2 questions about bike maintainence
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Whether the rims are worn out or not does not depend on either miles or years, but by actual condition. It can be easily verified by others.
Liked 2,971 Times
OP:
If the work that the mechanic is done well, I'd not worry about them not being able to find a stocked item..
FWIW, a mechanic doing supply chain/retail work is not a mechanic's strongest area of knowledge. Most shops in general (Bicycles, automotive, marina) rely on 1 person to specialise in multiple job fields.
-Oh Hey!
-Oh Hey!
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
In my experience (my own rims and those of family and of customers at shops where I used to work), riding in the wet, regardless of sand, is the primary cause of worn rims. Even not in a sandy area, the fine grit on the cleanest road will get on your rims and act as sandpaper under your brake pads. OP said they have used this rim for 9 years for commuting (which generally indicates at least occasional wet conditions) and other riding, and a braking track worn concave or to the point where failure is possible is very likely.
Likes For Wilfred Laurier:
