Is this Campagnolo RD 8spd compatible?
Looking for an 8 speed Campagnolo RD and found this one. I know its more of a collectors RD but Im thinking if it works, Ill use it (the hell with it!).
Was under the notion it was only up to 7speed.
Any help is much appreciated!
Thank you!
Sorry! Realized I didnt upload the pic!
Thank you!
Edumacator
Quoted: 2544 Post(s)
Liked 3,369 Times
Thank you!
Thank you!
Almost positive that this is the one that works with the Synchro 2 shifters that needs the little insert.
Almost anything works with friction though, but have no clue what the range is on them.
I can’t find it on velobase though so hopefully more knowledgeable folks will arrive.
I’d go with the early Chorus or Record 8 speed guys. They are pretty solid with ergo shifters.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Are you looking to go with the Campy 8-speed brifters with that little guy? If this is C Record, I don’t think so. It’s not a dual parallelogram design.
Thank you for your input.
Edumacator
Liked 3,369 Times
1994 versions for Chorus, the Record might be 1993 or even 92...I think. 26 max low and 26 wrap total. However, most folks get more.
This is the Record (from Velobase)
This is the Chorus (also Velobase)
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3954 Post(s)
Liked 6,642 Times
Trade ya.
Likes For SurferRosa:
Likes For shuru421:
Likes For shuru421:
señor miembro
Liked 6,642 Times
Here's a link to the op's rd:
https://www.disraeligears.co.uk/site...erailleur.html
That site shows the early C Record versions with the shield logo on the outer parallelogram plate and a spring at the b-pivot. Campy did away with that spring in later versions like the op's.
Quoted: 1088 Post(s)
Liked 1,935 Times
Very good. I was interested as there was an unknown frame posted with a stay end detail at the dropouts: https://www.bikeforums.net/classic-v...l#post23208620
Quoted: 4631 Post(s)
Liked 1,778 Times
You'll want a Campy 8 or first gen 9. Later 9 speed had a different pull ratio. Late Sachs derailleurs should also work.
