Safest Helmut
Lawman
Bikes: Spec. Tarmac Expert SL4
Quoted: 5 Post(s)
Safest Helmut
I don't care how many vents my helmet has or whether it is a little heavier. I want a helmet that protects my brain. If a harder outer shell and more crush material will give me more protection, I want it. Does anyone know if there is a manufacturer that builds a sturdier bike helmet? Jim
Quoted: 3352 Post(s)
Liked 1,054 Times
I have mentioned before that many years ago I owned a Bell Tourlite helmet. It had Lexan shell that was quite thick. Without a doubt it was the safest helmet I ever owned, and wish Bell still made it.
24-Speed Machine
Bikes: 2003 Specialized Allez 24-Speed Road Bike
But here is a website I use, before I get a helmet:https://www.helmets.org/index.htm
Last edited by Chris516; 12-26-13 at 09:59 AM. Reason: Included link to helmet ratings I use before I buy a helmet
Sadly, I don't think there's any real information on this. Helmet manufacturers don't cater to the safety market.
Bikes: Fuji Espree, Sun EZ-1 Recumbent Bike
If a non-vented helmet wouldn't bother you, you might think about a motorcycle helmet, most are stouter than bicycle helmets and have a D.O.T (Dept. of Transportation) rating. Go to a motorcycle shop, look around, try on a few. Some of the classic designs with no face shield are pretty cool looking. Just a thought.
Quoted: 2111 Post(s)
Liked 663 Times
Oh please do *NOT* take the advice to use a motorsports helmet on a bicycle. (Or visa-versa.) They are designed for different purposes.
(And just an aside - the D.O.T. is a minimum performance requirement for motorsports helmets. There are other ratings systems that you should be looking for in a motorsports helmet.)
If you really want a hard shell helmet, there are plenty of bicycle helmets to choose from. Pick any of the multisport hard shell helmets that also have a CPSC Bicycle stamp.
You can start browsing at https://www.bellhelmets.com/cycling/helmets/ .
One last note. Lots of folks (including me) have fond memories of the Bell Tourlite bicycle helmet, and for good reasons. It was quite good for its day. But please do not be tempted to buy a used one on ebay, unless you'd like a collectible to put on a shelf. The foam and shells of those vintage helmets have all aged out of service.
(And since this is A&S if you are a gray beard who is still using your Bell Tourlite - good for you. Mine is retired, what you do with yours is up to you.)
-mr. bill
-mr. bill
A motorcycle helmet is probably a little much for bike riding. But you could go halfway and get a skater's helmet. They're built stronger, but the tradeoff you'd make is having to put up with less ventilation.
Here's the model that I use: https://www.amazon.com/Protec-Adult-H...=skater+helmet
Some reviews for that particular helmet say that it isn't certified to adequately protect you, so you may need to look around.
If I were looking for the safest helmet, I'd be looking at the POC Receptor Backcountry MIPS.
Dual density foam, addressing low and high force impacts, multiple impact use; hard shell construction with advanced penetration protection; MIPS to mitigate oblique/rotational forces.
Next best in my opinion would be POC Trabec Race MIPS, which I'd consider if venting and a visor were more of a priority.
Quoted: 5703 Post(s)
Liked 2,433 Times
The concept of "safest" helmet is undefinable. The efficiency of any helmet depends on the impact speed. Impact speed is assumed when helmets are designed, and the design is optimized for that speed, with performance falling off on either side.
Helmets work by increasing the "baking distance" for your head from the impact sped to zero. The greater the braking distance the lower the G forces inside the head. So the key is a thicker crush zone, and crush rate matched for the impact speed. If
designed perfectly the foam will begin to crush at impact and bring your head's speed to zero just as it's crushed to the max.
If the crush rate is too high for the speed and thickness, your head will slow to zero before using the full thickness. If the rate is too low, you'll crush to the end before lowing to zero.
So it's the crush rate that determines the G-force your brain is subjected to, and helmet designers stay short of the maximum the average head will tolerate. Then they decide on a protection level and calculate the needed thickness.
You'd think that the answer would then be thicker crush zones, and it would be but for practical considerations. More foam means more weight, and a larger shell creates new problems, such as greater torque on impact, which increases neck twisting.
FB
Chain-L site
FB
Chain-L site
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
POC Trabec Race MIPS. I bought one after reading up on the research a few months ago. You have to import them, they're around $200, but I can afford it easily, and I can't justify not spending money if it gives me even a slightly improved chance of not having a brain injury.
MIPS is the important bit. If there are new helmets on the market that use MIPS, check those out too. When I bought mine, the Trabec Race was about it.
Work: the 8 hours that separates bike rides.
24-Speed Machine
A motorcycle helmet while overkill on the safety spectrum for a cyclist. It can actually throw a cyclist off balance. Except in the case of a cyclist on a recumbent, or a four-wheel bike.
MET and POC both make good helmets. The MET Parachute is a full face bike helmet designed for downhill or extreme mountain biking. There are also other brands of full face helmets designed for MTB and BMX. And as mentioned, multi-sport helmets commonly seen on snowboarders and skateboarders.
Quoted: 261 Post(s)
Liked 11 Times
+1
The contruction of a motorcycle helmet is night and day compared to a bicycle helmet. In fact, it is illegal to wear a bicycle helmet on a motorcycle. Why? Because a motorcycle helmet is better constructed and safer than a bicycle helmet. Yet, a cyclist travels with the same cars and trucks and hits motorcycle speed at times but is protected with a much inferior helmet.
Go and buy a bicycle helmet and then go check out a real motocycle helmet. See for yourself who has better protection.
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Motorcycle helmets on a bike are definitely overkill. They add a lot of weight to the head, increasing the chances of rotational injuries to the neck. On a motorcycle it's an additional hazard worth taking because you need the extra protection, but on a bike I'm pretty sure you'd be more likely to be injured wearing a motorcycle helmet than a bike helmet.
Also, motorcycle helmets are almost exclusively designed to minimize the risk of skull fracture, which is a significant threat when falling on a motorcycle. I don't think they do a thing to minimize the risk of rotational brain injuries and concussion, which are the main source of injury on bicycles. They're two different tools because they are two different problem spaces.
Also, on a bicycle, you're working a lot harder. My head is already a sweaty, dripping mess with a bike helmet, I don't think I could even bear wearing a motorcycle helmet on a bike.
"Per Ardua ad Surly"
Bikes: Bianchi Specialissima, Mongoose Hilltopper ATB, Surly Cross-Check, Norco City Glide
The safest Helmut is my buddy down the street who always follows the rules of the road and rides defensively. I don't recall how many vents he has, though.
Dirt junkie.
Bikes: Surly Ice Cream Truck, Peacock Groove road bikem, Salsa Fargo
Liked 6 Times
No, sorry, the correct answer is Helmut Kohl. Helmut Kohl is, in fact, the safest Helmut.
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
Quoted: 7 Post(s)
