Best Clips/Straps to Prolong Shoe Life?
Old 05-13-11, 10:48 PM
DRietz
Quoted: 7 Post(s)
Pretty self-explanatory I think, but if you need help figuring out what I'm talking about...
I have some vintage no-name metal clips and generic straps right now, and they really take a toll on my sneakers. I just threw out my fifth pair of Vans in the last 12months, where as prior to riding with clips, I could make a single pair break the 10month barrier.
It's undoubtedly from the rub.
So, which clips and straps do you guys use that will prolong the life of my sneakers?
DRietz is offline
Old 05-13-11, 11:09 PM
LupinIII
Bikes: too many
i've had the same vans slip ons for about the past year and a half, wearning them nearly every day.
cloth on top seems fine, but all the foam on the inside is falling apart.
also for your question, bmx platforms + foot straps (like foothold, holdfast, etc)
LupinIII is offline
Old 05-13-11, 11:27 PM
redpear
redpear's Avatar
The one thing that really comes to mind is leather covered toe clips
https://www.benscycle.net/index.php?m...oducts_id=3299
You can DIY leather on your current toe clips. Also consider plastic clips, though I prefer metal ones.
My solution to this problem is to go clipless (heheheheheh)
redpear is offline
Old 05-13-11, 11:36 PM
DRietz
Quoted: 7 Post(s)
Oh, I ride clipless on both my mountain and road bikes, but not the little commuter I built. Maybe that's my next bout of spending...
DRietz is offline
Old 05-14-11, 02:12 AM
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: Rock Lobster; EAI Bareknuckle; Evil Insurgent
Quoted: 361 Post(s)
Liked 7 Times in 4 Posts
I've never had a problem with my vans and with the notorious sneaker hating MKS sylvans with toshi doubles and double gates..... I've been running my pair for a year, daily... at most, the pedal related damage is some rubbing/ smoothing of the rubber edges and the sole where the pedal cages make contact from rubbing/ friction.
Yes platforms and straps.
Leukybear is offline
Old 05-14-11, 08:08 AM
nuhtowel
nuhtowel's Avatar
Bikes: Caad9, Fixed gear, Hardrock beater, 3 speed cruiser
i wear my leather boat shoes with my retrogression straps and they haven't damaged my shoes at all
nuhtowel is offline
Old 05-14-11, 10:33 AM
hamish5178
If you're going through five pairs of shoes in 12 months (even if they are Vans) I think the problem isn't your bike pedals, unless you're regularly riding centuries or something. . .
Do you wear socks? I'm usually sockless in vans/Sperry's and that tears up shoes but not 5/yr.
hamish5178 is offline
Old 05-14-11, 11:10 AM
just dank
Cult Classic Cycling Club
just dank's Avatar
Bikes: Ridley Helium, Norco Search
the toe clips with leather wrapped around them are awesome for protecting your shoes
just dank is offline
Old 05-14-11, 03:50 PM
wearyourtruth
Ride for Life
wearyourtruth's Avatar
if you really want to protect your shoes, i also suggest something like holdfast straps.
wearyourtruth is offline
Old 05-14-11, 03:55 PM
Scrodzilla
See you in Hell.
Scrodzilla's Avatar
Bikes: EAI Bare Knuckle, Dolan DB3 Prototype
Quoted: 626 Post(s)
Liked 79 Times in 43 Posts
I wear Vans slip-ons all the time and have never had that problem. Usually my shoes fall apart from age before seeing any substantial damage from my clips/straps.
Scrodzilla is offline
Old 05-14-11, 04:12 PM
nightfly
Quoted: 87 Post(s)
Liked 15 Times in 10 Posts
Nylon/plastic clips are cheap and don't mess up your shoes as much. Holdfast or equivalent straps don't mess up you shoes at all and they work way better than clips and straps. Probably get plastic clips for $5-10 at any local bike shop. Holdfasts etc are significantly more expensive but worth it.
nightfly is offline
Old 05-15-11, 11:36 AM
WeirdOddity
I'll second nightfly's response. I use plastic toe clips with leather straps and they don't mess up your shoes at all. Sometimes a set of wider/flatter pedals like the MKS GR-9 help.
WeirdOddity is offline
Old 05-15-11, 11:49 AM
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 361 Post(s)
True but, only get these if you rely on a front brake and not brakeless as these are horribly flexible.
Old 05-15-11, 11:57 AM
Scrodzilla
See you in Hell.
Scrodzilla's Avatar
Quoted: 626 Post(s)
I really wanted to like nylon/plastic clips but I don't. I loathe them.
Old 05-15-11, 01:25 PM
DRietz
Quoted: 7 Post(s)
Interesting. I run BMX pedals so I'll have to figure it out.
As far as the wear goes, I can't really comment on the 5 pairs of vans in the last 12 months besides that's what happened. I typically wear chukka lows, and they all started getting holes where my straps were every few months.
DRietz is offline
Old 05-15-11, 01:34 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 361 Post(s)
By coincidence the vans I've been running for over a year now happen to be chukka lows as well; the fabric is completely intact despite the use of cages everyday.
Old 05-15-11, 02:26 PM
tessartype
tessartype's Avatar
Bikes: 2009 Felt B2 Pro, 2009 Trek 1.2, '80s Hercules beater
I tore through two sets of plims in six weeks of riding with rusty clips. When one broke after I didn't slip in before a curb, I replaced them with a set of plastics that were more my size, and haven't seen much wear since. the soles, however, have black marks left by the pedal edges.
tessartype is offline
gmm213
Singlespeed & Fixed Gear
13
04-09-15 02:06 PM
Colorado Kid
Commuting
17
06-27-14 09:52 PM
southpier
General Cycling Discussion
8
04-18-14 04:55 PM
granto
22
09-22-12 10:14 AM
maxbakerman
31
08-10-11 11:13 PM
