Freewheel no engaging - removal required?
Please could I ask your advice... I have a BMX wheel which is probably 80s / 90s. The freewheel doesn't consistently engage when pedaling, so I'm guessing grease has gunged up the ratchets inside the freewheel body and the pawls aren't able to engage. Does this sound likely and, if so, is it possible to pull the freewheel apart to degrease it etc? I also don't have the correct tool to remove the freewheel, so if anyone could also point me towards what is required it would be much appreciated.
Thanks in advance, Richard
SE Wis
Quoted: 2751 Post(s)
Liked 3,409 Times
Not a BMX guy but that looks like a cassette freehub not freewheel hub.
https://www.pinkbike.com/forum/listc...hreadid=104117
Quoted: 283 Post(s)
Liked 262 Times
I’ll take a stab at it- If you can find an edge where a rotating part turns around a stationary part, I would use a syringe with some oil and inject oil into the freehub. Spin it around, wait a while, spin some more, wait, maybe more oil, spin, etc. you may be able to free up the pawls inside.
Likes For grizzly59:
Flushed it through with solvent and the pawls are now engaging much better / properly. Will lubricate with light oil.
Still wouldn’t mind knowing what tool was required to remove the freewheel though if anyone knows that.
Cheers.
Cheers.
Might be worth contacting Park Tool and asking - perhaps they could tell you, particularly if you send them a link to the last photo.
Of course, I might be "out to lunch" here. As I said, I'm not a BMX rider.
Likes For Hondo6:
Quoted: 1312 Post(s)
Liked 1,924 Times
It is a freehub that only comes off by a hex bit. The solvent wash is the best method to free it up. The cog can be removed by prying the snap ring off and the cog will slip off, but not needed. Washing it with light oil will be your best bet. Looks like a lot of the BMX hubs I built and watched the kids race in the ABA and NBA. I hope the rest of the bike has the matching anodized parts. Post a Pic of the whole bike for us to enjoy. Smiles, MH
To rmwesley: sorry about the incorrect info I provided above. Photos can sometimes be deceiving in the absence of relevant experience. (smile)
Likes For Hondo6:
