Tires
Bikes: Surly Disc Trucker, Ogre, Steamroller
Tires
I'm looking for a good set of 26in mtn bike tires for a touring setup. What I'd like is good traction and puncture resistant. (not worried about a soft ride).
Any ideas would be greatly appreciated.
think you'll have to be more specific, are you looking for mtn bike type tires, and "good traction" --on what sort of surfaces, as this is the real sticking point and is the more important factor to decide actual width and tread pattern.
Bikes: Thorn Nomad Mk2, 1996 Trek 520, Workcycles Transport, Brompton
These days I am riding on Schwalbe Marathon Plus Tour tires, 47-559 size. I ride on some gravelly trails and on road shoulders sprinkled with glass fragments. So far I am quite happy with the tires. They certainly belong on your short list!
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
I'm very happy with my Schwalbe Mondials in the 2.0 width. I run them at 80-90 psi on pavement and lower the pressure to 40 psi when on gravel and dirt.
That is mighty high pressure for that width! There is risk of wrecking the rims - depending on the width of the rim! My rims have inner well width of 19mm. That's too narrow for such high pressure on a wide tire. Wide tires have a lot more surface tension at a given psi. Then on a narrow rim that tension becomes a force spreading the rim apart.
But hey, if it works for you!
The Left Coast, USA
I've run the Continental Travel Contacts on two 26" MTB conversions, they look like MTB tires but ride like Gatorskins. I think you can get them in 1.6 or 2.0 widths. No flats or issues.
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
If you want puncture protection, Schwalbe Marathons are your solution. The Marathon Supreme is their fastest-rolling, but still darn near puncture-proof.
These guys have the cheapest prices on Schwalbe tires that I've seen.
Bikes: Salsa Fargo commuter,Litespeed Ocoee titanium mountain bike cannondale caad9 105 road bike
Marathon mondials offer the best combination low rolling resistance, puncture protection and on and off road suitability of any tire I know of.
Quoted: 3469 Post(s)
Liked 1,473 Times
whatever you get , a 3rd tire , folding type if you wish , is a good thing to have as a spare, on a Long tour.
Mad bike riding scientist
Quoted: 6228 Post(s)
Liked 4,231 Times
I haven't tried the Marathons...no one has had them in stock when I needed tires...but the Randonneur has good flat protection and wears very well. I can't see what the extra 400g would be used for.
Vittoria also has a number of off-road tires with smoother tread that would be good choices. Still lighter than the Schwalbe.
Stuart Black
Stuart Black
Bikes: Charge Duster Chromoly
i'm using marathon plus 26 x 1,5 and more than 4000km fully loaded (40kg) without a flat, glasses, dirt, gravel, tarmac, loving it.
bikediscount.de has great prices like someone told.
Thanks for all the replies.
Quoted: 418 Post(s)
Liked 523 Times
I found I don't have traction issues running them offroad at 40-30 psi, even on wet dirt.
Bikes: Surly LHT 26in 52cm 2008
TR9392 $26.99
The front rim is a 36 hole Velocity Mountain Goat in the 25mm width and the rear rim is a 36 hole Sun Rhyno Lite in the 25mm width. When I first got the Schwalbes, I was running them at 40 psi and the ride on pavement was awful. The side wall on the tire says 80 psi max, so I tried that and the ride quality and speed was phenomenally better. I was told it was safe to run those tires at 80psi with the wider rim?
The high pressure limit on the tire may be more than what the rim can take. This is tricky territory of course! But if you try say 60 psi maybe you will be happy with the middle road!
Here is another mention of the stress on the rim from high inflation: overinflated tires ?
https://sun-ringle.com/wp-content/upl...files_rev_.pdf
Marathon Mondial HS 428 | Schwalbe North America
what width marathons are you using, and which marathons?
I have ridden 26x1.5 regular marathons on all kinds of surfaces, and would only go wider and more tready if I knew I were to be predominantly on dirt and gravel--and of course with a load, wider is always going to be easier, wider foot print.
Quoted: 418 Post(s)
Liked 523 Times
There are two width measurements for rims, inner and outer. The inner is usually 5 or 6 mm narrower than the outer. 25 mm is sort of medium for an outer width, but it's on the wide side for an inner width.
[/url]
[/url]
I'll try a lower pressure and see how it feels. I haven't been able to dig up any pressure limits on my rims when doing a quick web search. I understand the max psi limit decreases with tire width from what I did find.
I have used 1.5 marathons regular at about 65psi with about 25lbs on the rear rack only, and that pressure works well. I do only weigh 140, but it seems to me that at 80-90 you are putting a lot more stress into your wheels and spokes.
Ive used 26x2 Supremes a bit and wouldnt run them at 90 unless I was loaded a lot, and frankly, even then in my experience that is simply too much.
I am convinced that higher pressures like that on a 2 in tire is working against you, less comfort and harder on the wheels. Allow the tire to do some more suspension effect and it wont be slower--within limits of course on pavement, but if you have a good floor pump, try various pressures for a given bike weight and ride the same route to really feel the difference. On rough paved roads, bringing them down from 80 or 90 to 60 or 70 will be a diffference you will really feel in being less beat up, with no real loss of speed.
I ride a route of about 10-12km as a commute and as I take the same roads, with all the potholes and rough stuff here and there, its a great way to try diff tires and diff pressures and really see how they feel, both in ride quality and effort required, and also to roughly compare ride times. Oh, and with diff weights too, so a bunch of factors that I can try out as I am commuting anyway, so fun to try stuff and actually feel the difference.
Here's another interesting discussion: FLO Cycling - Why Do You Use Less Tire Pressure for a Bigger Tire or Wider Wheel?
He talks about how rim width affects casing tension, but I don't see where he talks about the stress that casing tension puts on the rim, and how that changes with rim width. The casing and bead are pulling the rim in a particular direction. A narrow tire will tend to pull the rim away from the hub. On the same rim, a wider tire is going to pull more and more in line with the axis - the two sides of the rim are getting pulled in opposite directions.
This is all about the maximum safe pressure for the tire, rather than the optimum pressure for efficiency. For efficiency, it does seem like a trade-off between rolling resistance and suspension. There is energy lost when a bumpy ride shakes the bike. If you mostly stand on the pedals then the bumps don't shake you much. Do you have luggage on the bike that is getting shaken and absorbing energy? The most efficient tire pressure depends on all these factors!
and some more discussion: https://www.bikeforums.net/bicycle-me...m-failure.html
Liked 1,473 Times
Lower pressure will increase traction, but there is a limit to how low you can go before you get too much sidewall flex and the tire starts to feel squirmy.
Quoted: 147 Post(s)
Liked 8 Times
I have Schwalbe Marathon Dureme.... it was Schwalbe's top of the line tire back in the day. It makes a great all-around pavement and rails to trails tire. Performs well on dirt and gravel, too.
To put things in perspective with another example, on my drop bar bike with 28mm slicks, bike weighs about 30lbs with water, me at 140 and let's say 10-15 lbs of one pannier of stuff that I commute with--I regularly run 90psi in the rear and 85 in the rear---AND I know it goes down at least 5psi to 10 psi before I get around to pumping up again.
I always used to think the max pressure was best, but reading about losing efficiency over bumps (force going into frame) getting less beast up as the rider, and it being easier on the rims and spokes, made me experiment and consequently reduce pressures.
At whatever the tire width.
