Vintage Bike Bottom Bracket
I have a bottom bracket this is the correct size for the frame I am installing it on. It is threaded, and I meet quite a bit of resistance when trying to hand turn it and even turn it with a wrench. Is this typical of vintage frames? Does it need more grease?
The bracket is a shimano sized at 68x107
Nope, not typical. Doesn't need to hand turn but it should be easy with a tool. Make doubly sure that you're not cross threading it. Also, how do those threads look? A real bike shop should have a die to tap the bb threads, but they're crazy expensive for personal ownership.
Likes For cpach:
Quoted: 1324 Post(s)
Liked 927 Times
It should start to thread on fairly easily and then get harder to turn. As cpach says, it sounds as if you're cross-threading it. STOP before you ruin the threads.
A good bicycle mechanic should be able to chase the threads for you.
A bicycle co-op is a great place to learn how to do things like this. Unfortunately at this time most of those seem to be closed.
Good luck and cheers
Likes For Miele Man:
Quoted: 1438 Post(s)
Liked 1,092 Times
You might try cleaning up the frame threads with a wire brush, then removing the chips and adding some grease before trying again. If you still have issues seek help; forcing parts into place rarely improves a poor fit or crossed threads.
Likes For dsbrantjr:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Assuming it's a cartridge, it's marked L and R. Be sure you have that correct. Again, if it's a cartridge, if you put the "fixed cup" in first, it may be hard to start the "adjustable" cup.
Likes For andrewclaus:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Concur with @dsbrantjr; clean the threads out with a wire brush and try again. Failing that, you may need to do more aggressive thread chasing. This is best done with a piloted tap set, but often an acceptable thread chaser can be made by grinding slots into an old bottom bracket cup:
Be aware that if your frame has English (most likely) or Swiss (rare) bottom bracket threads, the fixed cup side will be a left-hand thread, and you will need a separate thread chaser for each side.
Likes For JohnDThompson:
Thanks everyone. I decided to bring it to my LBS. The mechanic suggested thread chasing, as was mentioned here.
Luckily, I didn’t cross thread and mess up anything. The mechanic said the threads are pretty fine and caked, but what’s making it difficult is the fact that the inside tubing holes (sorry, not sure about terminology) make it difficult for the bb to catch. He said he could probably jam it in now, but that would affect the future removal of the bb.
$40 to rethread and install bottom bracket. I’m thinking this is pricey, but the shop is located in an affluent suburb— the mechanic was helpful, so I don’t mind doing things the right way.
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
Would love to see the project when it is complete. I love vintage bikes. Nothing like lugged steel to get you going in the morning. Heck even the old attempts at other materials like aluminum or carbon are neat to look at.
Quoted: 4199 Post(s)
Liked 3,851 Times
If it was only the frame tube ends that stich inside the shell's ID) were the issue a simple grinding down/out of them would open up the clearance. A Dremel could do this although fairly slow. A 1/4" die grinder would make it a faster job. Andy
AndrewRStewart
AndrewRStewart
Price will vary, but that's what I'd consider about 30 minutes of shop time, so if they have an approximately $80/hr shop rate that sounds about right, which wouldn't be uncommon in a high rent metropolitan area. They also may, fairly, be erring on the generous side of their labor rate given the relatively high tool cost.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Car dealers around here charge more per hour, AND have a one hour minimum! I needed a five minute job on my truck, yep, 1 hour labor.
All things considered, to operate a bike shop and charge $40 for this job is cheap.
