Ever wondered what happens if you inflate a tyre until it explodes?
(starts at 8:30) Don't try this at home, kids
Quoted: 303 Post(s)
Liked 136 Times
Back in the '70s before hookbead was developed, inflating a tire was an adventure, you never were quite sure the
tire would hold or not on the basis of friction and air pressure. I had a number of blowouts over the years, sounds
like a 22cal pistol being fired. Hook bead tires do this on rare occasions when the hook is not fully seated. If you
are looking at the right spot you can see and sometimes catch the herniating tube before it blows with a bang.
Found out the hard way when a girlfriend decided to put air in the tires of my mountain bike. 100 PSI in clinchers (not tubeless) blew about an hour after she filled the tires...the front had a bent rim and torn sidewall and the rear just had a shredded sidewall.
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Quoted: 4210 Post(s)
Liked 3,875 Times
Any one who has worked in a LBS knows that creaking sound. Often accompanied with a "Ooo S..T!" then the bang if one's hands are not fast enough to purge the valve. (Actually more often one hand, the other one is madly trying to keep the creeping off tire in the rim). Andy
AndrewRStewart
AndrewRStewart
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Ugh I reflexively flinch just thinking about this.
2 stories:
When my now-wife and I started dating I was at her apartment one evening and I had brought my commuter bike inside with me. We were watching TV, the bike was leaning against the wall, not being touched, when BAM! the tire blew off. Turns out the rim tape had gotten out of place so one of the spokes was poking into the tube and it decided to fail at that moment.
It took several hours for the cats to reappear.
Second time: I had bought an old gas-pipe Raleigh and converted to a fixie/beater bike for getting around town. Having grown up in the 80s and 90s I wasn't familiar with the old cheap steel clincher rims from the 70s, and I also was not familiar with the fact that they don't have much of a hook to hold the bead. So I inflated the tires to 90 PSI which was normal, for the time.
I had two tires catastrophically blow out from under me before I figured out I should run lower pressure. I didn't crash either time, but something that loud and unexpected, during a ride, certainly made my heart rate numbers spike up a bit.
2 stories:
Quoted: 1572 Post(s)
Liked 643 Times
It's been awhile but I can't ever remember being quick enough to save it once I saw the tire start to swell on the rim.
In the early 70's I had a Raleigh Grand Prix and a guy was working on it in the shop. I have always had a practice of putting talcum powder on the tube, more back then than now. The steel rims were not hook bead. He was using a compressor. Suddenly I hear a "POW" and see a white cloud billow out of the shop entrance . . . .
Quoted: 943 Post(s)
Liked 172 Times
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Will manufacturer warranty cover this defect?
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
215 psi on a carbon clincher rim. Inflated with a floor pump! Some delamination at 150 psi first.
From pinkbike. Action starts at 2:30. Note the full face shield on the operator.
https://www.pinkbike.com/video/336672/
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Yeah, Every kid growing up in the 60's and '70s who filled up their ballon tire bomber at the local service station with the air hose has done this.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
I remember working in the bike shop during the transition from 27" to 700C. We had many tires available in both sizes. If you put a 27" tire on a 700C rim it would work fine- then you'd pump it up to 80psi or so and it would crawl off the rim and go BOOM. Yes, Andy, I know that sound.
Jeff Wills
Jeff Wills
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times
I'm probably the only person who didn't know this but my exploding tube experience went like this: I had a flat tire on my touring bike - not a puncture, but the stem pulled away from the tube. So, I got a new tube and decided to test out my floor pump on the new tube before installing it in the tire (I had been having some issues with my floor pump sealing to the stems on my other bike and wasn't sure if it was a pump issue or a tube/stem issue with the other tubes). This was a heavy duty, puncture resistant tube and I started inflating it, again, outside the tire. I don't think I got above around 35 psi and I noticed the tube was looking somewhat distorted as it was inflated - some sections seemed to bulge more than others. So, I'm thinking the tube is defective since the tube isn't inflating evenly ... of course, at around 35 or so psi, the tube exploded. Was loud, and startling, as I'm thinking I'm well below the threshold psi that the tube could support and was NOT expecting the tube to burst.
So, if a burst tube is loud when it explodes inside the tire, I'm here to say it's even louder when outside the tire.
I always have to learn things the hard way ......
Liked 643 Times
Poorly installed tires can do this.. tube pushes the bead off the rim..
Inner tube goes boom..
The very day in summer 1993 we bought our first tandem, a Burley Duet (still going strong!). It's in the living room and it's 2am. BOOM! Those kids at the shop must not have mounted the tire correctly.......
A couple of months later, on a club ride, front tire, BOOM! in the middle of a pace line. Miraculously stayed upright and took out none of our friends. Gee, I thought I was so careful installing that tire.....
A couple of weeks after that, another club ride, another front tire detonation, this time at around 22mph on a turn. We were down in a split second. Lots of road rash but nothing broken and no other riders hurt. We limped home with about 50psi and I did some research. It turned out Specialized had made a run of Armadillo tires that were slightly oversize and they offered to replace my tires for free. They then proceeded to send me 2 27in tires instead of 700x25c. I donated them to a friend with full disclosure and he was going to use them to hang stuff up in his barn or something.
Continental ever since with 0 issues.
Quoted: 90 Post(s)
Liked 137 Times
LOL, I hate when that happens. This summer while working in my shop ( very hot day mind you ) I heard what sounded like a shot gun going off, scared me as it was loud and didn't sound like a bicycle tire exploding. I went outside and looked around at my car & truck tires and all was good & I never found what it was, fast forward to last month when I found what went boom. A good friend had his kids old Yamaha quad here for a bunch of work and the new tubes he put in the rear tires exploded ripping the tires apart lol.
Glenn
Glenn
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Long ago, I asked my son to use my compressor to blow up the tires on a garden cart. 25 years later we still have the discussion of whether "blow up" means "inflate" or "explode". I was a good 20 feet away and my ears rang for half a day.
Quoted: 943 Post(s)
Liked 172 Times
Quoted: 5224 Post(s)
Liked 3,585 Times
Wilson!
Quoted: 1074 Post(s)
Liked 295 Times
Tubes are only meant to provide an air-tight cavity, and rely on the tire for structural strength. Puncture-resistant or not, outside the constraints of a tire they will stretch unevenly to resemble a cartoon or a recently fed snake and eventually burst at a fairly low pressure.
