Go Back  Bike Forums > Bike Forums > Alt Bike Culture
I don't know what to call this.
Alt Bike Culture Chopped, dropped, stretched, lifted, and otherwise cut up and put back together. The art and science of choppers, cruisers, lowriders and the vast world of mutant bicycles.
Old 10-20-18, 06:12 PM
Kahsyrbag
Bikes: J.C. Higgins Freightliner built between 1958-1963, 1985 Mongoose City Bike, Sear & Roebucks Ted Williams Signature Series Free Spirit mid 70s, 2005 Schwinn Stingray Stealth
Quoted: 18 Post(s)
Liked 11 Times in 8 Posts
Their is no motor on this bike, but after two months I have gotten use to it, it has a 60V 35AH lithium battery, and a 12V 20AH sealed lead acid.
What was left of my sanity jumped out the window a couple months ago. Eight 6.5"/16.5cm speakers, eight 3"/7.6cm super tweeters, and a 12"/30.5cm subwoofer.
I'd love to know how much it weighs, the batteries alone are 50lbs/22.6kgs
From left to right the buttons run- left signal lights, amplifiers, prea-mplifier and Bluetooth receiver, horns, main power is a keyed switch, headlights/tail lights, blue under glow that moves with the music, tight signal lights.
Seven band equalizer above the control panel.
Right side of the subwoofer is the 2x100 watt military grade amplifier for the speakers, and a voltage regulators that drops the 60 volts to 24 volts.
Left side of the subwoofer is the 600 watt military grade amplifier for the subwoofer, and a voltage regulators that drops the 60 volts to 12 volts.
Red 5630 tail lights.
The headlights are 2 30 watt dual LED pods.
The blue 5630 signal lights are incredibly difficult to get a photo of.
Kahsyrbag is offline
Old 10-20-18, 06:23 PM
GrainBrain
GrainBrain's Avatar
Quoted: 1221 Post(s)
Liked 629 Times in 472 Posts
Make sure to wear your high viz to be seen at night
Cool, do you wear ear muffs?
GrainBrain is offline
Old 10-20-18, 06:33 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
DrIsotope is offline
Old 10-20-18, 06:34 PM
Kahsyrbag
Quoted: 18 Post(s)
I probably should for the monthly ride I attend, I max the system on that ride.
Old 10-20-18, 09:05 PM
Kahsyrbag
Quoted: 18 Post(s)
I should probably mention, you can build a really nice sound system for a bike and add only five pounds, instead of a hundred.
Old 10-22-18, 09:17 AM
Philphine
Quoted: 90 Post(s)
Liked 18 Times in 16 Posts
do you just occasionaly charge the battery or have a way of charging it while you ride?
i'm actually thinking on a (much much) simpler stereo/lighting system for one of mine. really just some scooter mirrors that have speakers built into them and a little more elaborate lighting than usual. i've read a little about bicycle charging systems but there isn't a lot of info so i'm always searching. like having the generator/dynamo work like an alternator that keeps a small 12v battery charged.
Philphine is offline
Old 10-24-18, 08:06 AM
Kahsyrbag
Quoted: 18 Post(s)
I use a 20ah sealed lead acid on my cruiser with a simple speaker setup, and it can go all day between charges, so I just popped the battery on the charger overnight, it does weight ten pounds though.. You can get amp boards with bluetooth for $20 and you can choose stereo, or 2.1 and stick a sub on your bike.
Old 10-29-18, 04:10 PM
Fastfingaz
Quoted: 176 Post(s)
Liked 25 Times in 13 Posts
I love what you have done with that sound system,,,,, wish I could afford such a creation,,,,,, I have the tricycle already and a few yards of speaker wire,,, now what else do I need,,,,,,,
Fastfingaz is offline
Old 11-01-18, 05:47 PM
Kahsyrbag
Quoted: 18 Post(s)
I lol'd at a few yards, I went through a hundred foot spool of 16 gauge wire, added more besides that, and also used some 12 gauge. Just look up a 12v bluetooth amp board on Amazon, super simple and easy.
Old 11-01-18, 06:26 PM
Fastfingaz
Quoted: 176 Post(s)
​​​​​​I figured as much just by looking at your pictures,,,,, Ima look that up hopefully it'll simple and easy that even an idiot can do it ,,, thanks....
Old 11-27-18, 11:52 AM
embalmingfluid
That's awesome! Would love to see a video of it in action.
embalmingfluid is offline
Old 01-20-19, 09:18 PM
BicycleSafari
Safari Master
BicycleSafari's Avatar
Bikes: 84 Ross Mt.Whitney - 84 Specialized Stump Jumper - 84 Nishiki Kodiak - 86 Specialized Rockhopper - 86 Cannondal SM-600 with 24" wheels - + more project frames than I'd care to admit to
Quoted: 34 Post(s)
Liked 49 Times in 16 Posts
I would call it a "boom bike"
BicycleSafari is offline
Old 01-20-19, 11:13 PM
BrocLuno
BrocLuno's Avatar
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Quoted: 75 Post(s)
BrocLuno is offline
Old 01-24-19, 04:28 PM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1835 Post(s)
Liked 292 Times in 255 Posts
I have a Walkman AM/FM stereo cassette recorder with speaker membranes on the radio side but I used to carry a small actual boombox. That was too much too handle and it fell off and broke.
Rollfast is offline
Old 01-25-19, 08:46 PM
RollingBuffalo
RollingBuffalo's Avatar
Bikes: '13 Schwinn Solitaire, 84' Miyata 310, '82 Schwinn Super Le Tour
Quoted: 53 Post(s)
Bike de sound
RollingBuffalo is offline
Old 04-17-19, 04:57 AM
ToobNoob
Bikes: in the market
I know what you can call it...... floor spaghetti
ToobNoob is offline
Old 04-22-19, 12:08 PM
KingKong
KingKong's Avatar
BoomBox bike
KingKong is offline
Old 05-01-19, 04:33 AM
AnotherHuman
DJ ride! Pretty hilarious
AnotherHuman is offline
Old 05-02-19, 11:53 PM
fquint
Call it "Mr. Boombastic"
fquint is offline
Old 05-07-19, 04:38 AM
Pro11yN0taZeus
Yes, video please! What kind of music to you play? Amazing lighting.
Pro11yN0taZeus is offline
Old 05-07-19, 07:48 AM
Kahsyrbag
Quoted: 18 Post(s)
I unfortunately never took a video of it, and my garage started leaking when everything began thawing, so I removed all the electronics and have them in a safe place in my house. I'm a renter so the garage may never get fixed.
Old 05-10-19, 08:53 PM
MsTris10
Wooowww that intense!
I second “mr.boombastic” 😂
MsTris10 is offline
Old 05-12-19, 11:30 PM
Kahsyrbag
Quoted: 18 Post(s)
When I am able to put it back together i am definitely gonna put a plaque on the back that says "Mr. Boombastic", I'm a huge fan of Shaggy, and that just sounds like an awesome bike name.
Old 05-13-19, 09:59 PM
wschellen
Quoted: 31 Post(s)
Liked 129 Times in 32 Posts
Wow that's crazy and I am almost up to ten posts.
wschellen is offline
Old 10-13-19, 08:53 PM
Kahsyrbag
Quoted: 18 Post(s)
Had to junk this trike, the frame rusted through from all the dang salt on the roads here in the winter, now I gotta find something new for winter.
