craigslist campy tool score!
car dodger
derailleur alignment tool, freewheel tool, unbranded chainwhip, unbranded chain tool, small thingy(?), campy decal/sticker, small parts campy envelope w/ a few caliper? washers!
edit: chaintool is "cyclo made in england"
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
car dodger
maybe...seems too nicely made for that though.
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
It's funny how tools become so specialized even though they have such simple functions. I suspect that the derailleur alignment tool is really just a bar with a bolt that screws into the derailleur hanger and you just bend the hanger with it as needed to straighten it if needed, but I guess none of us ever really have time to build that tool ourselves, so that's where Park, Campy and other companies step in with these things. Question is, how many times do you really get to use these things to make it worth buying or just taking up space in your tool boxes? I currently have a good lead on some real nice Park tools but I can't figure out what to pull the trigger on because this question keeps coming up in my head. How many headsets will I install in the next 5 years??....uhmmm maybe three or five at most. Is it worth getting that headset installing tool from my lead then???, Do I really need a humongous wheel dishing too crowding all my other stuff if I only expect to build 1 or 2 wheelsets a year at most??? Gosh, I can't seem to answer those questions.......Anyway, my LBS isn't that far away to have it done those few times.....
Just my latest personal thoughts on getting more bike tools for myself.
Chombi
Chombi
car dodger
yea, you are right, I probably won't ever use that tool, esp. when I can use pretty much the all lbs tools, under their supervision/guidance. But, the price was right for the collection ($20), so I bit!
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Quoted: 150 Post(s)
Liked 34 Times
You can probably flip it to a guy that really needs it so youcan make some cash to buy other more "significant" tools in the future.
Chombi
Bianchi Goddess
Quoted: 2936 Post(s)
Liked 2,933 Times
nice score but I think there is a part of hanger alignment tool missing. where is the part that slides back and forth to contact the rim? something like this one. https://www.parktool.com/repair/readhowto.asp?id=39
if I had a hanger alignment tool I would check every new or used frame I was building or fixing up for the first time. seeing a hanger is bent in in the vertical plane is easy. but if it is bent, hhmm well that is not exactly horizontal so howabout if it is twisted?
PS is the "little thing" something you attach to a tube of grease to lube cables? do you have acloseup?
Sugar "Kane" Kowalczyk
car dodger
Here's a close up of the "thingy":
I'm sure it's bound to be someone's holy grail!
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Bianchi Goddess
Liked 2,933 Times
does that slide onto the derailleur alignment tool? it looks like there is a place for a screw or setscrew
car dodger
Yes! But what is missing to check the measurement?
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
N+1
Bikes: A few
Liked 5 Times
car dodger
But then why does the thingy fit perfectly onto the campy alignment tool? Coincidence?
Edit: actually it doesn't fit perfectly, it is a little big and has some wiggle slop - not useful for measuring.
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Quoted: 3464 Post(s)
Liked 2,831 Times
It's funny how tools become so specialized even though they have such simple functions. .... Question is, how many times do you really get to use these things to make it worth buying or just taking up space in your tool boxes? I currently have a good lead on some real nice Park tools but I can't figure out what to pull the trigger on because this question keeps coming up in my head. How many headsets will I install in the next 5 years??....uhmmm maybe three or five at most. Is it worth getting that headset installing tool from my lead then???, Do I really need a humongous wheel dishing too crowding all my other stuff if I only expect to build 1 or 2 wheelsets a year at most??? Gosh, I can't seem to answer those questions.......Anyway, my LBS isn't that far away to have it done those few times.....
Chombi
Chombi
Second, you are correct the number of times of use is limited, but when THAT tool is needed, there often is no substitute. Or the substitute is shadetree in nature, like using a bolt, bushings and washers to install a BB fixed cup. A shop I worked for was using that set up, I looked at the owner with the expression of surely you are joking? Not too long later he finally got a Campagnolo tool kit.
Third, after you have used good tools, marginal work-a-rounds are just that, marginal.
Be a man, buy some tools.
N+1
Bikes: A few
Liked 5 Times
First, I don't trust the mechanics at the local shop.
Quoted: 150 Post(s)
Liked 34 Times
Hoho! "be a man, buy some tools??!" If only you know how much tools I already have in my steel tool shop chest that must weigh over a couple of hundred pounds I use for my motorcycles and my cars and my bikes, you would understand why I would try to limit to buy yet another tool that will just get buried under all the other tools I already have, because I rarely use it.
Been tooling around bikes since the 70's as a kid and have been successfully able to work out, remove and install even the most recalcitrant part a bike had ever presented to me and so, for my purposes, only the most proprietary tools (like freewheel removers and crank pullers) that will only fit certain brand of parts are the only ones I still buy tools for.
Chombi
Chombi
bikerbobbbb
Bicycle Mechanics
14
03-27-16 02:30 PM
pumabicycle
Bicycle Mechanics
36
04-27-14 07:20 PM
