Better design for belt drive bikes
Quoted: 529 Post(s)
Liked 255 Times
When regular bikes use belt drives, the chain stay goes through the belt. So there needs to be some way of breaking the frame to fit a belt, or some way of breaking the belt.
This could be avoided by making bikes with higher chain stays, which go above the belt. This would be a simple design modification. There are probably some belt drive bikes which do this already.
Over the hill
Quoted: 987 Post(s)
Liked 1,186 Times
There are (were?) mountain bikes with a design like this. Works fine.
It's like riding a bicycle
Quoted: 529 Post(s)
Liked 255 Times
If frame manufacturers made frames like this, they could be used for either chain drive or belt drive, which would probably result in selling more frames.
It would also give those wanting belt drives more frame options.
Likes For alo:
Quoted: 2428 Post(s)
Liked 2,875 Times
Chain is still inboard of the elevated chainstay---i.e., chain still passes through the frame. (See photo below; cable housing is outside frame, chain is inside.) Manufacturer would have to eliminate both the right chainstay and seatstay.
Likes For Trakhak:
Likes For alo:
Quoted: 1188 Post(s)
Liked 1,154 Times
As long as the rear cog is still inside the frame dropout, the belt/chain still crosses the chainstay. The elevated (or dropped, as in modern gravel bikes) chainstay is a solution for chainring / tire clearance, nothing to do with the chain or belt.
To solve the frame splitting problem there are two options - move the rear cog outboard the frame, or get rid of both chainstay and seatstay on the drive side. Both seem possible, but would be rather sophisticated solutions and most probably are far from cost effective.
Le Crocodile
Quoted: 367 Post(s)
Liked 771 Times
Using a track style dropout on an elevated CS bike is easy. Wrap belt around rear pulley, install wheel all the way forward, wrap belt around crankset pulley, pull wheel rearward to tension, and off you go. We do stuff like this all day when building custom motorcycles etc.
Likes For prj71:
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
There is a BMX company called YESS and they have done it both ways.
Likes For cbrstar:
Palmer
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1644 Post(s)
Liked 1,785 Times
Pretty much been there, done that, got the souvenir t-shirt, gimme cap and autographed poster.
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
The Allied Able is elevated chainstay but they don’t offer belt drive, oddly. https://alliedcycleworks.com/collect...-able-frameset
