules, not 100% correct but you have to looks very close to tell. https://www.ebay.com/itm/113637260557
I don't know that seller, not endorsing, just turned up in a brief search.
You can tell real Campy ferrules from the Record/NR era because they have a little flip to the outer edge, that sort of funnels the housing into the ferrule:
Euro-Asia claims to still have them, on their website. They're wholesale only, so you'd have to find an LBS that's willing to order some for you. I expect the price will be high.
The Euro-Asia pic shows it bright plated, nickel I think it is, but you'll generally find them tarnished to a darker grey.
EDIT: I just remembered, Harry Havnoonian has the step-down ferrules for sale, genuine Campagnolo. 2 ferrules plus two diver's helmet braze ons for $20 here: https://www.ebay.com/itm/254825540995
You may not need the braze ons but it's a way to get genuine Campy ferrules — if you're into that!
Likes For bulgie:
Liked 59 Times
Campy stainless housing for rear derailleur
We have originals on sale on both our online store and ebay. On ebay, the listing is https://www.ebay.com/itm/116168605156
On our online store (lower price but higher shipping cost) the listing is
https://boulderbicycle.bike/Deraille...vo-Record.html
Note that the housing looks very similar to what campy used for Bar Con housing, but it isn't the same. The Bar Con housing is thicker and if I recall, the ferule really doesn't fit into it.
Mike Kone
Boulder Bicycle
Mike Kone
Boulder Bicycle
Liked 2,684 Times
Mike Kone
Boulder Bicycle
Mike Kone
Boulder Bicycle
Likes For bulgie:
Thanks for the info on the part and where to buy it. I’m always amazed when I can get a more accurate description of an item and buy it with less hassle than I could when it was in production.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 348 Post(s)
Liked 268 Times
Mr. Spadoni-
Get some nylon or Teflon cable liner tubing and thread it into the coiled, stainless housing as recommended earlier. It will stiffen the housing and aid in the smoothness of the shift quality. The translucent housing just slides right into the stainless outer and is not visible through the coils. Correct ferrules help as well.
Old fart
Quoted: 3617 Post(s)
Liked 3,453 Times
BikeToolsEtc has them, but only in bags of 100:
https://biketoolsetc.com/index.cgi?i...tem_id=JW-1156
Specifically, the "diver's helmet" type chainstay cable stop uses the stepped ferrule:
car dodger
Does campy ferrule #619 actually fit down into the nuovo record derailleur? I have a bunch of ferrules, old and new, none fit into my NR derailleur. So I used a small stepped one.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
