View Poll Results: Would you buy a hybrid with 2.5" tires?
Yes, with disc brakes
31
64.58%
Yes, with V-brakes
2
4.17%
No
15
31.25%
Voters: 48. You may not vote on this poll
we be rollin'
I mean with something like the Schwalbe Super Moto X or Kenda Kwick Seven.5 with 27.5" wheels? Would you choose either disc brakes or V-brakes like the Tektro M730? Also, with mudguards as standard equipment?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I'm not sure it fits the conventional definition of a hybrid bike, but it is 2.8" 27.5+
Quoted: 5224 Post(s)
Liked 3,585 Times
fat tires, disk brakes & fenders? oh yeah!
we be rollin'
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Many here already have, or close to it: the Specialized Roll comes with 27.5 x 2.3" tires. I'd like to convert my Roam from 29" wheels to 27.5" wheels, and then use a 2" or greater tire on it. I have 29 x 2" tires on it now, and they make the bike just a hair tall. A 27.5" x 2.3"ish tire is about the same overall diameter as a 700x38. One of the things I like about disc brakes is you can do this with rim sizes relatively easily.
Likes For hokiefyd:
Unless you are small, I don't see the disadvantage of large wheels. 29+ is an actual category offered by a few manufacturers. Rolls better over rough terrain.
Quoted: 18382 Post(s)
Liked 4,515 Times
While not a particular hybrid or fat tire user, I am planning to build a bike around the Surly Extra Terrestrial tires sometime in the near future. Drop bars, of course. Probably front suspension. Generally intended for rough gravel riding/touring.
we be rollin'
I would re-think the front suspension. I have a mountain bike with Rockshox XC 30 forks and although it's a good fork and I like the fact it doesn't make me dive when I brake, I'm inclined to think sometimes I'd go for a rigid fork. I mean if it's not plush enough to dive while braking it also gives the impression it's almost useless for regular city biking. (I know about replacing the coil to a softer one but don't want to do it since I don't want to dive while braking anyway. lol)
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
A rigid mountain bike? Yes.
A "hybrid" not so much. The wide tires just kill the utility for street use. My feeling is it is too far in the dirt direction to be called a hybrid.
Liked 4,515 Times
But, yes, there is extra weight and complexity.
It will be an interesting experiment. Then I could do something different for number 2.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
No. Tires that wide (and suspension for that matter) are for mountain bikes. But then, these bike category labels are fairly blurred, so call it, (and get) what ever you want!
we be rollin'
I'm partly talking about this because in the area where I live, the last winter just WRECKED the roads. I mean we had periods of freezing then thawing several times which resulted in pot holes on the road that are so bad, some roads are closed. In the long term, you may have problems with front suspension anyway so...
I am potato.
Liked 1,631 Times
Well, I meant the same geometry as a hybrid. But, possibly with a semi-aggressive posture so you can bend your elbows and go faster when you're in a rush.
You could always buy the bike with the wide clearance for future options & install tires more suited to current conditions. In that case, it might be a smart buy. See if the bike shop will swap for better tires & you might be a happy camper.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
How can this conversation even begin with so little information. How and where you intend to use it matters.
Quoted: 576 Post(s)
Liked 1,003 Times
Quoted: 1221 Post(s)
Liked 629 Times
Sure I would. Here's my do it all mtb, 29er and 2.2" tires (continental x-kings). I ride a lot of pavement with it in the winter, total blast. I also obviously use it off road in the summer so it has the suspension fork. I can easily pump out 50 miles with it, it's about choosing good rolling tires and pumping the air pressure up. I'll keep the pressure at about 40psi on pavement unless there's alot of snow and ice.
I've always wanted an N+1 bike that had a light frame, lighter wheelset and rigid fork with the same tires.
we be rollin'
Believe it or not, I wouldn't mind using a bike like that like a full-blown commuter with mudguards and front and rear racks. The point is I could get groceries or whatever without any fear of potholes and just barrel through. Or even as a weekend adventure bike. But, still with a semi-aggressive position so I could bend my elbows and lean forward to go faster if I'm really impatient.
we be rollin'
What bike is this? It looks modified.
By the way, If you search for Bobtrax X5 in eBay, you'll find something equivalent to what I was thinking about. Although it has 3" tires. However, it would be possible to install 2.5 inch tires on it. And for mudguards, I think it may be possible to modify the SKS Bluemels 75 U to fit the bike. (Those are made for a 29er but maybe cutting down the rods might do it.)
Liked 762 Times
If you search for the name of the bike, "clem smith jr", you'll find that it's a Rivendell model -- very nice stuff.
Is it me or your front mudguard is installed backwards?
Edit: On second thought it's probably installed that way due to the rear facing fork crown.
The definitions seem blurry, but if we assume a hybrid is meant to be a "hybrid" of road and mountain bike, the 29+ isn't a contradiction.
Most hybrids have flatbar, MTB groupsets and wider tires (compared to road), but have no suspension and a more road geometry.... and many variations of that.
Most hybrids come with 700c wheels, which is the exact same rim as 29" (or called 28"in europe, but exact same size). 29+ is exactly like all the hybrids most manufacturers sell, just some wider tires for more comfort and our ever degrading roads.
My hybrid (Toughroad) can fit up to 2.2" tires
we be rollin'
